john stones 1 - Moderator Posted December 5, 2015 Share Posted December 5, 2015 Its birch ply Craig in special wood offers John Quote Link to comment Share on other sites More sharing options...
kc Posted December 5, 2015 Author Share Posted December 5, 2015 Sorry that's my mistake. It is of course Birch Ply. More expensive than other ply but much nicer to work with and stronger too. You can buy just a square foot if thats all you need. The big bits in the bargain section are a great buy if you need lots but beware the 60 inch lengths may add a lot to postage! Did you see my note about making the 6mm part from 2 layers of 3mm? Saves buying 6mm as well. Edited By kc on 05/12/2015 19:58:51 Quote Link to comment Share on other sites More sharing options...
Craig Thomas Posted December 5, 2015 Share Posted December 5, 2015 Is this just for the fire wall? Quote Link to comment Share on other sites More sharing options...
Craig Thomas Posted December 5, 2015 Share Posted December 5, 2015 So far I'm up to ?125 lol. I'm ordering g 1 extra of everything. Got most of the bits and pieces in the order. This dosent include glues or coverings but it does include a couple of tools and most of the hardware. Who knew building was so expensive? Hopefully not my wife. 😅 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 5, 2015 Share Posted December 5, 2015 Those prices for 24 inch by 60 inch look odd ? John Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted December 5, 2015 Share Posted December 5, 2015 Posted by Craig thomas 1 on 05/12/2015 20:43:13: So far I'm up to ?125 lol. I'm ordering g 1 extra of everything. Got most of the bits and pieces in the order. This dosent include glues or coverings but it does include a couple of tools and most of the hardware. Who knew building was so expensive? Hopefully not my wife. 😅 Yeap, building is definitely not a cheap way to get a model. I never cease to be amazed by many of the ARTF's I see (and fly!) - I simply couldn't build a model for what they cost. It does get a bit cheaper as you go on - because you acquire a "scrap box" - it is not scrap at all of course - its bits of wood left over when you have finished the model. But often you'll be surprised how much of a new build's material you already have in there. BEB Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 5, 2015 Share Posted December 5, 2015 And think of this. I know modellers who buy ARTFs and then are scared stiff of flying them because they know that one heavy landing will cause very serious damage. i.e. A Wilga, £400, Miss judged the first landing. Weeks of repairing. Now THAT is expensive! Quote Link to comment Share on other sites More sharing options...
kc Posted December 6, 2015 Author Share Posted December 6, 2015 The cost of all the balsa, ply & spruce ACTUALLY needed according to my material list ( if my estimate and calculation is right! ) would be £42.09 plus post if you bought from SLEC and very similar if bought from Balsa Cabin. The piano wire would come to £4.11 extra or £2.62 for just the 8SWG if you already have scraps of 14 & 16SWG for the elevator joiner & skid. My costing is based on buying the minimum size SLEC supply. For example buying a 300mm by 300mm piece of 6mm birch ply when you really only need 80mm by 110mm. ( you could laminate from spare 3mm ) Or buying 36 inches of dowel when you only need 2 inches and buying a full sheet of 1/2 when you only need half a sheet. So most people will be able to find these small bits in stock or have plenty left for other models. My estimate is also based on the most economical use of materials as I explained. Quote Link to comment Share on other sites More sharing options...
Craig Thomas Posted December 6, 2015 Share Posted December 6, 2015 I've over ordered on everything by at least 1 of each for the the numerous mistakes that will be made. Also got all the hinges and bits and pieces needed. Plus a plane and balsa stripper for future projects. Quote Link to comment Share on other sites More sharing options...
kc Posted December 6, 2015 Author Share Posted December 6, 2015 Make sure you store the ply properly -flat & weighted down- as the 3mm birch ply and 6mm birch ply needs to be flat but warps very easily especially indoors with central heating. John said "Those prices for 24 inch by 60 inch look odd ? " yesterday. It is noted that it's crossgrain. That normally means the outer grain runs acroos the short dimension rather than the usal long dimension. No problem for us as we only use small bits. However it is very cheap and might have some other defects, maybe warped? Edited By kc on 06/12/2015 16:51:09 Quote Link to comment Share on other sites More sharing options...
Craig Thomas Posted December 6, 2015 Share Posted December 6, 2015 I'll bear that in mind KC. All the building shall be in the garage so no worry of central heating wrapping. I need to figure out how to upload pictures on this forum via my phone and iPad. Think I'll be needing to post pics for advice at some point. Quote Link to comment Share on other sites More sharing options...
Craig Thomas Posted December 8, 2015 Share Posted December 8, 2015 I've just been going through the wood I have orders from the material list. With the tail plane, is it acceptable to glue 2 bits of sheeting together ? With all the wood I've got not one bit is big enough for the tail plane. Iss around 10mm short at the trailing edge. Quote Link to comment Share on other sites More sharing options...
Craig Thomas Posted December 8, 2015 Share Posted December 8, 2015 I've just been going through the wood I have orders from the material list. With the tail plane, is it acceptable to glue 2 bits of sheeting together ? With all the wood I've got not one bit is big enough for the tail plane. Its around 10mm short at the trailing edge. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 8, 2015 Share Posted December 8, 2015 Yes that will be fine but I would suggest making the join at the leading edge. At least that is the way I always do it. Quote Link to comment Share on other sites More sharing options...
Craig Thomas Posted December 8, 2015 Share Posted December 8, 2015 Makes good sense to me peter. Thank you. 👍 Quote Link to comment Share on other sites More sharing options...
kc Posted December 9, 2015 Author Share Posted December 9, 2015 It is easier to join a slightly oversize piece on and then cut to shape. Quote Link to comment Share on other sites More sharing options...
Craig Thomas Posted December 9, 2015 Share Posted December 9, 2015 Well, I now know what thickness wood I have. Just spent an hour with a vernier calliper measuring the thickness of the balsa. All wood is marked so I know what's what. Now all is left is to figure out what is the soft 3/32 from the medium. 🙄 Quote Link to comment Share on other sites More sharing options...
kc Posted December 9, 2015 Author Share Posted December 9, 2015 Digital kitchen scales are the answer. Quote Link to comment Share on other sites More sharing options...
Craig Thomas Posted December 9, 2015 Share Posted December 9, 2015 I'll have a go with the scales. Trouble is ours aren't digital. The wife's not much of a baker sadly. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted December 9, 2015 Share Posted December 9, 2015 I've got some digital scales I bought from Boots years ago. Their main use has been for mixing epoxy but they come in handy for other things as well. Thye're certainly not fit to use in the kitchen after being my workshop Geoff Quote Link to comment Share on other sites More sharing options...
kc Posted December 9, 2015 Author Share Posted December 9, 2015 Well you need digital scales in the house to weigh letters etc ....... However a simple balance of some sort works - you don't need to know the weight but just to find which sheets are heavier. Various designs for homemade balances are around somewhere...... Quote Link to comment Share on other sites More sharing options...
Craig Thomas Posted December 10, 2015 Share Posted December 10, 2015 Think I've made a little mistake on my wood order. Is the 3/8 x 1/8 trailing edge stock the pre shaped tapered wood? I've just bought regular shaped wood. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 10, 2015 Share Posted December 10, 2015 Yes, but you can easily shape it from 1/8" sheet. Matk it off, shape it and then cut it off the sheet. I use this method because it is easier than trying to get a perfect chamfer on 1/16" sheet trailing edges. Doing it this way you can just put the sheet trailing edges on and then add the final 1/8" X 3/*8" trailing edge Quote Link to comment Share on other sites More sharing options...
kc Posted December 10, 2015 Author Share Posted December 10, 2015 Peter's method gives more to hold onto which saves Elastoplast! Quote Link to comment Share on other sites More sharing options...
Geoff S Posted December 10, 2015 Share Posted December 10, 2015 ... but, kc, no model can fly unless it's anointed with blood I got my Dec RCME this am (paper version) and I'm pondering the plan. Geoff Quote Link to comment Share on other sites More sharing options...
