john fuller 1 Posted November 9, 2016 Share Posted November 9, 2016 I am building a Piper Pawnee and have been trying to get a system working to spray water to replicate the real thing. I have tried quite a few ideas (not very successfully). The main problem with using water is getting a pump with a high enough pressure to spray out of nozzles for the whole span (73". Also with a 16oz fuel tank full of water it is emptied in less than 10 seconds. This set me wondering if a smoke system might be able to give the right effect through multiple nozzles??? Quote Link to comment Share on other sites More sharing options...
XK50 Posted November 10, 2016 Share Posted November 10, 2016 Remembered from a piece of Prod Eng coursework, circa 1968, in order to get a more uniform water spray across each wingspan, the orifices need to be of varying diameter (inner - smaller, outer - larger) to compensate for the drop in pressure. John Quote Link to comment Share on other sites More sharing options...
john fuller 1 Posted November 11, 2016 Author Share Posted November 11, 2016 I will give that a try. Thanks for that Quote Link to comment Share on other sites More sharing options...
Gordon Tarling Posted November 11, 2016 Share Posted November 11, 2016 I'd suggest that you don't waste your time with water - in model sized quantities, it's not visible enough when the model is flying and, as you've found, duration will be very short. I've seen several threads on several forums over the years and the most successful and visible system that I've seen used exhaust smoke piped to the wings and nozzles. Of course, if you're using electric power, Lipo batteries could solve your problem. Quote Link to comment Share on other sites More sharing options...
john fuller 1 Posted November 16, 2016 Author Share Posted November 16, 2016 Thanks Gordon, Yes it seems the water idea is a non starter, my only concern with the smoke idea is to make sure I dont restrict the exhaust and stop the engine running properly. I have been thinking that as some of them used a spreader system from a hopper that it might be better to run the exhaust through that rather than nozzles along the wing? Quote Link to comment Share on other sites More sharing options...
Gordon Tarling Posted November 16, 2016 Share Posted November 16, 2016 John - if a hopper and spreader is in the equation, that opens up a world of possibilities. Dusty products usually weigh less than water, so it should be quite possible to build a working hopper that's filled with some sort of powder. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted November 16, 2016 Share Posted November 16, 2016 I'm sure I've heard of people simulating spray (top dressing?) with talcum powder. I'd imagine a flinging system rather than trying to pipe it through nozzles would work best... Edited By Martin Harris on 16/11/2016 12:52:02 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted November 16, 2016 Share Posted November 16, 2016 Steam powers your answer Quote Link to comment Share on other sites More sharing options...
Martian Posted November 16, 2016 Share Posted November 16, 2016 I built a Piper Pawnee using a hopper into a spread we r have a look h**LINK**ere Quote Link to comment Share on other sites More sharing options...
Andy48 Posted November 16, 2016 Share Posted November 16, 2016 Peter Miller has a crop duster plan out there which uses flour/icing sugar. If you buy the plan it comes with his article which explains much about his successful attempts at dusting. Its the Agrocat from Traplet. Quote Link to comment Share on other sites More sharing options...
john fuller 1 Posted November 16, 2016 Author Share Posted November 16, 2016 Yes I have now decided to go with the hopper/spreader system. I like the model you have built it looks really good Martian. That spreader you have come up with looks good, I am going to have to put the feed to the spreader further forward as i have left it to late in the build to run it through the wing. Do the slots at the front give a good flow of powder through the vanes? Andy, I have built mine from the Traplet plan by Herman Grobler to 72" span, but I must say that it not a very good plan, there are a number of errors and information on the plan is minimal to say the least !!! Quote Link to comment Share on other sites More sharing options...
john fuller 1 Posted November 16, 2016 Author Share Posted November 16, 2016 Am now sitting and wondering if i can modify the wing as the spreader needs to sit directly beneath the wing for it to look right. I have had to re-do the top of the cockpit as the plan shows it tapers sharply from front to back which is wrong and proved to be impossible to glaze the cockpit doors because of the differing angles. i have modded the U/carriage from how it is in the photo as it looks completely wrong. Edited By john fuller 1 on 17/11/2016 00:06:39 Quote Link to comment Share on other sites More sharing options...
Martian Posted December 15, 2016 Share Posted December 15, 2016 Hi John how are you getting on with your Pawnee ? . Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 15, 2016 Share Posted December 15, 2016 Posted by Andy48 on 16/11/2016 20:57:42: Peter Miller has a crop duster plan out there which uses flour/icing sugar. If you buy the plan it comes with his article which explains much about his successful attempts at dusting. Its the Agrocat from Traplet. Actually I used talcum powder with a central dust hopper and spreader. Very effective and very commonly used. The design is a Traplet plan caled Agrocat Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 15, 2016 Share Posted December 15, 2016 You only need a hold about1" wide and 1 1/2" long. The veturi effect of the spreader sucks the powder out. You do need a pretty good seal between fuselage and wing or you get well talcumed servos. Quote Link to comment Share on other sites More sharing options...
john fuller 1 Posted December 23, 2016 Author Share Posted December 23, 2016 Martian, the build is almost complete with the exception of the dusting system. Am hoping for maiden flight on the Tues after Xmas (weather permitting). I also still need to get the decals sorted as I am doing it in the "westwick Distributors" scheme as this was a local company that was based at Ludham airfield andi have found some old photo's of their Pawnee's. will take some pics later today and post them on here. Peter thanks for that info. Will get the maiden sorted and then get the extraction system fitted. Quote Link to comment Share on other sites More sharing options...
Martian Posted December 23, 2016 Share Posted December 23, 2016 Good luck John Quote Link to comment Share on other sites More sharing options...
john fuller 1 Posted December 23, 2016 Author Share Posted December 23, 2016 Thanks Martian, do you know the rough sizes that you made your spreader box? Quote Link to comment Share on other sites More sharing options...
Martian Posted December 24, 2016 Share Posted December 24, 2016 Posted by john fuller 1 on 23/12/2016 21:20:41: Thanks Martian, do you know the rough sizes that you made your spreader box? **LINK** on page 1 is a close look at the spreader, dimensions at front are 9cm wide and 3cm high and the exit is 24cm x 2cm , my pawnee is 60inch span, your pawnee is looking great Martian Quote Link to comment Share on other sites More sharing options...
john fuller 1 Posted December 26, 2016 Author Share Posted December 26, 2016 Thanks for the info Martian, have taken a few more photo's outdoors, as the ones in the shed dont really do it justice Quote Link to comment Share on other sites More sharing options...
