Glyn R Posted June 12, 2016 Author Share Posted June 12, 2016 I have finished the fuse covering. I am about to glue in the Robart hinges. I normally use epoxy but I recently read about using canopy glue. Anyone tried it, should be less messy. Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 12, 2016 Share Posted June 12, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
cymaz Posted June 12, 2016 Share Posted June 12, 2016 I use epoxy...use plenty of Vaseline in the joint and around the knuckle. Work epoxy into the hole and on the END on the pin hinge. Best of luck Quote Link to comment Share on other sites More sharing options...
Glyn R Posted June 12, 2016 Author Share Posted June 12, 2016 As far as I can tell Pacer hinge glue is no longer available. There are posts which say that canopy glue is the same. I think I will stick to epoxy. I have done this before it's fine but fiddly. Edited By Glyn R on 12/06/2016 17:59:26 Quote Link to comment Share on other sites More sharing options...
Glyn R Posted June 12, 2016 Author Share Posted June 12, 2016 Thank you Percy for seeing the pun. Quote Link to comment Share on other sites More sharing options...
Glyn R Posted August 10, 2016 Author Share Posted August 10, 2016 There has been a tragedy in my life. My wife lost her battle with cancer on July 23rd 2016. I now have to pick up the pieces so the Extra will recommence. Quote Link to comment Share on other sites More sharing options...
Colin Carpenter Posted August 10, 2016 Share Posted August 10, 2016 Glyn. Deepest condolences. SWMBO is 3 years into her cancer battle, is ok so far. Colin Quote Link to comment Share on other sites More sharing options...
Simon B Posted August 10, 2016 Share Posted August 10, 2016 Very sorry to hear this Glyn. My condolences. Quote Link to comment Share on other sites More sharing options...
Manish Chandrayan Posted August 10, 2016 Share Posted August 10, 2016 My condolences Glyn. Quote Link to comment Share on other sites More sharing options...
Glyn R Posted August 10, 2016 Author Share Posted August 10, 2016 Posted by Glyn R on 10/08/2016 16:20:13: There has been a tragedy in my life. My wife lost her battle with cancer on July 23rd 2016. I now have to pick up the pieces so the Extra will recommence. I don't know how I came to get the date wrong. I guess it only matters to me, so the date was actually July 13th 2016. Thanks for all the condolences. Edited By Glyn R on 10/08/2016 17:29:20 Quote Link to comment Share on other sites More sharing options...
Martyn K Posted August 10, 2016 Share Posted August 10, 2016 That's dreadful news Glyn. I am really sorry to hear that. Please accept my condolences and take time to let the pain heal a little Martyn Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 10, 2016 Share Posted August 10, 2016 I am so sorry Glyn......thinking of you. Take care. Quote Link to comment Share on other sites More sharing options...
Glyn R Posted August 18, 2016 Author Share Posted August 18, 2016 Thanks for all the kind words. Even though we have never met it has helped. I have started to finally fix the elevator and rudder. The pilot has a home so some progress has been made. I will post pics shortly. Quote Link to comment Share on other sites More sharing options...
Glyn R Posted August 22, 2016 Author Share Posted August 22, 2016 The pilot rests on a removable platform above the servos. I like to use masking tape around the hinge holes which can be removed before it sets. Makes cleaning up much easier. The pin hinges were coated with Vaseline at the pivot before fitting. Finally with all controls attached. Next glue the canopy to its frame. Edited By Glyn R on 22/08/2016 09:37:58 Quote Link to comment Share on other sites More sharing options...
Glyn R Posted August 27, 2016 Author Share Posted August 27, 2016 Fitting the aileron servos and pushrods. The clevis are screwed onto a 3mm threaded rod with a 4mm carbon sleeve. At the aileron end is a ball bearing connection. Quote Link to comment Share on other sites More sharing options...
Rich too Posted August 28, 2016 Share Posted August 28, 2016 That looks great, and belated condolences. Quote Link to comment Share on other sites More sharing options...
David Davis Posted August 28, 2016 Share Posted August 28, 2016 Nice work Glyn. Belated condolencies from me. I've been travelling. Which plan did you use? Quote Link to comment Share on other sites More sharing options...
Glyn R Posted August 28, 2016 Author Share Posted August 28, 2016 The plan is the Roy Garner 1-4.5 scale version from Traplet. It was the nearest in size to my needs. Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted August 28, 2016 Share Posted August 28, 2016 I had one of the original Cmpro Extras that I had an OS 120 F/S in it. A great flyer until I got too clever with it and it got re-kitted! Nice job by the way Glyn. Quote Link to comment Share on other sites More sharing options...
Glyn R Posted August 28, 2016 Author Share Posted August 28, 2016 Same thing happened to me. It just occured to me that I only need to finish painting the cowl and it will be ready to fly. I will assemble it and test run the engine in the plane in the next day or so. Quote Link to comment Share on other sites More sharing options...
Glyn R Posted August 29, 2016 Author Share Posted August 29, 2016 Assembled ready for engine test run. Just waiting for my assistant to arrive. Quote Link to comment Share on other sites More sharing options...
Glyn R Posted August 31, 2016 Author Share Posted August 31, 2016 I have luckily discovered that there is a serious error in the engine mount. The reinforcement in this joint where the engine box meets the fuse is inadequate. It's already showing signs of movement before I have started the engine. The 1/2" balsa needs replacing with something much stronger. I will have to redo this joint before I can go any further. Edited By Glyn R on 31/08/2016 16:35:33 Edited By Glyn R on 31/08/2016 16:36:15 Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 31, 2016 Share Posted August 31, 2016 Carbon or fibre glass wrap with epoxy maybe ? Quote Link to comment Share on other sites More sharing options...
