john stones 1 - Moderator Posted January 4, 2017 Share Posted January 4, 2017 Is that some heat proof gunk of some sort between the clamps and pipes Rich ? John Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 5, 2017 Author Share Posted January 5, 2017 Posted by Adrian Smith 1 on 04/01/2017 19:56:47: Very wise place to put a bracket on the header Rich. Saves vibration at the crankcase end! Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 5, 2017 Author Share Posted January 5, 2017 Posted by john stones 1 on 04/01/2017 19:58:59: Is that some heat proof gunk of some sort between the clamps and pipes Rich ? John Hi John, the bracket is a slightly loose fit on the pipe so I have used high temp silicon and let it set before tightening. Edited By Rich2 on 05/01/2017 06:35:26 Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 7, 2017 Author Share Posted January 7, 2017 I set up the twin elevator servos through ch 2 and 5 and the ailvator function. Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 7, 2017 Author Share Posted January 7, 2017 I opened up some more vent holes. Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 7, 2017 Author Share Posted January 7, 2017 Switches and fuel dots done. Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 7, 2017 Author Share Posted January 7, 2017 I tried some H9 alloy servo arms and love them set up the ailerons. Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted January 7, 2017 Share Posted January 7, 2017 Looking good Rich. With stuff like servo arms it is always good to spend as much as you possibly can for the best gear. My elevators are also set up using CH2 & 5 on my Futaba 14SG. So easy with that facility. Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 14, 2017 Author Share Posted January 14, 2017 I got the tank installed today, took me a couple of hours, which seems ridiculous, but a lot of that time is spent planning and trying different configurations. I don't know why but a bought a non rc fuel filter, on the basis that it should be a fit and forget item. I didn't factor in how much bigger it would be, and positioning it was a challenge. It also has 6mm inlet/outlets so getting the fuel tube on was fun - nothing a bit of boiling water couldn't sort! Anyway, all done and I'm pleased with the results. Getting near to completion now..... Edited By Rich2 on 14/01/2017 17:27:25 Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 14, 2017 Author Share Posted January 14, 2017 Edited By Rich2 on 14/01/2017 17:29:54 Edited By Rich2 on 14/01/2017 17:30:38 Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 14, 2017 Author Share Posted January 14, 2017 Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted January 15, 2017 Share Posted January 15, 2017 Nice tidy install there. I like the heat shrink on the friction points. Something I will adopt to, Rich. Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 15, 2017 Author Share Posted January 15, 2017 Thanks Adrian. It might not be necessary but it's good insurance. It doesn't like going round corners though! Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 15, 2017 Author Share Posted January 15, 2017 Sunday football cancelled today but there was a silver lining, I had time to crack in with the cowl! you need patience and a steady hand for this, neither of which am I blessed with but it turned it ok. For some reason I changed a habit of a lifetime and didn't use masking tape to mark the cowl - I used a permanent marker directly onto the cowl Edited By Rich2 on 15/01/2017 13:13:30 Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 15, 2017 Author Share Posted January 15, 2017 The header was tighter than expected so I have lined the inside of the cowl with aluminium tape, a couple of layers, hopefully the heat will not be a problem. Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 15, 2017 Author Share Posted January 15, 2017 Nearly finished, I used a grommet cut in half to protect the plug lead. Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 15, 2017 Author Share Posted January 15, 2017 Continuing with the cowl, I cut the dummy radial using the suggested hot knife method. And then it was time to glue to the cowl, the supplied clamps did not quite do the job, and some extra padding was required. Don't worry I did centre it!! Edited By Rich2 on 15/01/2017 18:28:55 Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 15, 2017 Author Share Posted January 15, 2017 I also got the choke rod done and it was a chance to use my new tap and die set! First I tapped the choke arm to m3. And then I did the same to the supplied nut and bolt. Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 22, 2017 Author Share Posted January 22, 2017 Drilled the prop - job I am now getting the hang of - and then had to trim the spinner to fit - a job I prefer not to do! I made a bit of a hash of the spinner, but its ok, I'll do better next time Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 22, 2017 Author Share Posted January 22, 2017 So, it was finally time to assemble the plane for the first time and balance using the buddy supplied. The batteries will need to be around the wing tube to balance - about right as I have the added weight of the canister up front. Any ideas on mounting methods? There is no obvious place to put them. Edited By Rich2 on 22/01/2017 15:27:31 Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted January 22, 2017 Share Posted January 22, 2017 What I have done, Rich is make a tray that fits into canopy hatch.Similar to putting in my Pilot RC Extra 330SC.Same for the AW Edge540. Bit of a pain, but it did the trick. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted January 22, 2017 Share Posted January 22, 2017 Looking good Rich. Is that a HobbyKing spinner by any chance? Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 23, 2017 Author Share Posted January 23, 2017 Posted by Gary Manuel on 22/01/2017 21:02:10: Looking good Rich. Is that a HobbyKing spinner by any chance? Cheers Gary, yes it is.. Quote Link to comment Share on other sites More sharing options...
Rich too Posted January 23, 2017 Author Share Posted January 23, 2017 Posted by Adrian Smith 1 on 22/01/2017 20:41:24: What I have done, Rich is make a tray that fits into canopy hatch.Similar to putting in my Pilot RC Extra 330SC.Same for the AW Edge540. Bit of a pain, but it did the trick. Thanks Adrian, I did think of that as I'd seen you do it before. I am not keen on it as I usually do semi permanent connections to the batteries. Is there any reason why I cant mount them directly to the top of the wing tube? Quote Link to comment Share on other sites More sharing options...
