Ron Gray Posted April 23, 2021 Share Posted April 23, 2021 Good point Graham, my tank is mounted on a thin foam strip, has to be thin to get the tank in under the sloping 'screen', but I might see if I can get another layer in there. I'm using a SLEC tank at the moment and that has got their small tube clunk so could try a different make to see if that helps, can't see why it would but you never know. My money is still on the air leakage as I've also noticed some fuel residue on the front edge of the screen, just behind the needle assembly. All good fun this Miss Marple lark. Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted April 23, 2021 Share Posted April 23, 2021 Is your tank pressurised from the exhaust, not a problem from that side? Blocked nippel or kinks in the tube sealing the tank vent. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 23, 2021 Share Posted April 23, 2021 Yes Roy, pressurised from the silencer and not blocked as I use that to show me when it’s full, plus I can prime the carb by putting my finger over the exhaust. I’ve physically blown (mouth - yuk) through the pipes to make sure they’re clear. Anyway, new rear plate and needle assembly just arrived from JE (was showing as out of stock so ordered the individual parts but they came up trumps will complete assembly) so will fit that today and get it out flying again tomorrow. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted April 25, 2021 Share Posted April 25, 2021 (edited) My Bowman Spatman build completed, awaiting maiden. OS15 Max fitted, sidewinder style. Brown Paper/PVA covered, hot wire cut, polystyrene wings. Deviated from plan with fuselage slimmed to accommodate engine orientation. Light-ply (popular) fuselage sides due to lack of balsa. AUW 870g. Edited April 25, 2021 by Piers Bowlan 2 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 25, 2021 Share Posted April 25, 2021 Looking good Piers. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 29, 2021 Share Posted April 29, 2021 Well I took 'Spatty' out again today and got flights of up to 10 minutes! There problem was to do with the needle assembly so to avoid messing around I replaced the complete rear cover plate and needle (thanks to Just Engines) - sorted! Trouble is I just 'won' an eBay auction for another, this time brand new, OS 15 LA! 1 Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted April 29, 2021 Share Posted April 29, 2021 Glad you got it sorted Ron. Now you will have to build a Spatman twin if anything untowards happens to your Spatman. By the way, what size tank are you using? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 29, 2021 Share Posted April 29, 2021 Thanks Piers, I know I keep saying it but it’s such a hoot to fly, especially now that it can go 10 minutes. The other thing that has surprised everyone is how well it flies in windy conditions. I also discovered a new trick, one wheel touch and goes, brilliant! Anyway, I’m using a SLEC Maxi tank, 4oz size (blue). Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted April 29, 2021 Share Posted April 29, 2021 2 hours ago, Ron Gray said: Anyway, I’m using a SLEC Maxi tank, 4oz size (blue). Great, that is what I am using too. Good to hear it is fine in windy conditions ?. Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted April 29, 2021 Share Posted April 29, 2021 Hi Ron it certainly looks a hoot in your video, and blistering quick. Glad you got it all sorted. Every time I’ve had the opportunity to fly my one it been that windy I think I should know better! But it handles it very well. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 29, 2021 Share Posted April 29, 2021 It seems to be even quicker now that the needle has been sorted! Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted May 8, 2021 Share Posted May 8, 2021 Hi Gents, yet another wet weekend? however the good news is I've finished putting the words together for the article. To every one who has sent me pictures thank you very much, they are much appreciated. A quick reminder if anyone else has any more photos to add to the article, now will be a good time to do it. The pictures need to be well focussed and over 1MB to use in print, please include some details about your model to. No date yet when it will appear but appear it will. I have some other news, the Bowman brand along with Airsail should, all being well, be making a come back by the end of the year. Fingers crossed ? 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted May 8, 2021 Share Posted May 8, 2021 Excellent news Roy, on both fronts! Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted May 27, 2021 Share Posted May 27, 2021 Had the chance to take the spatman out yesterday for the first time in a bit. On the upside it wasn't raining but yet again it was windy, one day I will get to see how it flies in the flat calm. I took my cameras with me so have all the stills I need & from my hat cam some flying film. Did 3 flights and the one I filmed is the one where I land sideways and knock the gear off, wouldn't you just know it! Still the nylon bolts did what they were meant to, no over damage than that. Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted June 28, 2021 Share Posted June 28, 2021 Been a while since the last post, I assume we're all out getting stick time. Anyway I made a small mod, new undercarriage with bigger wheels. My old aluminium gear has got very soft, I think it's fatiguing from years bending. So I've picked up a length of 2mm x 20mm aluminium, It's easy to cut and bend to shape. This time I'm putting bigger wheels on, to help it run over the grass and moss and not dig in. No spats either, witch should all help with ROGs and landings. Questions is, can I still call her a Spatman? ? Quote Link to comment Share on other sites More sharing options...
Nigel Sharp Posted June 28, 2021 Share Posted June 28, 2021 So that will be a Bowman Spatless then ? 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 28, 2021 Share Posted June 28, 2021 Or Spatboy (until he grows a pair!) 1 Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted June 30, 2021 Share Posted June 30, 2021 On 21/11/2020 at 18:14, jeff2wings said: Ron, Jeff & Piers I've sent you all a PM's Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 30, 2021 Share Posted June 30, 2021 ??? Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted June 30, 2021 Share Posted June 30, 2021 Hi Ron, don't quite know know what happened there. I sent you a post, Kevin Crozier would like a higher resolution picture of one of your photos you posted here, if possible. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 30, 2021 Share Posted June 30, 2021 No problem Roy, do you know which one it? Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted June 30, 2021 Share Posted June 30, 2021 This is the one we are after, at above 1MB for good print quality, or higher if I can get it! The detail are in the personal message I sent this morning. Thanks for the help. ? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 30, 2021 Share Posted June 30, 2021 Never got the pm Roy! Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 30, 2021 Share Posted June 30, 2021 PM'd you Roy Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted June 30, 2021 Share Posted June 30, 2021 Thank you Ron that's fantastic. Got it. Quote Link to comment Share on other sites More sharing options...
