cymaz Posted June 25, 2017 Author Share Posted June 25, 2017 Thank you Gents.........my mistake, they are Radio Active tanks . The plane is about 15 yrs old. The spars are spruce top and bottom. There are another couple of spars at the rear of the wing and there is the spar at the LE. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted June 25, 2017 Share Posted June 25, 2017 You can buy them direct from Radio Active. Quote Link to comment Share on other sites More sharing options...
cymaz Posted June 25, 2017 Author Share Posted June 25, 2017 Posted by Peter Miller on 25/06/2017 18:17:58: You can buy them direct from Radio Active. Can you buy online or do I need to ring up?? ( I need 4 !!! ) Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted June 25, 2017 Share Posted June 25, 2017 I rang up but you could check their website. I haven't got the web address though.Just google them. I had a n oldcatalogue Just gogled their website http://www.radioactivemfg.com/ Edited By Peter Miller on 25/06/2017 18:26:39 Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 9, 2017 Author Share Posted July 9, 2017 Update...! After being at Greenacres and club flying....etc...etc, thought I would post progress on the refurb. To be honest, it's been a little slow. Mrs Cymaz and I have had a tax bill, pay for the van hire and Travelodge for last week and had to buy a new mattress....oops. So, the covering expenses will have to wait a month or two until next payday. Although, Wheelspin Models supplied the 4 fuel tanks, replacement hinges and balsa filler. Today it was time to tackle the engines. They are OS 40la ones, so very simple. Stripped each one down to see if there was any damage inside, replaced the pipe on the remote needles and put new OS F plugs in. Each one started by hand after a few flicks and was a complete non-drama.. The battery and switch have been replaced. New wing servos with new hatches have been installed. And the cockpit modified and ply lined to accept a couple of pilots. I have also settled on the colour scheme. Edited By cymaz on 09/07/2017 18:01:33 Edited By cymaz on 09/07/2017 18:02:22 Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 9, 2017 Author Share Posted July 9, 2017 So many engines....so little time New wing servo covers.. Engine nacelles ready for covering... Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 15, 2017 Author Share Posted July 15, 2017 Spending today on the wing. Most of the hinges can pull as the glue has failed. So the first job is to re-glue,pin and re-hinge. Installed new aileron push rod and servo arms. Rough mounted the engines, adjusting the end points for all four engines......not an easy task! Not taken any pictures as there is really nothing new to see. If anyone wants details of how I adjusted the end points for the four engines from one servo, I will gladly share. Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 15, 2017 Author Share Posted July 15, 2017 Throttle servo...each arm is controlling one pair of engines, I have decided on the colour scheme, for the moment. It may yet change!! White and red on the fuselage. Back bands across each wing with black engine nacelles. Possibly red wing tips. And if I can find suitable Canadian decals I will go for them. It's a bit of mix and match but I don't mind....its not exactly scale. Edited By cymaz on 15/07/2017 15:01:27 Quote Link to comment Share on other sites More sharing options...
Rich too Posted July 15, 2017 Share Posted July 15, 2017 Sub'd Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 31, 2017 Author Share Posted July 31, 2017 The white Solartex has arrived so its time I started doing some covering.... 4 hours later !!!!!!!!!!!!!! (OK , so its all the difficult , fiddly corners. Doesn't time go quickly) Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 3, 2017 Author Share Posted August 3, 2017 9ft of lower wing covered......only another 9 ft to go The Poly-C and light fibreglass has arrived for the engine covers. Edited By cymaz on 03/08/2017 20:21:58 Quote Link to comment Share on other sites More sharing options...
kevin b Posted August 3, 2017 Share Posted August 3, 2017 If you consider the time taken to drink the malt and the fuel cost for flying 4 x OS40s, the malt is probably cheaper per hour. Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 3, 2017 Author Share Posted August 3, 2017 Posted by kevin b on 03/08/2017 21:27:58: If you consider the time taken to drink the malt and the fuel cost for flying 4 x OS40s, the malt is probably cheaper per hour. Should I run the 40la engines on Scotch ? Sacrilege! Some might say. However, the clean up at the end of the day will result in a rare blend Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 14, 2017 Author Share Posted August 14, 2017 UPDATE!!! Just finished covering the wing ( 18' in total), pinned and attached the ailerons and began fitting in the hatches. Also began covering the nacelles. It's the first time I have used Poly-C and light glass cloth ( 0.6oz/sq yd). So far it's been easy and straightforward to use. There is no smell, covers easily and soaks in well into the weave. I have done the two flat sides and will leave it to dry and then cut around the corners. The cloth does have some give and has gone around a corner-but no far. When the varnish dries I will cut the cloth, tidy up the corners and re-coat. The brushes wash out well with soap and water.... Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 15, 2017 Author Share Posted August 15, 2017 The pilot arrived over the weekend....ebay for a few £££. It was a swimming Action Man and felt heavy. So some surgery was required....the patient didn't survive. For those of a nervous disposition look away now..... He lost something else as well (no just the feet) I expect hate mail from the Action Man Appreciation Society soon Edited By cymaz on 15/08/2017 11:54:12 Quote Link to comment Share on other sites More sharing options...
Martian Posted August 15, 2017 Share Posted August 15, 2017 good grief man give him some dignity the recover is coming along really well ,p.s why not call it anteater Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 15, 2017 Author Share Posted August 15, 2017 I'm on holiday this week so I will get on with it....hopefully . Mrs Cymaz has agreed to dress him in a white shirt and blue trousers. I hoped to get two lads in the cockpit but I'm afraid he will have to fly solo. Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 15, 2017 Author Share Posted August 15, 2017 After a day in the garage...progress has been made Cockpit painted and glazed measured, cut and fitted. Not glued in just yet. Side windows now blacked out. I think it tidies up the sides. Began covering the tail / fuselage. This might be finished tomorrow ,if I don't go flying. Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 16, 2017 Author Share Posted August 16, 2017 Too windy to fly today so got on with the covering...now done Tail now finished. Rudder fitted with Robart pin hinges and epoxied in. Elevator fitted with flat pin hinges P.S. Found this site this morning. Might give it a try Edited By cymaz on 16/08/2017 19:50:19 Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 16, 2017 Author Share Posted August 16, 2017 Too windy to fly today so got on with the covering...now done Tail now finished. Rudder fitted with Robart pin hinges and epoxied in. Elevator fitted with flat pin hinges Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 16, 2017 Share Posted August 16, 2017 Interested in a pair of twin intelligent glow drivers for that? Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 16, 2017 Author Share Posted August 16, 2017 The wing is completely covered now Martin. Would installing them mean cutting open the Solartex?? Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 16, 2017 Share Posted August 16, 2017 Looking at the original cowls you may not have room considering that each motor needs a 1.2V supply and a switch plus charge/boost socket. Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 16, 2017 Author Share Posted August 16, 2017 Martin, the cowls are tight. The fuel bays have zero room. Thanks for the offer but I will get remote glows and screw them to the cowl bearers. Might get some of these....................oh, and 4 of these Edited By cymaz on 16/08/2017 22:00:00 Quote Link to comment Share on other sites More sharing options...
