Danny Fenton Posted May 24, 2008 Author Share Posted May 24, 2008 Thanks Shaun, just wish I could FLY IT!!! Bloomin weather Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 24, 2008 Share Posted May 24, 2008 It's lovely here, sunny and about 8kts of wind. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted May 25, 2008 Author Share Posted May 25, 2008 Today is even wetter and windier than yesterday what country are you in Shaun??? Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 25, 2008 Share Posted May 25, 2008 Today is poo! Wet and windy, guess we were just lucky yesterday here in Shropshire. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted May 25, 2008 Author Share Posted May 25, 2008 Well I am only next door in South Staffs, it was blowing a gale yesterday!! Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 25, 2008 Share Posted May 25, 2008 Funny old thing, the weather. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted May 30, 2008 Author Share Posted May 30, 2008 Well still waiting for the weather to co-incide with a pass out but it looks good for this evening. I have added the spinner, it blanks off a good bit of the motor, the spinner is 4" and the motor.... well it isn't anywhere near that, so it is shielded from cooling air. If this first 4 minute flight goes okay I will add cooling tubes to feed the motor. I will recharge and measure how much goes back in. The next flight times will be adjusted accordingly. At 1kw then my pack should last for 3.5 minutes if i flew full throttle the whole time. But I wont be doing that ........ I hopeSpinner needs to be another inch I reckon Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 30, 2008 Share Posted May 30, 2008 Good luck this evening danny, I look forward to the post flight report, FDRs and video of course I am off back to the wotty now to fit the new eagle tree unit and LCD panel Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted May 30, 2008 Author Share Posted May 30, 2008 A couple more shots, they may be the last of it in one piece Just need one of it in the air now Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted May 30, 2008 Author Share Posted May 30, 2008 Going to have to get somebody else to film the flight Chris is complaining he never gets to see the model except through a viewfinder Have fun with WATTY Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted May 30, 2008 Share Posted May 30, 2008 TimboWe tend to connect the LCD screen after the flight but before disconnevting the battery. Not sure if thats feasable with yr installation? Saves installing it "properly" Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 30, 2008 Share Posted May 30, 2008 Hi Chris...fitting it semi temporarily to the model with a bit of velcro - logger strapped to outside too - had to re-wire the ESC and UBEC etc, and also been busy on other stuff today Programming the new cheapy 50A ESC ( £9 from a UK supplier ) has been a pain..and the 2s setting LVC doesnt work...will probably use nicad setting and fool it into thinking there is 8 nixx cells which should give me about 7.5V cut off. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted May 30, 2008 Author Share Posted May 30, 2008 Well the Fury is determined not to fly.As I was wheeling her towards the runway, I must have caught the retract switch on the Tx just momentarily, any way it was enough to start the gear retracting, once the entire weight of the model was on a partially retracted leg gravity stripped the gears in the servo. The wheels would neither go up nor down and I could n't even lock them down to fly.So its another servo for me, and another unsuccesful attempt at flying the Fury Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted May 31, 2008 Share Posted May 31, 2008 AAARRRRGGGHHHH!!!!!!!!! Bad Luck!!!Weather looks good here over this weekend though, hope same with you, and that you get a servo in there......... Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted May 31, 2008 Author Share Posted May 31, 2008 Hi Dave yes the weather does look good, sunny at the moment and calm. Servo wont arrive from Hong Kong for at least a week so it will be sunny until then Might have to get the WATT4 out again Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 31, 2008 Share Posted May 31, 2008 Thats a bummer Danny Have a good weekend anyway and safe flying - the eagle tree is now instaled in my wotty ( I am trying very hard to resist the urge to rename it WATT4 ) .... its so common darling Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 31, 2008 Share Posted May 31, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 31, 2008 Share Posted May 31, 2008 I like that ... Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted June 1, 2008 Author Share Posted June 1, 2008 Well the Fury had two flights this morning with the undercarriage locked down. Unfortunately the video innadvertently got overwritten The first flight was very uneventful, it is not overpowered but after a three minute flight only 700Mah had been used. So re-charged and went for a more spirited 3 minute flight with a loop and a roll. still only used 1200, so 8 minutes sedate, or six minutes easily with a few aeros.Fulll flap landing was so slow it was gorgous, almost a three point landing right at my feet. I should have known that a landing that good must not have been captured on film the benefit of only being 8lbs.Anyway the Fury flies really well, did some lovely high speed low passes. Chris suffered a problem on his DH88 and it spun in from a great height, so although a good day for the Fury a very sad day for Chris's Comet, and it flew so nicely too. Really sorry to see it Chris.I will do a final total on the costings when I get a chance.Here is flight 2 Eagle tree Average current 15A 45A peak, 1000 watts peak, Average 329 watts Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted June 1, 2008 Share Posted June 1, 2008 One of those things Danny. Post mortem continues although Video and Eagle tree aren't really helping with that.It was the first flight of the Fury that we video'd over. At least we got the DH88 on tape for Splat and Youve been framed. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted June 1, 2008 Share Posted June 1, 2008 Well done Danny commiserations Chris Quote Link to comment Share on other sites More sharing options...
winchweight Posted June 1, 2008 Share Posted June 1, 2008 Good stuff Danny, get some film next week! Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted June 1, 2008 Author Share Posted June 1, 2008 will do chaps, it really does fly very well. Will look better when the wheels are tidied away. The nose tucks very sharply when the flaps are dropped (90 degrees)Verdict? a lot of model for £99...................a sixty 2 stroke would fly it..... Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted June 1, 2008 Share Posted June 1, 2008 Yes, but that would be smelly Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted June 1, 2008 Share Posted June 1, 2008 Oh thats very bad news Chris Trust the post mortem will be published on here - very sad.Well don e Danny on the Sea Fury... I have just finished uploading a few pictures of our fly-in to image shack, and will post them alter toinight - see, you guys should have come here, then the crash would not have happened. I have also just downloaded the leccy wattys first eagle logged flight.... disappointing in some ways - only managed 8 mins before the packs were obviously very low and I had to land smartish. No data yet, will try and post over on the wotty thread later tonight.I have noticed though on recharging when I got home ( rained off AGAIN! ) only 1657ma went back in ....and this is a 4000 ma pack which went pretty well flat as a pancake on me in flight ? Quote Link to comment Share on other sites More sharing options...
