Tony Bennett Posted September 13, 2015 Share Posted September 13, 2015 Yes i am back decided that Depron is the way i want to go now with my building, so i have been beavering away in the back ground. been focusing on Free Flight mainly with a few RC models thrown in for good measure. FF models RC been working on my CAD as well, so i can draw up the plans better to make building easier. Tony. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted September 13, 2015 Share Posted September 13, 2015 You have been a busy bee Tony, very impressive. What is the twin, I don't recognise it, perhaps I should have gone to spec savers! Which CAD program are you using? I have had a go using Rhino for MAC but I didn't find it intuitive, probably because I am a bit of a luddite. I think it is one of those things you have to persevere with. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted September 13, 2015 Author Share Posted September 13, 2015 total cad. £7.99 from maplins. the twin is the Bristol Brigand. Quote Link to comment Share on other sites More sharing options...
eflightray Posted September 13, 2015 Share Posted September 13, 2015 Tony, I hope you don't mind me suggesting an alternative method to building fuselages to how you show in the last picture. I use a box structure with part formers added. that way you end up with a nice internal box for installing the receiver, servos, battery etc. CAD is ideal for determining the box size. Here's a link to the thread I posted -- **LINK** Ray. Quote Link to comment Share on other sites More sharing options...
Masher Posted September 13, 2015 Share Posted September 13, 2015 Glad to see you're back Tony, I've missed your build blogs - not enough of them around Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted September 13, 2015 Author Share Posted September 13, 2015 seen it neath thanks. there is a box in the front of the fuselage if you look carefully. i like my way as i can lay the fuselage halves down on the worktop when sheeting to i can keep them flat, then i glue the two halves together and add the nose box later. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted September 13, 2015 Share Posted September 13, 2015 Hi Tony, great selection of planes. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted September 13, 2015 Share Posted September 13, 2015 Excellent work as always Tony. Linds Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted September 14, 2015 Author Share Posted September 14, 2015 Mitsubishi zero well under way now. Quote Link to comment Share on other sites More sharing options...
Mark Stringer Posted September 14, 2015 Share Posted September 14, 2015 Looking good Tony!! Nice to see the Brigand coming together .. here is "G" in case you haven't seen this photo .. one of many from my fathers collection: edit: now I just need the plans to do one about 1500mm span with a couple of electrics in it Edited By Mark Stringer on 14/09/2015 13:37:24 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted September 14, 2015 Author Share Posted September 14, 2015 brigand was finished some time ago. i suppose i will have to finish the plans off now. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 14, 2015 Share Posted September 14, 2015 Still busy then Tony, good to see you posting stuff, nice work as usual John Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted September 14, 2015 Author Share Posted September 14, 2015 the spitfire sneaked up on the zero from behind. yakadakaka went the spits guns. i need to get out more. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted September 14, 2015 Share Posted September 14, 2015 Before you get out, you need to make a Buffalo. That'll even things up for the Zero. Quote Link to comment Share on other sites More sharing options...
