Keith Evans 3 Posted August 27, 2018 Share Posted August 27, 2018 I'm currently using a short length of old petrol hose pipe on my PAW 35 held on with a hose clip as an extender .What do others use to get the mucky stuff away from the model. I'm not thinking of a custom made job or anything that requires a lathe . Quote Link to comment Share on other sites More sharing options...
bert baker Posted August 27, 2018 Share Posted August 27, 2018 I’ve used plastic air pipe thick walled to good effect on a PAW Quote Link to comment Share on other sites More sharing options...
brokenenglish Posted August 27, 2018 Share Posted August 27, 2018 I use silicone tube. Find the appropriate diameter to get a good tight push fit on the PAW silencer outlet and you don't need any attachment device. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted August 29, 2018 Share Posted August 29, 2018 What ever you use don't scrimp on the diameter of exhaust oroextend it too far . A free flow for the exhaust is needed as too much back pressure will adversely affect the engine and can cause overheating etc. Edited By Engine Doctor on 29/08/2018 10:19:21 Quote Link to comment Share on other sites More sharing options...
Dai Fledermaus Posted August 29, 2018 Share Posted August 29, 2018 What ever you use don't scrimp on the diameter of exhaust oroextend it too far . A free flow for the exhaust is needed as too much back pressure will adversely affect the engine and can cause overheating etc. Edited By Engine Doctor on 29/08/2018 10:19:21 Would that advice apply equally to your average glow motor? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 29, 2018 Share Posted August 29, 2018 Just as a point of interest. You can solder up exhausts from tinplate and bits of brass tube using soft solder. IT works for diesel but NOT for glows. Quote Link to comment Share on other sites More sharing options...
Keith Evans 3 Posted August 29, 2018 Author Share Posted August 29, 2018 Hi all .I've all my glow engines fitted with standard B@Q plastic pipe ,some of it up to about 9" to 10" long for about 6 to 7 years now to minimise the mess .Yes I agree that power may be down but the way I fly ,mostly on 1/4 to 1//2 throttle it is not a concern and I suffer no over heating . On the diesel side the B@Q pipe melts through in two flights .I stayed away from silicon as I believe it is attacked by the fuel hence the use of Tygon for all fuel lines . The current length of tubing on my PAW 35 is about 2" and seems to run fine . Thanks for all the feedback. Keith Quote Link to comment Share on other sites More sharing options...
