Ray Wood 4 Posted January 26, 2020 Share Posted January 26, 2020 Hi All, I thought it would be good to start a proper scale model build after 6 years of model boat building for a change, I have finished & flown Brian's small Harvard 68" and started a couple of others now in the loft Mossie & ME 109. But thought the Valiant with it's fixed undercart could be a good scale hack, so here goes...... It won't be a quick build as I'm normally building 3-4 other projects at the same time 😀 here is the front inner section of the fuselage, trying to keep it light. Regards Ray Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted January 26, 2020 Share Posted January 26, 2020 Will keep tabs on your build, always liked the Valiant............ Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted January 27, 2020 Author Share Posted January 27, 2020 Hi all, Front bulkhead in place with a brand new ASP90FS in place, should do the the job ok 😀 Regards Ray Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted January 30, 2020 Author Share Posted January 30, 2020 Hi all, Slowly making progress, and thought it would be a good idea to take some of the 1/4" sheet out behind the c of g to reduce the nose ballast required , so away with my Gaskin hole cutter we go 😀 Regards Ray Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted January 31, 2020 Author Share Posted January 31, 2020 Hi all, Big step forward with the rear fuselage sides glued to the front assembly, inverted over the drawing to get it straight. Coming up soon lots of bulkheads to cut & fit and the start of the planking 😀I Regards Ray Quote Link to comment Share on other sites More sharing options...
Martian Posted January 31, 2020 Share Posted January 31, 2020 Looking lovely so far Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted January 31, 2020 Author Share Posted January 31, 2020 Thanks Martian, Early days yet, £100 of balsa turned up from SLEC today, great service 2 days from me phoning the order over 😀 Regards Ray Quote Link to comment Share on other sites More sharing options...
Martian Posted January 31, 2020 Share Posted January 31, 2020 Which variant is this one are you going to use a dummy PW engine ? Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted January 31, 2020 Author Share Posted January 31, 2020 Not to sure which variant i' m building yet just following the drawing at present, it would be nice to fill the cowl with a dummy P&W radial 😀 Quote Link to comment Share on other sites More sharing options...
Gary Clark 1 Posted February 1, 2020 Share Posted February 1, 2020 Looking forward to following along Ray, I've always been a big fan of Brian Taylor. A 3d printed radial is simple, cheap and looks great for very little effort Gary Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted February 1, 2020 Author Share Posted February 1, 2020 Hi Gary, When I get further I will be very interested to commission a printed engine, who would you recommend? Regards Ray Quote Link to comment Share on other sites More sharing options...
Gary Clark 1 Posted February 1, 2020 Share Posted February 1, 2020 Hi Ray I can print one for you. That's why I got the printer in the first place, great for exhaust stacks, engines, pilots, cockpits, everything really! Just let me know what size youd like and I can sort you out with something. Gary Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted February 1, 2020 Author Share Posted February 1, 2020 Thanks Gary That is a kind offer I will take you up on 😀 I make a living with a computer, so any connection with my hobby is a no no ! Balsa bashing has been a life long passion 😀 happy days! Rear lower formers in position now, with lots lightness added Regards Ray Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted February 8, 2020 Author Share Posted February 8, 2020 Hi all, On with the tank access hatch and cockpit and rear formers, planking next 😀 Regards Ray Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted February 15, 2020 Author Share Posted February 15, 2020 Hi All, As Dennis is howling outside what better evening to start planking the fuselage 😀 with 1/8th x 3/8" strips cut from 4" sheet with my 36" steel rule, best investment ever. regards Ray Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted February 18, 2020 Author Share Posted February 18, 2020 Hi All, With such a large canopy this fuselage doesn't need that much planking, with a bit of work with the razor plane & Permagrit sanding block it will be less like a thrupenny bit 😀 Regards Ray Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 18, 2020 Share Posted February 18, 2020 Looking good Ray. Quote Link to comment Share on other sites More sharing options...
maurice northcott Posted February 19, 2020 Share Posted February 19, 2020 Great work Ray. Nice to see another of Brian's designs being built. Keep at it Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted February 19, 2020 Author Share Posted February 19, 2020 Thanks Guys, I find the balsa is a very therapeutic medium Here's my 68" BT Harvard way back in 1996. Picture of an old photo! Regards Ray Quote Link to comment Share on other sites More sharing options...
maurice northcott Posted February 19, 2020 Share Posted February 19, 2020 Nice looking Harvard Ray. Yep the old balsa bashing can be therapeutic when it goes right... Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted February 20, 2020 Author Share Posted February 20, 2020 Hi All, Managed some more planks tonight, before my wife and I watch Live Island together 😀 the things we have to do to stay married (43 years) so it must be working !! Regards Ray Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted February 20, 2020 Share Posted February 20, 2020 Looks great Ray well done Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted February 21, 2020 Author Share Posted February 21, 2020 Thanks Danny, I have admired the detail you go to with your projects, I hope I don't get too carried away with this one, these maybe famous last words I will have to order the cowl & canopy soon. Regards Ray Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted March 1, 2020 Author Share Posted March 1, 2020 Hi all, The fuselage top planked, I will need to build the tailplane now so the elevator, tail wheel linkages can be installed in situ before the bottom planking is finished off. Great building weather lately & received my operators number from the bmfa 😀 so I can carry on doing what I've been doing for 50 years 😉 Regards Ray Quote Link to comment Share on other sites More sharing options...
Ray Wood 4 Posted March 13, 2020 Author Share Posted March 13, 2020 Hi All, For anybody new to the Brian Taylor tailplane building method of 2 separate halves built flat on the building board, this is the first half of the " vibrator's" tailplane, which was the Valiant's Nick name from those who flew them 😀 Regards Ray Quote Link to comment Share on other sites More sharing options...
