New EDF Mini Jets- Jet Provost & Folland Gnat
hello alex,someone did have a problem with their Mig when they eventually found out their fan was designed for a 4s battery...and they had been trying with a 3s one.....not giving enough thrust...changed to 4s...model flew....
ken anderson...ne.1..long shot dept.
Edited By ken anderson. on 15/06/2020 13:13:56
Eddie,
Apologies I misread your post as about a Gnat not the Provost! Have not built that one but I think the same is true only more so. You need max thrust and lightest airframe you can. Maximising ( and I mean as big as you can possibly make it) the cheat inlet right next to the fan entry I think should be your next step. Up the battery c rating and measure the thrust before you try to fly.
Tim
I am also only getting about 300g thrust from my FMS fan in my Provost. I had the same with the fan in the Sabre which I posted about in that topic.
I was hoping it may have been a case of a bad fan, but the Provost is exactly the same. I have tried various batteries including a 40C graphene, but 310g was the best that I got.
No idea how anyone is getting these 600g figures!
Alex,
your model is a stunner - I nearly did that scheme and if i build another i will do.
As others say, its not the model , these is clearly something wrong.. the 3s fan has a 5400KV motor, the 4s much lower Kv so if on 3s would be low thrust. check yours....
If me i would try other batteries and esc in turn..
MY model has no issues on 3s, good luck
Steve
Thanks all.
EVERYTHING in the model is stock from the 4-max 3 Cell setup.
I've just ordered a couple of new Overlander Batteries - one 50C one 80C. It will be interesting to see if these can get the fan spinning any faster...
Does anyone have any other suggestions if that doesn't yield results? If it is a faulty ESC, is there a way to tell? Is the 4-max stuff decent or should I be going with a different type?
All my previous models have been off the shelf, which has been great for learning to fly - but useless for building my own; so any advice is really really appreciated! smiley
The problem certainly sound like a low thrust issue. Although my model is a Gnat it flies well and doesn't need an especially energetic launch to get it away easily. Full throttle and a firm 'push' and it is away with a nice, gentle, controlled climb out.
With a 2150 3S Opti-Power LIPO (35C continuous rating) installed the model weighs 615 grams and, using the 'kitchen scale' test produces around 580 grams of thrust. Fan and ESC both came from 4-Max. I also enlarged the 'cheat hole' by about 20% (pretty much as big as it could go) to help the fan 'breathe'.
One final thought occurs to me...……...have you 'trained' the ESC to recognise the correct full throttle point? If not then you might be a long way short of full power even with the Rx stick pushed fully forward
Just in case a batch of "3s" fan units have been supplied with a "4s" motor, can any of you with low thrust check the amps or watts at full power. Then someone can compare it with a known good 3s unit.
An rpm check would also be good, but perhaps not many would be able to do that.
Dick
I decided to try one of my old batteries with the Gnat just now using the kitchen-scales test.
The old battery is an Align 40C 2250mAh 3s and gives about 400 grams of power; that's about 60-70 grams more power than the new battery with an appreciable increase in pitch from the EDF.
The *new* 4 max battery, not used at all aside from with the Gnat is identical specs aside from being 50mah less, at 2200mah.
I can't explain this - I guess it might just be a quality issue!
Alex,
that thrust is way too low . There is a table on page 9 which lists my test results for a 3S set up using various size intake sizes. Although fully charged my lipo was only a 25C zippy. The 600 g thrust I finally achieved was With a peak current of 42A and an rpm of 49000. ( rpm was a factor of 2 out in my table as I used poles rather than pole pairs in my pre test setup!)
4max lipos are usually top notch and are my usual go to lipo. The zippy just provided a better physical size for this model.
Not sure what the problem is with your set up but a current measurement would sure help the analysis. Probably worth buying yourself a cheap watt meter. You just connect it in the battery lead and read the values.
Tim
Thanks Tim. I've just ordered myself a little watt meter. Given all i've read I simply cannot believe it is an airflow issue as I barely get to 400g static thrust with the battery hatch off.
I do wonder if I have a 4S motor. I guess this will be determined by the current draw results using the watt meter?
I think the ESC for the 4S and 3S setups are the same - they are just programmed slightly differently.
I do at least feel slightly better that it doesn't seem to be my build quality letting it down!
After another failed test flight I have given up. It was so bashed up I decided to just scrap it. In the process I thought I would look at the thrusts and they were as follow:
3 cell new Turnigy 30-40C 2.2 Ah hi discharge battery. Hobbywing 40 a esc. fully calibrated with throttle on radio. Hi timing. Powerfun 4900Kv on 3s. enlarged cheat hole to inch by three inches. AUW inc battery 700g.
Normal---- Bat hatch on. RX hatch on. 350 grams on scales. no chance of flying.
With just RX hatch off -------------------------430 grams. Did not fly
Here on its me deconstructing the plane
No duct tube no RX hatch -----------------466 grams
No duct tube with hatch -------------------378 grams
No bat hatch no RX hatch no duct --------466 grams
No bat hatch, no RX hatch, snapped off fuz/tail and duct. Rear of fan open completely 550 Grams.
So 550 grams max but no plane left. I may build another one but keep it lighter and go 4 cell.
I also have given up trying to get Provost to fly, have tested thrust and getting very similar figures to Eddie. Am now revising it to have motor and propeller at the front. Obviously doesn't look authentic, but should look ok in the air.
My motor was 2627-KV5400 running on 3 cell.
Edited By alan barnstable on 16/06/2020 08:41:14
My Gnat has the FMS 4s Fan unit in it, and this morning I tested it on 3s on the scales.
355 gms thrust at 21.3 amps 220 watts - and that was with an old 3s 2200 connected via a 300mm adapter lead (all I coulkd find at the time) as it had the wrong connectors. In all other respects it was in flying trim with the battery hatch on.
It does make you wonder if some units have been supplied with the wrong motor.
Dick
Edited By Dickw on 16/06/2020 10:45:51
