Peter Miller Posted February 4, 2021 Share Posted February 4, 2021 Further on there is a full sequence of wing building photos Quote Link to comment Share on other sites More sharing options...
Glenn Ryan Posted February 11, 2021 Share Posted February 11, 2021 Hello Peter. It appears that your build thread has disappeared. Do you know what happened to it? Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted February 11, 2021 Share Posted February 11, 2021 Here? Quote Link to comment Share on other sites More sharing options...
james brough Posted February 14, 2021 Share Posted February 14, 2021 hi folks when you fit the front leading edge strip does it follow the edge of the tip or does it sit on top of the tip and do taper it before you soak the end of the full strip regards jim Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted February 14, 2021 Share Posted February 14, 2021 (edited) Leading edge strips finish at the ‘notch’ in the tip and on mine are on the centre line of the tip. They blend in to the strips that are fitted to the outer edge of the tips and I sanded mine after I had soaked, bent and glued. This may help Edited February 14, 2021 by Ron Gray Quote Link to comment Share on other sites More sharing options...
james brough Posted February 14, 2021 Share Posted February 14, 2021 thankyou very much ron Quote Link to comment Share on other sites More sharing options...
