Jonathan Young Posted January 29, 2020 Share Posted January 29, 2020 Hi there can anyone help I've baught an ikonnic red reciever that is supposed to be compatible with my aurora9 but I cant for the life of me bind them . Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted January 29, 2020 Share Posted January 29, 2020 Have you read the instructions for the Iconic Red Transmitter, they are on the Airtek hobbies website.? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 29, 2020 Share Posted January 29, 2020 You beat me to it This is from the Instructions Pairing Place the transmitter and receiver within 2m of each other (but not less than 45cm) then power the transmitter ON. 45cm (18" to 200cm (78" apart Power the receiver ON noting that the LED will initially flash red / blue, then change to fast flashing red. For initial pairing the receiver must be powered on within 5 seconds of the transmitter. Once paired this time constraint is no longer necessary. Edited By Denis Watkins on 29/01/2020 17:52:39 Quote Link to comment Share on other sites More sharing options...
Jonathan Young Posted January 29, 2020 Author Share Posted January 29, 2020 I've tried following the ikonic instructions but still cant get it to bind.. Quote Link to comment Share on other sites More sharing options...
extra slim Posted January 29, 2020 Share Posted January 29, 2020 Put your tx into blue flashing as opposed to red, same as when binding a minima rx.. try that.. hold down button on back of tx module for 5 sec then release if I remember Quote Link to comment Share on other sites More sharing options...
Outrunner Posted January 29, 2020 Share Posted January 29, 2020 It can be done. As extra slim says you have to bind to Aurora 9 with blue flashing LED on TX module, hold down bind button on Rx and with your third hand switch on Rx power. Fidley but it works. If you check with Hirec instruction it shows the procedure, just bind as Minima Rx. Phil. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted January 29, 2020 Share Posted January 29, 2020 I have the instructions for it. I have several Ikonic rx's.. Edited By Paul Marsh on 29/01/2020 20:40:00 Quote Link to comment Share on other sites More sharing options...
Jonathan Young Posted January 30, 2020 Author Share Posted January 30, 2020 Thanks guys I got it to bind now I have another problem I've changed the transmitter to mode 1 and now I have a sloppy off centre stick any ideas? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 30, 2020 Share Posted January 30, 2020 Stick ratchet adjustment, Page 26 of manual Jonathan, very easy to do Quote Link to comment Share on other sites More sharing options...
Jonathan Young Posted January 30, 2020 Author Share Posted January 30, 2020 It's not the throttle stick it's the rudder and elevator .. the elevator is off centre and sloppy sloppy on centre stick... Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 30, 2020 Share Posted January 30, 2020 Screws in holes on the back, under rubber covers, small screwdriver alters tension Read page 25, and look at 26 Quote Link to comment Share on other sites More sharing options...
