Robert Parker Posted January 11, 2018 Author Share Posted January 11, 2018 Hi Chris, The learning never stops, just keep building and flying Regards Robert Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 15, 2018 Author Share Posted January 15, 2018 Hi All, I have made a tentative start on the fuselage and all started well until I started placing the formers in position. Somehow I have managed to make some them too short only 3mm or so and I have re-made a part plus I feel that I need to have an additional former just in front of the tailplane as the transition form ovalish to square does not seem to work when I tried to bend a scrap piece of 1/16th let alone a piece of 3/32nd. All I have done is dry fitted so far so alterations can easily be done, so this is challenge no1. Overall I am pleased with the look. The 1/4 sq balsa is just placed and the formers will be notched to accommodate it, I will also be adding another in the forward section and join the two. Plan laid out ready to start. Most of the front formers turned out too short, I'll have to re-make those as well as...... ....add a new former as indicated by the pen and re-made K6(top right) Same position on the model perhaps not showing in to much detail the change from curvature to straight below the tailplane and then going to a curve on the underside. This will slow me down a little while I draw a new former and re-make some others, all part of the fun. That's all for now Regards Robert Quote Link to comment Share on other sites More sharing options...
Martian Posted January 15, 2018 Share Posted January 15, 2018 Cripes i'm getting a headache just following you Quote Link to comment Share on other sites More sharing options...
Concorde Speedbird Posted January 15, 2018 Share Posted January 15, 2018 That is an impressive bit of design and build work. Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 16, 2018 Author Share Posted January 16, 2018 Thank you CS, it is my most ambitious project so far, pushing to my limits of design and building but hopefully not the flying. Regards Robert Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted January 18, 2018 Share Posted January 18, 2018 Do you plan to build the wing with some washout, Robert? Wing size is huge, the tail with double rudder very effective and you don't have a Clark Y airfoil. If the weight is fine and you use washout to prevent a stall at the wing tips, it should be a nice flier. Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 19, 2018 Author Share Posted January 19, 2018 Hi Timo, Yes I am planning some washout on the wings when I get to build them. Regards Robert Quote Link to comment Share on other sites More sharing options...
Erfolg Posted January 19, 2018 Share Posted January 19, 2018 I considered building a Dornier flying boat, as they seem to be the dogs thingies to look at. It was one with a parallel chord wing, and a push me pull you engine arrangement. The body was to be Blue Foam. Then you come along and show how it should be done. It is great Quote Link to comment Share on other sites More sharing options...
Erfolg Posted January 19, 2018 Share Posted January 19, 2018 Whoops, something is not working properly, it seems! Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 20, 2018 Author Share Posted January 20, 2018 Erfolg, Go on go for it, it would be interesting to see the build. There are not enough flying boats around, it's the Do18 with the push me pull you engine setup you're thinking of I considered it myself at one point. Regards Robert Quote Link to comment Share on other sites More sharing options...
Erfolg Posted January 20, 2018 Share Posted January 20, 2018 As part of part of my preparation to build a model, I like to get my hands on a bit of background information. Not strictly data as such, more history. To that ends I bought a small booklet, a bit like mag in size, from a local second hand book shop. This turned out to be a PR pub., more about what a wonderful company is, its strong innovative history. A lot about the "X" or 10, a bit about the side sponsons as a innovative design feature. Then nothing about many of the Dorniers many of us recognise, other than some was planes were produced. Then loads about the wonderful 27 etc and their major contribution to satellites. That went in the bin. I have William Greens "War Planes of WW2", by then it was all tapered wings etc. I have never seen a Plastic kit as you have, Which I do think is useful, showing detail contours etc, which 3 view drawings at small scale cannot show. I must confess that anything approaching absolute accuracy is not my thing. I certainly do not have your level of skill and commitment to produce a work of art. I always think, yes, I will crash it, it is just when. No point in committing my soul and breaking my heart, because this view allows me to not be to embarrassed when others look at my models. Keep going as I am envious and enjoy this build. Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 20, 2018 Author Share Posted January 20, 2018 Hi Erfolg, Thank you for your kind comments, I tend not to think of any unscheduled arrivals shall we say, yes I do get annoyed when they do happen, but having made them they can be repaired hopefully. Think positive it will fly. After reading your post I looked on Ebay and although there are no plastic kits available, I did find a set of plans for sale from the USA of a 1/14th scale from amahobby, DORNIER DO-18K1 scratch build R/c Seaplane Plans 66.5 in. wing span The finished model looks good Regards Robert Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 21, 2018 Author Share Posted January 21, 2018 Hi All, I have made the first fuselage side and ended up making another additional former near the tail to keep the lines flowing smoothly. All glued up and added the 1/4sq longerons The additional formers in place Jointing the longerons and the 1/2"sq wing support in position My way of getting around a little problem. I decided to add some ply to support the phenolic wing tubing for the sponsons and needed to mark the centre on the ply so I came up with this I added some 3/32nd sq to help support the planking. The end result. So that is one side done, once this had dried I'll make the other That's all for now Regards Robert Edited By Robert Parker on 21/01/2018 19:11:03 Edited By Robert Parker on 21/01/2018 19:16:28 Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 28, 2018 Author Share Posted January 28, 2018 Hi All, Second fuselage side built, this time I managed to make a small mistake and cut the cabane support timber off after gluing it in place and had to fit a new one all done now , another senior moment . Clamped the two sides together and placed the tail assembly on top and she is looking good. After the photo was taken I realised my mistake of cutting the cabane support flush with the rear former,thinking of weight saving Coming together nicely I think I may have to alter the shape slightly of the former second behind the cockpit, a tricky point there where just behind the cockpit the top of the fuselage is almost flat and during transitions to circular over the next two bays. I'll wait and see how it looks with some dry sheeting first. Next, i'll join the sides together and have a go at making the cabane struts and set up the sponson support tubes, this could be fun. That's all for now Regards Robert Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted February 5, 2018 Author Share Posted February 5, 2018 Hi All, Well this last week has been a bit slow in progress with one step forwards and three back. That said, the fuselage has been joined and the cabane struts made and made again and again, finally got there as well as changing from steel to aluminium, a considerable weight saving. So not too many photos this time FAIL Attempt no1, the first bend went OK but when I formed the second it pulled the base shorter, try again. Metalwork is not my strong point. Attempt 3, much easier to form using the aluminium, these are just sitting in place. Since the photo was taken I have positioned these correctly and bolted them in place and wedged a ruler across the top and checked for alignment with the fuselage centre, spot on. Then removed them and glued up the sides then had to place the struts in position whilst offering up the sides and then clamping up the sides. That's all for now Regards Robert Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted February 5, 2018 Share Posted February 5, 2018 It’s going to be beautiful, you have a great taste in subjects. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 5, 2018 Share Posted February 5, 2018 Still watching & I'll second Colin here, Robert. Really going to become outstanding... Cheers Chris Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted February 5, 2018 Author Share Posted February 5, 2018 Thank you both, it is taking hold of me, as they do, all those curves, planking them well that could be interesting to say the least. I have another subject in the pipeline which I have started drawing but still in the very early stages plus another subject just keeps popping up in to my mind. Regards Robert Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted February 10, 2018 Author Share Posted February 10, 2018 Hi All, It's been a difficult week for me, my sciatica has returned again so I'm off work again, but unable to stand or sit for very long so my modelling has been done in short bursts until the pain is too much. I have also had tried aquapuncture for the first time to try to help but still not much improvement with two sessions or am I trying to rush it. Plus to assist the pain relief some red wine has been administered, not really recommended but it helps for a relatively good nights sleep. I have fixed the cabane struts in place and epoxied the bolts so hopefully nothing is going to move there. The sponsons support tubes guides are fixed in place started planking the fuselage and fixed the tail group in position. Setting up the sponson guides needed a little fettling to get the tubes parallel with each other and square to the fuselage. Once happy the guides were epoxied in place. Jumping ahead slightly, I placed the sponson ribs in place, roughly spaced, and I was pleased that they lined up nicely all bar one which needed a slight adjustment and they aligned with the fuselage side being just above the chine line. An odd angle of the top of the fuselage facing towards the bottom of the picture, planking started with a block glued in front of the stabiliser seat. The planking has been soaked in water and then persuaded around the compound curve and are fitted in pairs to try to avoid twisting the fus. This part of the planking is going to take some time until I get around the compound curve. I finally made a decision on how / where to mount the elevator servo. I was hoping to keep it hidden but I settled for just the arm and linkage showing. I realised today that I needed to glue in place the tail group as it would be difficult to get it set up correctly by keeping the fuselage centre square to the worktop and taking measurements at both ends again a little fettling of the seat was needed to get the measurements equal. Next, carry on planking and run in some pull cords for the rudder, elevator servos and power cables. That's all for now Regards Robert Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted February 10, 2018 Share Posted February 10, 2018 Robert, this is truly a scratch building master class! You have superb skills. Looking forward to seeing more soon Pete Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 10, 2018 Share Posted February 10, 2018 This is indeed a superb Master Class, Robert. Sorry to hear about your sciatica. Hope you get well soon. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted February 10, 2018 Share Posted February 10, 2018 Another nice build, Where have i been, there are so many nice builds going on at the moment. Watching with interest . Steve. Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted February 11, 2018 Author Share Posted February 11, 2018 Hi All, Thank you for your kind comments, not too sure about a "Master Class" though, just pushing my ability a little at a time. I'm just an average modeller hoping that one day to pass his "B" test. Regards Robert Quote Link to comment Share on other sites More sharing options...
