paul coleman 1 Posted May 26, 2019 Share Posted May 26, 2019 Hi,Does anybody know.or have this trainer? just wanting a review. Quote Link to comment Share on other sites More sharing options...
paul coleman 1 Posted May 27, 2019 Author Share Posted May 27, 2019 Why is there no right side thrust with this model i am wandering! can somebody explain please? Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 27, 2019 Share Posted May 27, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted May 27, 2019 Share Posted May 27, 2019 Assume you mean the e-Pioneer? Reviewed in RCME some 10 years ago. Good model, pretty aerobatic for a trainer. Well made, usual Seagull quality. Pop the name in the site search box and you’ll find several build threads and the original review. Edited By David Ashby - Moderator on 27/05/2019 17:57:09 Quote Link to comment Share on other sites More sharing options...
paul coleman 1 Posted May 27, 2019 Author Share Posted May 27, 2019 Hi Doc,yes,why is there no side thrust? Quote Link to comment Share on other sites More sharing options...
paul coleman 1 Posted May 27, 2019 Author Share Posted May 27, 2019 sorry david,yes the pioneer. Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted May 27, 2019 Share Posted May 27, 2019 I have an e-Pioneer It has no side thrust issues. So no need to add anything Flies very well and is sooooooo much better than my foamy trainer Quote Link to comment Share on other sites More sharing options...
paul coleman 1 Posted May 28, 2019 Author Share Posted May 28, 2019 Thankyou Charlie,what about thebattery compartment not having a hatch,if the battery should come loose,its bye bye plane,so im gonna make one,and put a couple of 20mm holes in it,ive actually emailed seaguls technical department,they left it out for the cooling of the battery. Quote Link to comment Share on other sites More sharing options...
Andy C Posted May 30, 2019 Share Posted May 30, 2019 I wouldn't put a hatch cover on. All I did was use Velcro on battery and correspnding "shelf" to stop it slipping and effecting CoG and a couple of Velcro straps (superglued to keep from losing) around shelf and battery to stop it falling out. Works a dream. Andy Quote Link to comment Share on other sites More sharing options...
paul coleman 1 Posted May 30, 2019 Author Share Posted May 30, 2019 Thats what i have done Andy,i just want extra security with a hatch,but i may reconsidor Quote Link to comment Share on other sites More sharing options...
paul coleman 1 Posted May 30, 2019 Author Share Posted May 30, 2019 How then does this particular model not need any right hand sidethrust,when others do? Quote Link to comment Share on other sites More sharing options...
Brian Dorricott 1 Posted May 30, 2019 Share Posted May 30, 2019 Side thrust not required flies like a dream but I did put a lid on battery compartment , made a lip using ply to push one end under and a couple of self tappers with a bit of brass soldered into the slot to make thumb screws ?. Came down once unscrewed the lid and the velcro had let go but the battery stayed put . It's had a battery fall out hence the lid , and a mid air crash and was repaired easily both times . Only other mod was to lock the steered wheel straight ahead and junk the servo , just use the rudder once you have speed up on ground . Trained on it and passed my A test with it and still get it out when I can't be bothered getting the glow fuel out ! Would recommend to anyone as a trainer over any foamy , only bettered by a Seagull Boomerang with a 4 stroke but that's another story . Edited By Brian Dorricott 1 on 30/05/2019 18:55:32 Quote Link to comment Share on other sites More sharing options...
paul coleman 1 Posted May 30, 2019 Author Share Posted May 30, 2019 Hi brian,I passed my test with a boomerang,but im going back to basics,to get my confidence back,as i have been crashing recently,and my hearts not quite in it at the minute,so i liked the the look of the pioneer. Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted May 30, 2019 Share Posted May 30, 2019 Yep I am with Andy, no need for a cover, Velcro on battery and two Velcro straps. Keeps the ESC nice and cool. I pass the connectors through the bulkhead so I can connect the battery via the top hatch. Makes it safer as the model is both upright and constrained. I use the 4 max setup with 3S battery more than enough power. Charlie Quote Link to comment Share on other sites More sharing options...
paul coleman 1 Posted May 30, 2019 Author Share Posted May 30, 2019 Charlie,what size prop? Quote Link to comment Share on other sites More sharing options...
charlie holdford Posted July 16, 2019 Share Posted July 16, 2019 Hi Paul Sorry, missed this... 11x7 I have just (yesterday) passed my A test using the Pioneer, and great trainer. Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 16, 2019 Share Posted July 16, 2019 We had one as a club trainer. Flew well with a .46 glow Quote Link to comment Share on other sites More sharing options...
David Davis Posted July 17, 2019 Share Posted July 17, 2019 That Seagull E-Pioneer looks very much like a Boomerang. No wonder the Pioneer flew well with a 46 in the nose! Quote Link to comment Share on other sites More sharing options...
Redex Posted July 17, 2019 Share Posted July 17, 2019 Great trainer, I passed my A test some time ago with this model, but it will take you well beyond the A test requirements, good in the wind and some spares available too, lots of fun. There are lots of threads and help on this forum with at least 2 good articles in RCM&E (March 2008 and Jan 2013). Mine is still used occasionally and has a 4S4000, 60A Esc, EnErG C4420, and 12*6 APC power train. I use velcro to hold the battery in place but have also made a hatch out of scrap plastic to cover the LiPo which is then velcroed to the fuselage with a couple of ducts cut out of the plastic cover - just for some airflow. Quote Link to comment Share on other sites More sharing options...
