Andy Clarke Posted June 30, 2015 Share Posted June 30, 2015 Hi, Just hoping someone could tell me yes or no to this- can I use a futaba 2.4 g tranny to buddy to another futaba but 35meg. Thanks Quote Link to comment Share on other sites More sharing options...
AJ Posted June 30, 2015 Share Posted June 30, 2015 Hi Andy, In principle there shouldn't be any reason why this shouldn't work as the radio should be a seperate stage from the channel source, but would be worth checking with someone who has these and can try it as Futaba do not always implement things in the most logical or obvious way. A. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted July 1, 2015 Share Posted July 1, 2015 Yes Andy we did so for years at our club. 2.4 set has to be master. John Edited By john stones 1 on 01/07/2015 00:20:06 Quote Link to comment Share on other sites More sharing options...
ChrisB Posted July 1, 2015 Share Posted July 1, 2015 I've used a JR 642 35mhz set as buddy and a Spektrum DX8 as master with no problems. Chris Quote Link to comment Share on other sites More sharing options...
Andy Clarke Posted July 1, 2015 Author Share Posted July 1, 2015 Many thanks for your help Quote Link to comment Share on other sites More sharing options...
Phil Green Posted July 1, 2015 Share Posted July 1, 2015 Posted by john stones 1 on 01/07/2015 00:19:31: Yes Andy we did so for years at our club. 2.4 set has to be master. it works either way John, both put out an identical ppm frame but the answer is "yes" Quote Link to comment Share on other sites More sharing options...
kc Posted July 1, 2015 Share Posted July 1, 2015 According to the Futaba manual it has to be two Futaba Tx with the 'rectangular' type plug. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted July 1, 2015 Share Posted July 1, 2015 I am not the sharpest knife in the draw with lektrickery Phil are you saying even with a 2.4 rx either set can be the master? John Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted July 1, 2015 Share Posted July 1, 2015 As fa as I am aware it can work either way . 2.4 Rx then 2.4 Tx is master and vice versa with 35 Meg Tx master for 35 Meg Rx Quote Link to comment Share on other sites More sharing options...
Phil Green Posted July 1, 2015 Share Posted July 1, 2015 If the rx is a 2.4 then yes the master has to be 2.4 What I meant was, if the rx is 35 that works too with the same physical connection but with the 35 tx as master. In other words it works either way, but of course the rx has to match the master tx Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted July 1, 2015 Share Posted July 1, 2015 Right lads, I've been doing it right then John Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted July 1, 2015 Share Posted July 1, 2015 **LINK** I asked a similar question. a link in this thread points to a trainer lead you can use if you have one square trainer port on one of the round type Quote Link to comment Share on other sites More sharing options...
kc Posted July 2, 2015 Share Posted July 2, 2015 The Futaba 6EX2.4 manual says both must be 'square' type. It says never connect to the round DIN type as it will damage your 2.4 Tx Quote Link to comment Share on other sites More sharing options...
