Tim Campling Posted September 2, 2017 Share Posted September 2, 2017 Hi all, I've finally succumbed and bought my first petrol ic, a DLE 60 twin. Bought from a mate but unused originally from Steve Webbs. It's all plumbed in and live but I can't start it. The issue seems to be no fuel into the carb. If I blow down the feed pipe its like blowing against a bung regardless of throttle/choke position. I've checked the low and high speed needles are at factory. A small squirt of fuel into the pot creates a pop so I know there's a spark. I feel the carb is just not sucking fuel in but am I missing something, what am I doing wrong? Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 2, 2017 Share Posted September 2, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Campling Posted September 2, 2017 Author Share Posted September 2, 2017 Thanks Tom, is that easy enough, I presume there is a rebuild kit available. Is this sort of problem common and if so what's the prevention? Quote Link to comment Share on other sites More sharing options...
bert baker Posted September 2, 2017 Share Posted September 2, 2017 Always make sure you have a spark plug fully in the cap, the spark units can easily go wrong if the unit tries to spark with out a spark plug fitted,, There is loads of Walbro carb videos on net worth watching Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 2, 2017 Share Posted September 2, 2017 Do you have a tank pipe open to atmosphere? Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 2, 2017 Share Posted September 2, 2017 Put your finger over the carb and turn over. It should draw fuel into the carb. Once the carb it wetted then try starting. The diaphragm may have ton e hard but if its never been run then that's unlikely.! Quote Link to comment Share on other sites More sharing options...
ChrisB Posted September 2, 2017 Share Posted September 2, 2017 Take the diaphragm out a soak in petrol for a day or two, that may solve the problem Quote Link to comment Share on other sites More sharing options...
Gordon Whitehead 1 Posted September 2, 2017 Share Posted September 2, 2017 The reason that you can't blow down the feed pipe is that the regulator only allows fuel to flow when the engine sucks. So that is not a fault. Also, the Walbro pump is powerful enough that even if the tank vent is blocked, it will suck fuel and collapse the tank inwards somewhat before it gives up. The carbs are easy to dismantle and fix. Ebay has plenty of Walbro repair kits. These are usually illustrated showing the contents, so if the diaphragm needs replacing, just buy a kit with the same shape diaphragm as the one in your carb. Quote Link to comment Share on other sites More sharing options...
Ultymate Posted September 2, 2017 Share Posted September 2, 2017 If the engines new and not been run it's far more likely to be a stuck needle than a diaphragm fault. Before doing anything else I'd prime the carb by shooting some fuel down the venturi of the carb, assuming you have ignition this should usually cause the engine to fire which as a rule will shock the needle loose without the need to strip the carb down Quote Link to comment Share on other sites More sharing options...
Tim Campling Posted September 2, 2017 Author Share Posted September 2, 2017 Thanks for all the input guys. I did think about soaking in fuel, I'll check all the above and try squirting a bit of fuel up the chute. Quote Link to comment Share on other sites More sharing options...
onetenor Posted September 2, 2017 Share Posted September 2, 2017 Diaphragms can go soft / floppy and not draw fuel. Soak it not in petrol but in meths or Methanol for a while. Reassemble and test . .If still no joy then change the diaphragm. This happens quite often on CD Stromberg carbs on cars etc. It's a weird effect. Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 3, 2017 Share Posted September 3, 2017 HERE is the rebuild kit for you Quote Link to comment Share on other sites More sharing options...
John Emms 1 Posted September 3, 2017 Share Posted September 3, 2017 If a new Walbro carb is not drawing fuel, then pump fuel into the carb pump inlet to get the pump working. HTH, John Quote Link to comment Share on other sites More sharing options...
Gordon Whitehead 1 Posted September 3, 2017 Share Posted September 3, 2017 Posted by cymaz on 03/09/2017 08:09:23: HERE is the rebuild kit for you Excellent Cymaz That's well worth remembering. Gordon Quote Link to comment Share on other sites More sharing options...
Mike T Posted September 3, 2017 Share Posted September 3, 2017 Yup! Well spotted! Quote Link to comment Share on other sites More sharing options...
Tim Campling Posted September 4, 2017 Author Share Posted September 4, 2017 Cheers Cymaz. I can't get near it 'till the weekend but I've squirted a bit of fuel into the carb to 'wet' it. Quote Link to comment Share on other sites More sharing options...
