Danny Fenton Posted December 4, 2014 Author Share Posted December 4, 2014 Nearly time for rib tapes Looking forward to the rivets, especially on the fuselage Might look at covering the elevators and rudder next Cheers Danny Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 5, 2014 Share Posted December 5, 2014 Looking very good Danny, i'm almost there myself but i'm doing the fiddly bits I left earlier on John Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 5, 2014 Author Share Posted December 5, 2014 Thought I would go back and look at the rudder next. Looking at the pics they clearly show that something (probably alloy plate) is sheeted over the top of the rudder, but only back about 2/3rds of the way to the trailing edge. You can make out pop rivets, so I guess it is an alloy skin. So once the underlying structure is removed to resemble this more closely the pop rivets need doing.... Cheers Danny Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 5, 2014 Author Share Posted December 5, 2014 First of all I added some 1/16 wide strips of PVC tape to act as a foundation, then RCModellers glues was applied via a 30ml bottle with a green syringe needle. The number of drops (rivets) is not to scale because the rudder shape does not match the drawing so I have spaced them as I saw fit Once they are fully dry then I will add the covering. Cheers Danny Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted December 5, 2014 Share Posted December 5, 2014 ahhh rivets. i was wondering when some would turn up. Quote Link to comment Share on other sites More sharing options...
Charles Galloway Posted December 5, 2014 Share Posted December 5, 2014 Danny, Have you done anything to the wire on the tail wheel yet? It's something I've never tried to do. Any help would be appreciated. I've covered the cockpits with the silver tape and am about to have a go at riveting. I did a test piece which turned out ok when painted black and lightly sanded. How did you use the pewter rub? As you can tell, all this is new to me. Cheers Charles. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 5, 2014 Author Share Posted December 5, 2014 Managed to get the solartex covering on the rudder. With glue dots you have to be very careful when you get heat near them, they tend to flatten. In this instance a littl flattening is okay because these are supposed to be pop rivets under the fabric. They are holding what appears to be a semi transparent section and isn't aluminium sheeting as I supposed. Anyway be very gentle with the iron in this neighbourhood With hind sight 5 minute epoxy blobs might have been a better, all beit slower rivet material. The Chippy is unusual in that it has these rivets under the fabric, that ARE NOT covered in tape. If they were we would apply the glue to the outside of the tex and then add tape. This is why I have done it this way Hi Charles, the tailwheel is as it was. I wont be doing anything with it until after the epoxy and cloth go on. The pewter rub was applied very very gently to the end of a cotton bud, then most rubbed off the bud before touching the model. I got a bit carried away sometimes and a rub with your finger or a drop of acetone on the bud will shift it. Make sure the ecetone doesn't take your paint off first! Let us see some pics as to how you are getting on? Cheers Danny Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 7, 2014 Author Share Posted December 7, 2014 Faffed around for two hours making pockets that will hold the hinges straight, also worked on getting the elevator so that it easily dropped under its own weight. Not important for RC but certainly is for control line! Got there in the end. Had hoped to get the elevator trim area done tonight but wont get it done before the glue curfew so am going to call it a night. Looking at hese pics, going to have to retire this Nikon soon getting very tired, more noise on the sensor than not Maybe Santa will bring me a new one Cheers Danny Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 9, 2014 Author Share Posted December 9, 2014 All the Solartexing is now complete, just the rib tapes to do. Will move on to the cowl I think next as I think the fuselage at the front will need rebating so the top of the cowl sits flush with the fuselage whilst the sides and lower sections stand well proud to give cooling airflow from inside the cowling. Cheers Danny Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted December 9, 2014 Share Posted December 9, 2014 looking nice looking very nice looking very very nice. i will be interested in how you do rib tapes as i need to some on the Auster. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted December 9, 2014 Share Posted December 9, 2014 Posted by Tony Bennett on 09/12/2014 21:04:20: looking nice looking very nice looking very very nice. +1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 9, 2014 Author Share Posted December 9, 2014 Thanks chaps, sneaking up on the fun bit...... rib tapes, panel lines and rivets soon Cheers Danny Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted December 9, 2014 Share Posted December 9, 2014 If I try to match your level of detail Danny, this'll take me another five years! Quote Link to comment Share on other sites More sharing options...
Charles Galloway Posted December 9, 2014 Share Posted December 9, 2014 Looking amazing. I too have never done rib tapes, so looking forward to some lessons from the master. Quote Link to comment Share on other sites More sharing options...
Andy Muckley Posted December 9, 2014 Share Posted December 9, 2014 Nice work as usual Danny, look forward to see how you do the trim tab on the elevator, cheer's Andy Quote Link to comment Share on other sites More sharing options...
Nigel Day Posted December 10, 2014 Share Posted December 10, 2014 Lovely stuff Danny. 'Fun bit' hmmm.... Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 10, 2014 Author Share Posted December 10, 2014 Rib tapes are a doddle Charles, you will love them. If you want to go mad then you can add the stitching that goes underneath too. I am going to try the method Richard Crapp uses as opposed to glue strips. The scale of the model will dictate if this is worthwhile, so I will do a test first. Hi Andy I opted to NOT do the trim tab in lith, and have gone for a simple balsa version.Aare you going to be at Clubnight tonight? could bring along my Chippy if you need inspiration? Just trimmed the cowl and offered it up to the model, be warned the cowl is NOT as long as on the plan, I am only just going to get away with it! So be warned if you have made a bulkhead according to the length of the motor, check the cowl is long enough. Cheers Danny Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 10, 2014 Author Share Posted December 10, 2014 Okay played with the cowl a bit.... But first for Andy, the trim tab. fairly straight forward stuff really.. Nothing at all challenging with that. I am sorry if you were looking forward to the alloy version in lith, but it just didn't warrant the extra work. Chain drilled the cowl prop opening and air intake, then smoothed the opening with a Drum shaped Permagrit in the Dremel Made up a temporary 57mm disk to help allign the cowl and tried it against the fus. Due to the cowl only just being longer than the distance from the prop to the bulkhead, I added some balsa stock so that I could form a rebate. I made a sanding block (seem to have made a few more than usual on this build) And made the rbate for the top of the cowl to sit in. This puts the cowl flush with the upper surface of the fuselage. The shape of the cowl along the top is not perfect, but I am not prepared to mess around with it its close enough. Can you tell what it is yet? Cheers Danny Quote Link to comment Share on other sites More sharing options...
AlexJ Posted December 10, 2014 Share Posted December 10, 2014 Hi Danny, Your progress and solutions are really taking away some of my trepidation! I have a couple of questions. Did you recess the wing further into the fuselage, I seem to remember it being mentioned somewhere? Just interested what the exotic additive to create the epoxy filler you were waiting for was? You were going to use it for the wing fillets, I think. Regards Alex Quote Link to comment Share on other sites More sharing options...
Nigel Day Posted December 10, 2014 Share Posted December 10, 2014 Even your throwaway tools look better than my build Danny. Thanks for the heads up re the cowl and fitting it. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 10, 2014 Author Share Posted December 10, 2014 Hi Alex, yes I moved the wing in the fus a bit, but not nearly enough to get the fillet at the front underside right. I wouldn't go mad here, something is wrong and you may create a rod for your own back just to make underside fillets look more accurate. Probably not worth the effort. If I were to make a guess I would suggest the wing section at the root is wrong and too thick. The magic substance i was waiting for is Microlight filler from West Systems. I haven't tried it yet as it arrived after i had finished the fairings in blue foam and balsa But there are a lot of fairings around the tailplane and fin that will need sorting after the fuselage is glassed so we can give the stuff a go then. The small amounts of filler used on the wing fairings just to tidy up was a product that Stevo put me onto some time ago. Its Red Devil "Onetime" lightweight filler. Its very similar to the stuff B and Q sells called Polycell "oneFill" But the Red Devil stuff sticks to balsa nicely and is easy to apply. The Polycell stuff sticks well to everything EXCEPT balsa and can be hard to apply. Cheers Danny Quote Link to comment Share on other sites More sharing options...
AlexJ Posted December 10, 2014 Share Posted December 10, 2014 Cheers Danny, I have used that Red Devil stuff, it is fantastic, it's so light you have to weigh the tub down! I will look up the West Systems stuff, I do love all the fluff and nonsense you can add to epoxy. I'll look at the wing height carefully, and make sure I maintain the correct angle of attack relative to the datum. Thanks Alex Quote Link to comment Share on other sites More sharing options...
Dennis Mulhair Posted December 10, 2014 Share Posted December 10, 2014 Hi Danny, Prior to applying the Solartex did you prep the woodwork with Balsalok or sanding sealer to make the covering stick better? Dennis Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 10, 2014 Author Share Posted December 10, 2014 Hi Dennis i applied some Balsaloc around the edges where there was not a big contact area. But otherwise no.Solartex is lovely to use but dont exceed 150 degrees or it may go saggy in the sunshine. I will be putting a coat of dope over the Tex once the rib tapes are on.CheersDanny Quote Link to comment Share on other sites More sharing options...
Andy Muckley Posted December 10, 2014 Share Posted December 10, 2014 Cheer's for that Danny, sorry for the late reply again, working some blinking mad hours again Quote Link to comment Share on other sites More sharing options...
