DaveyP Posted January 28, 2017 Share Posted January 28, 2017 Hi all, I'm sure I can't be the only one to remember small ( very ) dome shaped washers in balsa kits. These were used to act as a stop on a wire axle, one each side of the wheel. The "cup" side of the washer being filled with solder. Are these still available ? if so where from, I've done a quick tinterbong search without success. Tia. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 28, 2017 Share Posted January 28, 2017 Cup washers were mainly intended as thrust bearings for the rubber powered props. Not sure if you can still get them SAMS do not seem to have them Quote Link to comment Share on other sites More sharing options...
Keith Evans 3 Posted January 28, 2017 Share Posted January 28, 2017 Search for "small cup washers" you should find some on E.Bay . Quote Link to comment Share on other sites More sharing options...
Don Fry Posted January 28, 2017 Share Posted January 28, 2017 I seem to remember them, were they not 'sprung' onto the axle. I tried soldering, but never had any success, and abandoned the idea to systems that reliably hold the wheel on. Quote Link to comment Share on other sites More sharing options...
Former Member Posted January 28, 2017 Share Posted January 28, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted January 28, 2017 Share Posted January 28, 2017 easy way to do it,just needs a dab of solder. Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted January 28, 2017 Share Posted January 28, 2017 Quote Link to comment Share on other sites More sharing options...
DaveyP Posted January 28, 2017 Author Share Posted January 28, 2017 What a great idea, thanks Jim Quote Link to comment Share on other sites More sharing options...
cymaz Posted January 28, 2017 Share Posted January 28, 2017 How about these..will they do ? Quote Link to comment Share on other sites More sharing options...
DaveyP Posted January 28, 2017 Author Share Posted January 28, 2017 Posted by cymaz on 28/01/2017 16:39:08: How about these..will they do ? Yep, they would look great on the outside of the wheel, but it says they are out of stock....... I'll keep watching them, thanks. Quote Link to comment Share on other sites More sharing options...
Martin Whybrow Posted January 28, 2017 Share Posted January 28, 2017 Perhaps Bellville washers would do the trick Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 28, 2017 Share Posted January 28, 2017 I have never lost a wheel when soldered on. I have seen more wheels lost (and lost one or two myself with collects and other methods.. I refuse under any circumstances to use any other method except bind with wire and solder Quote Link to comment Share on other sites More sharing options...
