Peggy Sue 2
5 hours ago, Geoff S said:
A bit off-topic but what CAD s/w do you use, Ron?  I have a 3D printer winging (or floating) its way from Bangood as I write and, to be honest, I'm half-dreading being unable to make good use of it as I have very limited CAD experience.
I use Fusion 360 which I find suits me fine (and it is free!). There are lots out there but Fusion 360 has got a good YouTube presence so finding how to do things is quite good. I'm no great CAD expert, sure I used to draw building extensions years ago using CAD but the whole 3D thing was new to me but I have got used to using it. The slicing software I use is PrusaSlicer which, again, is perfectly suited to my needs.
  • Thanks 1
I took PS2 out for a second day of flying today, boy was it windy again, but this time gusting and a lot colder. I moved the battery back by about 20mm didn't seem to make that much difference (difficult to tell in the wind) but, once again, It handled the conditions really well and I also got to try the snap roll which I need to perfect but it does them like Peter said. After 8 - 9 minutes of fairly energetic flying, I had 60% battery left (4S 3700 40C) which bodes well for calmer days.
  • 7 months later...
Hi Peter
I've got a Saito 45 Special looking for an eventual airframe, and am very taken by your girl here...
Does anyone have a copy (scan) of the article for this 58" version they could send me?  And where could I get a plan?
I've got the plan/article off Outerzone for the original 48" version, which I could instead build (for an unused OS30FS or a well run-in ASP30FS in my modest collection), but would probably be better off with something I can actually see in the air!
Jon
  • 2 months later...
If you have a normal A4 printer you can print it yourself.  Using a PDF viewer like (say) Adobe Acrobat or Foxit PDF you can opt to print all or any part of the drawing at 100% on several sheets if necessary with markers to aid joining with Sellotape.  It's surprisingly accurate.  I find it very useful to print parts of the drawing using the 'snapshot' feature to stick on the wood to aid cutting out.
I have a program called "Tile Print" on one of my very old computers which came with a CD of plans.  THis is great because one can also enlarge or reduce a plan by simply specifying a dimension  on the plan and then printing it out on A4
I must see if one can download this program on my other computers
  • 1 year later...
