Binding ikonnic red to aurora 9
Jonathan Young
You beat me to it
This is from the Instructions
Pairing
Place the transmitter and receiver within 2m of each other (but not less than
45cm) then power the transmitter ON.
45cm (18" to
200cm (78" apart
Power the receiver ON noting that the LED will initially flash red / blue, then
change to fast flashing red. For initial pairing the receiver must be powered
on within 5 seconds of the transmitter. Once paired this time constraint is no
longer necessary.
Edited By Denis Watkins on 29/01/2020 17:52:39
It can be done. As extra slim says you have to bind to Aurora 9 with blue flashing LED on TX module, hold down bind button on Rx and with your third hand switch on Rx power. Fidley but it works. If you check with Hirec instruction it shows the procedure, just bind as Minima Rx.
Phil.
