.. Posted December 12, 2015 Share Posted December 12, 2015 Does anyone know if it's possible to change the bearing in the cone end of a dynatron starter? It looks to be a sealed unit but maybe someone has had one apart ? Thanks J. Edited By Justin K. on 12/12/2015 17:37:10 Quote Link to comment Share on other sites More sharing options...
Don Fry Posted December 12, 2015 Share Posted December 12, 2015 How old is it, mine has the paint worn off, and still goes. Quote Link to comment Share on other sites More sharing options...
stu knowles Posted December 12, 2015 Share Posted December 12, 2015 I don't have the answer to your question but I have had mine apart to straighten the shaft and seen the bearing that you refer to. In the end I didn't need to replace mine. I also happened to be perusing the 'Simply Bearings' web site and remember seeing that they stock what appeared to be the same style of bearing I only mention it in case to struggle to find one. Let us know how you get on. As an aside, although I have used the Dynatron for years, last summer I happened to see and use the Just Engines geared starter. I bought my own the same day and have used it ever since. IMHO a better starter for less money. stu k Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 12, 2015 Share Posted December 12, 2015 This one here may be cheaper than a bearing ! There are also spares available...here Edited By cymaz on 12/12/2015 22:44:57 Quote Link to comment Share on other sites More sharing options...
.. Posted December 13, 2015 Author Share Posted December 13, 2015 Posted by Donald Fry on 12/12/2015 20:28:57: How old is it, mine has the paint worn off, and still goes. Does its age determine if it is a factory sealed unit then? Quote Link to comment Share on other sites More sharing options...
.. Posted December 13, 2015 Author Share Posted December 13, 2015 Stu , Cymaz , Its an ebay purchase . The guy is willing to refund me so I think I will just send it back. I had found the spares section and the listing of the complete motor led me to believe it may not be viable. If I were stuck with it then I would maybe try & pull it apart but I think I will return it and look for another. Thanks J Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 13, 2015 Share Posted December 13, 2015 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Jon H Posted December 13, 2015 Share Posted December 13, 2015 I use the J'en 6.5:1 geared job and run it off a 6s lipo. It will turn anything! I asked them to get me one for my pain in the backside SC 5cyl radial as their smaller geared starter didn't cut it and I saw the bigger one on the OEM's website. It also spins up my laser 300 and 360 with ease and it even shrugged off a DLE55 without any fuss. Just be warned that if you use 6s lipo its quite easy to weld the switch on if you aren't careful, especially when it is new. Also if you coil the cable around the starter when you store it the cable can break at the point where it meets the starter body. I took mine apart and have made a detachable lead using EC5 connectors and it works very well. Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted December 13, 2015 Share Posted December 13, 2015 Sadly I have gone through two Dynatron starters that I have packed up for various reasons (I don't know what I do to 'em) , but for some while I have been using the J'en geared starter on my 60cc petrol jobs and it turns them over with ease with two 12v LA batteries connected in series. When I first bought it I didn't think it would last 5 minutes, but I have had to eat my words. Good price too. Quote Link to comment Share on other sites More sharing options...
jrman Posted December 13, 2015 Share Posted December 13, 2015 I also thought that Dynatrons were the best but finally came to realise they are just overpriced! I bought a JE 6.5:1 geared starter and would thoroughly recommend them to anyone. Powerful, torquey and sensibly priced. Quote Link to comment Share on other sites More sharing options...
.. Posted December 13, 2015 Author Share Posted December 13, 2015 Thanks for the input chaps , looks like a Jen starter it is then. Quote Link to comment Share on other sites More sharing options...
Chris Jenkins Posted February 17, 2016 Share Posted February 17, 2016 Hi I fixed my Dynatron yesterday, which had the same problem as yours. There was no bearing in mine, just a brass bushing, which works loose due to smacking the starter on the engine. Take the end caps off, remove the bushed end and place a socket over the crimped in bush, give it a wack with a hammer and all is sorted. Easy job 10 miniuts, no bits to buy!!!!! Quote Link to comment Share on other sites More sharing options...
