shades Posted July 15, 2008 Share Posted July 15, 2008 I have just come across a glow engine on which someone (definately not me by the way), has been a bit over zealous with the old plug spanner, and stripped the thread in head of his engine. The engine in question is in fact an HPI 21 truck engine, but we'll try not to hold that against him. The replacement engine is well over £100.00 and he has no money. Still at school in fact.Normally of course you would just drill it out and tap up a size, but of corse a glow plug is a standard size. Is there a way of fixing this? Andrew Quote Link to comment Share on other sites More sharing options...
Ultymate Posted July 15, 2008 Share Posted July 15, 2008 His choices are heli-coiling it (if you know someone with the kit) or replacing the cylinder head (not the whole engine) Quote Link to comment Share on other sites More sharing options...
birdy Posted July 15, 2008 Share Posted July 15, 2008 You could try some mole renches. Quote Link to comment Share on other sites More sharing options...
shades Posted July 15, 2008 Author Share Posted July 15, 2008 Yes, I have heard of the heli-coiling thing, but didn't know whether it was possible to use this on such a small scale. I have already tried to find a new head but to no avail. Thanks.I don't get how mole wrenches are going to fix a stripped thread, Birdy, or am I missing something.Andrew. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted July 15, 2008 Share Posted July 15, 2008 You could try Devcon, failing finding such a small heli -coil .We have used it on cracked cylinder walls on large diesels (oil rig) with success .I'm talking about the stuff used by the Navy not the stuff I've seen in your local DIY shop .Know any sailors ? Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted July 16, 2008 Share Posted July 16, 2008 Hi ShadesHelicoils are made in small sizes but you will also need the appropriate special tap to cut the new thread. It is larger diameter but the same thread pitch as the original. The helicoil is then scewed in with a special tool and it locks itself in place. The glow plug is screwed into the helicoil.Neat and effective but I don't know if a helicoil & tap is made for a standard glow plug thread.You could try a motor cycle repair shop. Stripping threads in aluminium bike engines is quite common so they usually have helicoil kits. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted July 16, 2008 Share Posted July 16, 2008 The thread is 1/4 UNF but if you can't get it helicoiled you might be able to make a threaded bush from brass (similar expansion rate to aluminium, I believe, which is the reasoning behind ABC engines) if there's sufficient material around the thread to make it practical and lock it by staking with a centre punch. Getting it gas-tight will be the only problem but perhaps making it slightly oversized / tapered would help. Insert it with a shouldered bolt or a bolt and locknut once you have the length / fit about right... Not much to lose by trying... Quote Link to comment Share on other sites More sharing options...
birdy Posted July 16, 2008 Share Posted July 16, 2008 Sorry, I was tweeting up the wrong tree. Quote Link to comment Share on other sites More sharing options...
birdy Posted July 16, 2008 Share Posted July 16, 2008 Sorry about the rubish joke. Quote Link to comment Share on other sites More sharing options...
Brian Parker Posted July 16, 2008 Share Posted July 16, 2008 Are Glow Plug threads not 1 /4 X 32 TPI ? Quote Link to comment Share on other sites More sharing options...
david vine Posted July 17, 2008 Share Posted July 17, 2008 Hi shadesIf this were my engine, I would drill and tap the hole in the head out to something like 10mm depending on how much meat around the stripped thread.As suggested make a replacement bush with a thin flange and with 10mm thread on o/d and new plug threaded hole ,then put bush in the freezer for a couple of hours after which carefully heat up head in oven. Screw bush into head quickly , use old plug to drive it in tight down to flange. Nearly forgot use one of the high temperature Loctites / flange sealants under the flange.Try it, you wont be worse off than you are now!!!!!!!!!!!!!!!Dave V Quote Link to comment Share on other sites More sharing options...
Mark Lubbock Posted July 17, 2008 Share Posted July 17, 2008 Hi Brian is correct glow plugs are 1/4 x32tpi & is an old ME(Model Engineering) thread. I think it also approximates to a 1/4 UNEF not UNF.You would be hard pressed to find a Helicoil in this thread, so the bush method described by David would be the best if you can't find a new head. All you need to do is find (say) a 3/8 or M8 brass bolt, drill & tap a plug thread down the middle, dril & tap the head to suit & trim the bolt to the correct depth & thin the bolt head to a thin flange-easy with a lathe, but possible with careful filing. If you or a mate has access to a lathe, a new head would be a simple job. Quote Link to comment Share on other sites More sharing options...
jaktan Posted July 17, 2008 Share Posted July 17, 2008 do as I do and that is to put the head in a lathe bore and tap it to 10mm useing a first tap and dont take the tap right through and then run a 10mm die down a piece of brass rod heat up the head and loctite the rod and screw in as tight as possible and leave to cool cut of the rod as close as possible to the head place the head back in the lathe face off the rod and centre it and bore it 7/32 machine it flush and tap it out 1/4 32 tpi Iv' done that many times for the boys in the club and i aint had any complaints yet ive even done that to a cox 049 but not with a brass insert Quote Link to comment Share on other sites More sharing options...
Allan Jordan Posted July 17, 2008 Share Posted July 17, 2008 Hi Shades, I'm with the " make and fit a bush brigade" Question is.. do you have access to the machine tools to carry it out ? I have no idea where you are located so why not send me a PM..perhaps I can help. Quote Link to comment Share on other sites More sharing options...
Matt Posted July 17, 2008 Share Posted July 17, 2008 Why don't you give these guys a call. I've never delt with the firm but I have used helicoils on aircraft...if its good enough for a Tornado it should be good enough for a model enginehttp://www.ar-sheldon.com/acatalog/Helicoil_UNF_thread_repairkits_Kits.html Quote Link to comment Share on other sites More sharing options...
shades Posted July 18, 2008 Author Share Posted July 18, 2008 "Oh, you guys"Many many thanks for all your help and suggestions. Knowing the actual thread size and type is really usefull and gives a good starting point. I don't actually own a lathe, but that doesn't mean I can't do it. Keep the suggestions coming.Thanks again. Shades.Watch you don't fall from that tree, Birdy. You're supposed to crash planes into trees, not perch in them. Quote Link to comment Share on other sites More sharing options...
birdy Posted July 23, 2008 Share Posted July 23, 2008 ! Quote Link to comment Share on other sites More sharing options...
Chris Channon Posted July 23, 2008 Share Posted July 23, 2008 Give Dave Turner a shout on the RCMF forum, he might be able to help.Chris Quote Link to comment Share on other sites More sharing options...
Chris Channon Posted August 8, 2008 Share Posted August 8, 2008 Did you contact Dave ? did you get is sorted?Chris C Quote Link to comment Share on other sites More sharing options...
Garry Pollard Posted August 9, 2008 Share Posted August 9, 2008 Doesnt Seem interested Chris. Another case of possible rudeness as has been discused in past by Timbo. On the other hand he might not come on the forum again or his computer could have blown up , who knowsGarry Quote Link to comment Share on other sites More sharing options...
shades Posted August 9, 2008 Author Share Posted August 9, 2008 Garry, does it make me rude because I've taken more than one day to respond to a forum post. For goodness sake! My entire life does not revolve around forum posts, I do have a life aswell. Besides I've been involved with another thread. I have already thanked everyone for their help earlier in the thread. In fact I was blown away by the response. Thank you Chris for your suggestion, but with respect for Dave, I would rather take help when it was offered directly, rather than through a third party. (Sorry! now this sentence does sound rude. It's not supposed to be. I hope you understand what I mean).Shades. Quote Link to comment Share on other sites More sharing options...
david vine Posted August 9, 2008 Share Posted August 9, 2008 Hi ShadesIf you havent got it sorted yet, please send it to me and I will willingly fix it for you .My pleasure.Happy tp help. Regards Dave Quote Link to comment Share on other sites More sharing options...
shades Posted August 9, 2008 Author Share Posted August 9, 2008 That is very kind of you Dave, and I am gratefull. I have already attempted a fix which was successful.......upto a point. Right up to the point when full heat expansion took place and fumes started blowing out of plug hole thread. My problem I think was using the taps and dies which I had to hand which have a thread which is too corse for the job. Possibly now it would be more difficult to fix with the right machine as the hole would have to be even bigger than the 10mm it is now.However, I now have found a supply of new heads. The cost of which is only a tenner. Whilst the satisfaction of repairing it myself would far exceed a tenner, I couldn't possibly allow myself to put the onnus on someone else just to save me a tenner. Many thanks Dave, I'll let you know if it all goes pair shaped. (Or "out of round")Shades Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 10, 2008 Share Posted August 10, 2008 Nobody has commented on my suggestion yonks ago about Devcon ( the military type ) Its not a bodge job .I'm not into that . You can drill and tap it . Surely someone out there knows what I'm talking about To re-iterate -It's used for fixing cracks etc in cylinder walls etc & it works I can assure you sceptics Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted August 10, 2008 Share Posted August 10, 2008 MyronYes, Devcon aluminium filled epoxy is great stuff (the 5cc carburettor parts are glued together with similar) BUT it has limited tensile strength and temperature resistance (both are much lower than any aluminium alloy) so using it in a cylinder head stripped plug thread situation might be asking too much. Quote Link to comment Share on other sites More sharing options...
