Cliff 1959 Posted April 30, 2019 Share Posted April 30, 2019 My friend has a problem in so far as his battery is fully charged but his motor is just pulsing and not reaching full power, any ideas he can try? He's rebound his tax. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 30, 2019 Share Posted April 30, 2019 Timing Cliff Look up Timing in his makers instructions Quote Link to comment Share on other sites More sharing options...
Cliff 1959 Posted April 30, 2019 Author Share Posted April 30, 2019 Forgot to say it's a foamy he hasn't flown for a year but it was fly just fine when last flown. Quote Link to comment Share on other sites More sharing options...
Colin Carpenter Posted April 30, 2019 Share Posted April 30, 2019 Could be cogging .Seen this several times recently and was dodgy connectors on motor or ESC ! Colin Quote Link to comment Share on other sites More sharing options...
Alan Thorpe Posted April 30, 2019 Share Posted April 30, 2019 I had the same problem a while ago and everthing looked ok at motor and esc....but motor kept pulsing too. So I carefully stripped back a small patch of insulation with exacto blade on each of 3 motor wires so I could do continuity test as far as the esc connector. Turned out one wire had open circuit just at connector but the heat shrink and insulation held it together so well, that it looked and felt perfect. Resoldered it and everything was perfect. Let us know how you get on. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted April 30, 2019 Share Posted April 30, 2019 It certainly sounds that one phase is open circuit either because of a broken connection as mentioned or a faulty esc (probably one of the output MOSFETs). Geoff Quote Link to comment Share on other sites More sharing options...
Outrunner Posted April 30, 2019 Share Posted April 30, 2019 As above, probably a bad connection to one of the motor wires. Had it happen a couple of times, the first time it was intermittent, the heat shrink was the only thing holding the connector on the end on the wire. Phil. Quote Link to comment Share on other sites More sharing options...
Brian Hammond Posted May 1, 2019 Share Posted May 1, 2019 It could be a worn out lipo. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted May 1, 2019 Share Posted May 1, 2019 As the other chaps have mentioned it's probably a dodgy connection. Poor soldering of the motor connections would be my guess.... Quote Link to comment Share on other sites More sharing options...
Cliff 1959 Posted May 13, 2019 Author Share Posted May 13, 2019 Well it turned out to be the esc, tried another one and all is well. The connections by the way were all good so who knows? Quote Link to comment Share on other sites More sharing options...
