Tony F Posted December 5, 2015 Share Posted December 5, 2015 Got mine yesterday and I think these are the blades ?http://pages.ebay.com/link/?nav=item.view&id=330526698966&alt=webTony Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted December 5, 2015 Share Posted December 5, 2015 Sorry Trebor. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted December 5, 2015 Share Posted December 5, 2015 Posted by Steve Hargreaves - Moderator on 30/11/2015 21:11:33: Details here...... Interesting....it talks about the jigsaw having a DC motor so it must be a smallish size. I wish they would do a small circular sander too....that would be very useful... Actually most motors are DC (or, more strictly, ac/dc). Really cheap motors are shaded pole ac only - used to used in washing machines and cheap turntables, maybe still are. Then there's the definitely ac only brushless ones we use in our models. I was concerned it would need a DC supply, which I have, but I'd prefer it to be mains powered or, at least, with built-in rechargeable LiPos. I got one yesterday and it seems fine. The only problem was fitting it into the small rack pack on my bike. The box was bigger than I expected. I haven't tried it in anger yet but it seems it will be perfect for my needs. I did wonder where to get replacement blades and I'm relieved to find they're the same as Proxon and that Axminster stock them as well as available on eBay. I'm great fan of Axminsterr and have one of their smaller bandsaws I use a lot. Thanks for the info. Geoff Quote Link to comment Share on other sites More sharing options...
Plummet Posted December 5, 2015 Share Posted December 5, 2015 Posted by GONZO on 01/12/2015 13:57:32: Sort of connected; in the past I had a floor standing grinder. I removed one wheel and in its place I used a 'pigtail' to attach a buffing wheel. Is it still possible to get these parts or have the 'elf police banned such things? Have you seen https://www.machinemart.co.uk/p/cbk150c-6in-polishing-kit/ or http://www.axminster.co.uk/pigtail-mop-arbor-6mm-shank-503936 or even http://www.ebay.co.uk/itm/POLISHING-MOP-PIGTAIL-converts-bench-grinder-etc-/401024256099 Plummet Quote Link to comment Share on other sites More sharing options...
Essjay Posted December 5, 2015 Share Posted December 5, 2015 Have a look at Beesley Tools, they have a good stock of Proxxon tools and accessories including jigsaw blades. **LINK** Quote Link to comment Share on other sites More sharing options...
trebor Posted December 5, 2015 Share Posted December 5, 2015 Posted by Mark Kettle 1 on 05/12/2015 09:58:16: Sorry Trebor. Just kidding Those 2 blades should last me years if I just use it on thin ply 'n' balsa. Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted December 5, 2015 Share Posted December 5, 2015 Turned mine into a table top jigsaw. I've mounted mine upside down in some scrap wood off cuts so I can use it to cut out formers etc and have both hands free the move the work around. I made a frame from some MDF that is placed over the top of my circular saw so it's at a good working height. I rebated the table top to nestle the jigsaw tool in. I have access to the on/off switch and speed control underneath, it's held in place via the Tee bar on the tool and two 1/8" ply plates/saddles screwed in. The pictures hopefully will explain. The table top is 15 mm deep, after drawing around the heel sole plate and Tee bar I rebated the area needed for the tool heel in at around 7 mm down and the rebate for the Tee bar less so. Edited By Mark Kettle 1 on 05/12/2015 14:25:15 Quote Link to comment Share on other sites More sharing options...
Geoff S Posted December 5, 2015 Share Posted December 5, 2015 That's a good idea, Mark. I think I could do a similar thing and use my Workmate as its base. I use my bandsaw for most cutting but it's not very good at holes Geoff Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted December 5, 2015 Share Posted December 5, 2015 Cheers Geoff. Quote Link to comment Share on other sites More sharing options...
Stuphedd Posted December 5, 2015 Share Posted December 5, 2015 best idea you have published yet Mark !!! cheers pete Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted December 5, 2015 Share Posted December 5, 2015 Cheers Pete, it may be the only idea. Quote Link to comment Share on other sites More sharing options...
bert baker Posted December 5, 2015 Share Posted December 5, 2015 I purchased two of the jig saw's today the on off switch has failed on one of them. Has any one else sufferd the same problem, I had the last two in the shop so not sure I could get it changed for a replacment Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted December 6, 2015 Share Posted December 6, 2015 Got one of each in one of the Exeter branches. Very pleased with both.... Thanks for the prompt .. John Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted March 1, 2016 Share Posted March 1, 2016 Just had it stop working, checked the fuse and that the current was getting to the tool then took it to bit's and found one of the wires to the switch with only one or two wire strands for the connection. Stripped back the wire a little and re-soldered it and back working now. Phew . Edited By Mark Kettle 1 on 01/03/2016 11:29:16 Quote Link to comment Share on other sites More sharing options...
trebor Posted March 1, 2016 Share Posted March 1, 2016 I don't think that soldering iron is big enough Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted March 1, 2016 Share Posted March 1, 2016 I was just going to say that! Couldn't you find a bigger one Mark? Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted March 1, 2016 Share Posted March 1, 2016 Total power corrupts in this case it melts. I only used the corner (I couldn't find the smaller one, took ages to warm up). Edited By Mark Kettle 1 on 01/03/2016 11:51:31 Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 7, 2016 Share Posted December 7, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
