james brough Posted October 24, 2020 Share Posted October 24, 2020 THANKS peter i shall work it out one way or another Quote Link to comment Share on other sites More sharing options...
james brough Posted October 29, 2020 Share Posted October 29, 2020 hi it might sound a daft question to you but i can only build 1 wing on the plan and building board so how do i get to build the other side to get all the parts in the right position I AM NEW TO BUILDING SO DONT LAUGH Quote Link to comment Share on other sites More sharing options...
Mark Elen Posted October 29, 2020 Author Share Posted October 29, 2020 Hi James, There are various ways of doing this. Take it to the local print shop and ask them to scan it and print it in reverse is one way that I have used to good effect, the problem with this though, is if their machinery changes the scaling, it all goes wrong. (When I did it this way, I got them to print the whole plan, fus, Wing right way and wing flipped, to negate any scaling errors) What I did with PS, if you look on page 3 of this build, was to trace out the whole Wing plan, then flip the tracing and build from that. It is an hour or twos work and you need to be precise with it, though, to be honest, I spent more time sharpening the pencil than drawing with it, but it is do-able. Im sure others have their own ways of doing this. Cheers Mark Quote Link to comment Share on other sites More sharing options...
Mark Elen Posted October 29, 2020 Author Share Posted October 29, 2020 Hi James, I forgot to say, if you go down the tracing route, greaseproof paper will work - it’s what I used on the first attempt, but proper tracing paper is much better, I got a ten meter roll from e-bay for a few quid, it’s much nicer to work with. Make sure you pin it down over the plan and take your time. I then used a long straight edge and pinned both the original plan and my tracing to the building board and built the whole wing as one piece. If your board isn’t long enough, you will have to build one half at a time. Cheers Mark Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 30, 2020 Share Posted October 30, 2020 Another dodge is to wet the area with paraffin which makes it transparent. The paraffin dries after a time and the plan goes back to normal. A bit smelly and paraffin is not so easy to get these days. The reverse or mirror print is the best answer and I have never had any problems with it. If tracing the plan you only need one side of each spar and rib. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted October 30, 2020 Share Posted October 30, 2020 I always take my plans to the printshop, there is a commercial printers near me with large format printers. I pay about £3 a sheet. To be clear you should ask for a mirror image of the wing or you may end up with a black image with white lines and writing, for that is what a reverse image is. You could also get the plan slightly enlarged while you are at it if that is your want, although not useful if you are buying the CNC parts. I prefer to keep the original plan pristine so that I can refer to it, as I normally cut up the copies into the component parts. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 30, 2020 Share Posted October 30, 2020 One of our club members usually has about three copies including a mirror image one. Quote Link to comment Share on other sites More sharing options...
james brough Posted October 30, 2020 Share Posted October 30, 2020 thanks very much for that i get 2 copies of the plan local so i am sure they could do that Quote Link to comment Share on other sites More sharing options...
james brough Posted November 2, 2020 Share Posted November 2, 2020 hi the printers i have used before does not do it now another one wanted £40 to do it i shall have to bite the bullet and trace it Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 2, 2020 Share Posted November 2, 2020 £40!! Rip 0ff time in a big way!!! Quote Link to comment Share on other sites More sharing options...
kc Posted November 2, 2020 Share Posted November 2, 2020 When tracing a wing drawing you only need to do the ribs and spars etc. You dont need to do much detail and there is little need to do the tips. You can always refer to the printed plan for all the minor details. Use a sharp 2B pencil. One drawing can do both wing halves and saves messing up the original drawing. Lay it on a white paper background for visibility when building. Instead of tracing you could always mark the rib positions from drawing onto a balsa stick ( 1/4 sq spar ) and then draw onto white paper or transfer straight onto plasterboard etc then draw the ribs at right angles. Spar positions are spaced using a wing rib. I did that recently for a wing and it took about half an hour onto white paper because I did both wing halves TE to TE so all the rib positions were same ( opposite each other - just a matter of drawing the ribs right across both wing halves using a Tee square. The Tee sq could use the straight edge of a piece of plasterboard etc ) For tracing I used to use greaseproof paper sold by Tesco or Sainsbury in a 20m roll for just over a pound. Recent stocks seem to be almost opaque and brown, so of little use. as you don't find out until you open the packet. If anybody has found a better type -let us all know. Edited By kc on 02/11/2020 19:21:29 Edited By kc on 02/11/2020 19:25:51 Edited By kc on 02/11/2020 19:28:39 Edited By kc on 02/11/2020 19:31:45 Quote Link to comment Share on other sites More sharing options...
james brough Posted November 3, 2020 Share Posted November 3, 2020 thank kc i will try that starting tomorrow i hope Quote Link to comment Share on other sites More sharing options...
james brough Posted November 17, 2020 Share Posted November 17, 2020 hi folks there was an picture in rcme recently of a cowl that had keyhole slots in it that slid down four screws in the firewall and was held in place by a swivel does any one remember how thick the ply face was the cowl was built onto with the keyhole slots in Quote Link to comment Share on other sites More sharing options...
kc Posted November 17, 2020 Share Posted November 17, 2020 It was 1/16th ply on the Rans Chaos. If you use thicker ply it would work OK but the central cores of the ply are more obvious and are difficult to fill the voids in the wood. So 1/16 Birch ply is the stuff or it could be 2 layers of 1/32 if that is all you have in stock. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 17, 2020 Share Posted November 17, 2020 This is my standard cowl retention system. As has been said. 1/16" ply works well.Youjust need a little swivelling catch at the bottom Quote Link to comment Share on other sites More sharing options...
james brough Posted November 17, 2020 Share Posted November 17, 2020 thanks very much for the info on the cowl i had cut a 1/32 ply so i cut another to glue together today depending on any replies now i can glue them up THANK YOU KC AND PETER MILLER Quote Link to comment Share on other sites More sharing options...
james brough Posted December 22, 2020 Share Posted December 22, 2020 hi another query on peggy sue 2 cant see any reference to the elevator wire dimensions to join the two pieces together or what gauge to use any help would be very much appreciated regards jim Quote Link to comment Share on other sites More sharing options...
kc Posted December 22, 2020 Share Posted December 22, 2020 14SWG ( about 2mm ) piano wire is used on other models and should work. It's quite important to ensure the joiner does not become loose in any model. Accurate hole drilling is important. Some of my models have a tiny patch of 1/64 or 1/32 ply over the balsa at that point and also a the horn mounting. The edges of the ply are sanded to a chamfer before fitting and are almost invisible. Actually I hate wire joiners and and I think a 1/4 sq spruce joiner is nicer if glued properly. ( needs bigger hole in rudder though and doesnt suit all designs) It might be too late now but I find it easier to fit the joiner ( either wire or spruce ) when the elevator balsa is still in one piece, then cut the V shape out when glue has dried. Edited By kc on 22/12/2020 17:26:38 Quote Link to comment Share on other sites More sharing options...
james brough Posted December 22, 2020 Share Posted December 22, 2020 hi kc thanks for that have just looked again at the plan and found the info good idea of yous to use as well though thanks a lot regards jim Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 22, 2020 Share Posted December 22, 2020 Yes. 14 SWG elevator joiner. I just fill the hole with glue. Neverc had one come loose. Quote Link to comment Share on other sites More sharing options...
james brough Posted December 22, 2020 Share Posted December 22, 2020 hi thank you peter i shall get there in the end I HOPE regards jim Quote Link to comment Share on other sites More sharing options...
Nigel R Posted December 23, 2020 Share Posted December 23, 2020 I'm with kc, I like spruce too join elevator halves. Makes a good control horn mount too. Actually my new favourite is a sandwich of 1/16 ply with hard balsa in the centre. 2 or 2.5mm piano wire will work perfectly well. Get a decent length prong going in to the elevator. And yes accurate holes are a must. Epoxy to fix the wire in place . Edited By Nigel R on 23/12/2020 07:13:13 Quote Link to comment Share on other sites More sharing options...
james brough Posted February 4, 2021 Share Posted February 4, 2021 hi its me again i am building the wings for ps2 at the moment but can only build one at time how far do i have to buid them before i join them together to complete them regards jim Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 4, 2021 Share Posted February 4, 2021 Build one completely. Build thye second up to skinning the toppof the leading edge. Join with the second root rim and then complete the sheeting. I hope that is clear. Because there is no dihedral you will find it much simpler as the whole thing can be kept flat on the board.The completed wing only needs to be on far enough tobe stable Picutres here https://www.modelflying.co.uk/forums/postings.asp?th=129216 Edited By Peter Miller on 04/02/2021 16:47:16 Quote Link to comment Share on other sites More sharing options...
james brough Posted February 4, 2021 Share Posted February 4, 2021 thank for that info peter its more clear in my head now with those pictures on the model flying site regards jim Quote Link to comment Share on other sites More sharing options...
