Fun Flyer Posted August 16, 2016 Share Posted August 16, 2016 A question to all those who've been there and done that; is it possible or advisable to convert a Futaba T7CP Tx from 35mhz to 2.4ghz. I know that there's already a thread on converting a TC7P but I'm not sure if they're the same Tx. I ask because a few of us in our club who still fly on 35mhz have noticed unexplained, and unprecedented, glitching and mishaps recently and I for one am thinking of changing to 2.4 if I can easily convert my Tx. Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 16, 2016 Share Posted August 16, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
MattyB Posted August 16, 2016 Share Posted August 16, 2016 Short answer is yes - plenty of people seem to have converted them to FrSky for instance... Edited By MattyB on 16/08/2016 15:45:06 Quote Link to comment Share on other sites More sharing options...
Ian Moody Posted August 16, 2016 Share Posted August 16, 2016 I have converted four of these transmitters in the past with the last one being only about three weeks ago and can honestly tell you it is very easy following the instructions on Youtube and online else where. I have been flying with one converted for the last few years with no problems what so ever and the receivers are very cheap and easy to bind and have excellent range. Cheers Ian Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted August 17, 2016 Author Share Posted August 17, 2016 Thanks to all for the information and apologies for the slow reply. I had seen some information on the web but you guys have managed to pull it all together pretty well. While I'm leaning towards converting the Tx I'm still not convinced that its worth the trouble. I have been flying on 35mhz without any problems for more than thirty years but events of the past two months have brought this to a head. Two experienced flyers have lost models which went in without any warning and for no reason that was discernible afterwards. I've had three separate models, two electric and one IC take on a mind of their own for a few seconds before recovering. My three were at altitude so no harm was done. Percy, our field is miles away from garage doors or door bells but I do take the point that we don't know what else is out there! Ian, thanks for making it sound so easy. Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted October 27, 2016 Author Share Posted October 27, 2016 I've received the FrSky Module at last and have even progressed to looking in the back of the Tx. Am I right in believing that the Red, Brown and Black, Mod, +Vcc and Gnd, wires in the photo are where the module needs to be spliced in? I wnt to be very sure before I reach for the wire cutters that I'm not going to ruin a perfectly good Tx! Quote Link to comment Share on other sites More sharing options...
Phil Green Posted October 27, 2016 Share Posted October 27, 2016 Thats right, but remember you're connecting your Frsky module to the wires, not to the pos/neg/mod pads marked on the PCB in the photo. Also bear in mind Futabas strange use of colour: red=neg brown=pos black=ppm (mod) Remember to remove the crystal from the old RF board. If its a DHT 'hack' module, and you only even intend to use two-way (D series) receivers, then you can discard the one-way/two-way switch - it unplugs from the bind board. You can in fact discard the whole bind board, which is what we normally do. There are some Bind-board notes at the bottom of the Archive page of singlechannel.co.uk Dont power the module without an aerial attached. On my 6EX I put the aerial inside the handle which is very convenient when fighting through 5 feet of bracken. A black felt-pen top fitted the 35 aerial hole perfectly. Cheers Phil Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted October 27, 2016 Author Share Posted October 27, 2016 Thanks Phil, interesting information as usual on the single channel site. Futaba do seem to be in a world of their own when it comes to colour coding. I was thinking of fitting a two way switch in the Vcc line so that I could switch power between the original 35Mhz board and the 2.4Ghz module. That way I don't need to do a complete Rx refit of the existing models. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted October 27, 2016 Share Posted October 27, 2016 Posted by Fun Flyer on 27/10/2016 15:20:13: Thanks Phil, interesting information as usual on the single channel site. Futaba do seem to be in a world of their own when it comes to colour coding. I was thinking of fitting a two way switch in the Vcc line so that I could switch power between the original 35Mhz board and the 2.4Ghz module. That way I don't need to do a complete Rx refit of the existing models. Hi Fun Flyer. I used to switch between 35 meg and 2.4 until one day I forgot to extend the aerial while using 35 megÂÂ . Very nearly flew through a fence and just got aerial up in time. After that I went entirely over to 2.4 and at FrSky prices it didn't cost the earth. Edited By Engine Doctor on 27/10/2016 16:53:07 Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted October 27, 2016 Author Share Posted October 27, 2016 Posted by Engine Doctor on 27/10/2016 16:51:34: Posted by Fun Flyer on 27/10/2016 15:20:13: Thanks Phil, interesting information as usual on the single channel site. Futaba do seem to be in a world of their own when it comes to colour coding. I was thinking of fitting a two way switch in the Vcc line so that I could switch power between the original 35Mhz board and the 2.4Ghz module. That way I don't need to do a complete Rx refit of the existing models. Hi Fun Flyer. I used to switch between 35 meg and 2.4 until one day I forgot to extend the aerial while using 35 megÂÂ . Very nearly flew through a fence and just got aerial up in time. After that I went entirely over to 2.4 and at FrSky prices it didn't cost the earth. Edited By Engine Doctor on 27/10/2016 16:53:07 That would be a constant niggle!! Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted November 7, 2016 Author Share Posted November 7, 2016 Well, I finished fitting the module on Saturday night, flew on 35Mhz yesterday and managed to successfully bind a 2,4Ghz Rx yesterday afternoon. Next is to fit the new Rx in a model and try it out. All your advice is much appreciated. Quote Link to comment Share on other sites More sharing options...
