winchweight Posted May 26, 2008 Share Posted May 26, 2008 My Mig build has already been started as it was a swap meet find. The wings are beautifully finished in what appears to be painted tissue and dope. What lightweight finish will give me the same result? If I should continue with tissue and dope, then how? I've never done it, nor seen it done. Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 26, 2008 Share Posted May 26, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 26, 2008 Author Share Posted May 26, 2008 Brill, thanks Eric. I know that film is stronger, I just never get a finish that I am happy with, so I thought I try summat new (to me). Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 26, 2008 Share Posted May 26, 2008 what about Poly C and tissue - several layers and coats? Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 27, 2008 Author Share Posted May 27, 2008 Never used it. Do go on..... Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 27, 2008 Share Posted May 27, 2008 here Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 27, 2008 Author Share Posted May 27, 2008 Sweet, I'll read and digest (figuratively). Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 27, 2008 Share Posted May 27, 2008 It really is excellent stuff, and far less smelly and messsy than dope or 2 x part epoxies etc. Quote Link to comment Share on other sites More sharing options...
Terry Whiting Posted May 28, 2008 Share Posted May 28, 2008 Shaun.....I have been at this building game many years, and I have found Profilm the icing on the cake as far as a covering material, so pal I do not know what you are doing to get a bad finish. Profilm will take all modelling paints except celulose based. The finished model needs wiping over with Isoropyl alcohole and is ready for painting. Spectra can be brushed or purchase in spray cans, and it is fuel resistant. What must be remember the finish is only as good as the preparation, and that applies to any paint or film covering..............Don't forget 95% of RTF use profilm Edited By David Ashby - RCME Administrator on 27/01/2011 07:49:22 Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 28, 2008 Author Share Posted May 28, 2008 True. What I have trouble with is edges and compound curves. The Mig15 I'm building has a graceful curved fuselage, but I'm worried I won't do justice to the wing which was covered (tissue and dope)before I bought it (at a swappie). Quote Link to comment Share on other sites More sharing options...
Terry Whiting Posted May 29, 2008 Share Posted May 29, 2008 When I started modelling tissue and dope was the norm,it's all we had, today I think it would kill me. I can understand you wish to do the wing justice by continuing that finish on the fuselage, but I think us modellers tend to go OTT with Warbird finishes, we become brainwashed with these pristine privately owned warbirds seen at our shows, which are nothing like the true finish. The ME 262 I have just finished, Is covered in grey Profilm. That fuselage has some serious compound curves, but was covered in four panels of film, starting at the bottom, sides, then top. The seams you can see, but you need to look hard. Best of luck on whatever you choice. Edited By David Ashby - RCME Administrator on 27/01/2011 07:48:06Edited By David Ashby - RCME Administrator on 27/01/2011 07:48:17 Quote Link to comment Share on other sites More sharing options...
Jonathan Lewzey Posted May 29, 2008 Share Posted May 29, 2008 you could get lightweight solarfilm called So-lite. Go to www.solarfilm.co.uk , click on iron-on coverings and then so-lite. There is no direct link. I've used it on a number of models. It works best on sheeted surfaces. Remember to keep your iron temperature low as it is thinner than ordinary film.Good luck with the build whichever method you choose. Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 29, 2008 Author Share Posted May 29, 2008 Thanks guys, there's some food for thought. What about brown paper and pva(?), would that be a suitable covering? Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 29, 2008 Author Share Posted May 29, 2008 Thanks Jet. I will either order some Poly C or have another bash with Profilm.Cheers all! Quote Link to comment Share on other sites More sharing options...
Geoff Smith 1 Posted January 26, 2011 Share Posted January 26, 2011 This thread is usless. Adverts covering right hand side Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted January 26, 2011 Share Posted January 26, 2011 tis for me too, damned nuisance Quote Link to comment Share on other sites More sharing options...
Dusty Posted January 26, 2011 Share Posted January 26, 2011 Same prob, keep it short! Quote Link to comment Share on other sites More sharing options...
Mark Millward Posted January 26, 2011 Share Posted January 26, 2011 Adverts on mine too Quote Link to comment Share on other sites More sharing options...
John Privett Posted January 27, 2011 Share Posted January 27, 2011 I was about to comment that the recent change to prevent this happening seems to have failed. But the post that caused this dates back around 30 months! If either BEB or David want to fix it, the problem is in Terry Whiting's post on 28/05/2008 at 20:16:00. It's the usual   problem. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted January 27, 2011 Share Posted January 27, 2011 Thanks John, the new site fix should stop this going forward but there's always those few historic cases that slipped through. Quote Link to comment Share on other sites More sharing options...
