Charging Nimhs
If anything, Nimhs are light duty anyway, and if you look at their leads, they are not high discharge.
If 1 cell is starting to drop now, maybe the lower voltage of the pack is triggering full ok momentarily
Then with being boosted, then the charger believes that it can carry on, am guessing
I do know a failing cell does mess up charging
Is it All your Nihm packs do this?
John, it sounds like you are describing a "false peak" detection. The only way to overcome this is to increase the charge current. I always use manual select charge rate, never the auto select charge but normally I use a limit of 1A charge for Tx & Rx nimhs which seems to work well even with quite high (2000 maH) batteries & doesn't cause the leads to heat up.
i find 400mah a good all round charging figger for nimh packs for Rx and TX's.
When i have had false peak detect charging problems on two ocaisions it was a bad switch, another time a poor connector (all having slightly higher impedance than a good version
and you also get problems when you have a doggy cell in the pack which has happened to me only with new or just about new packs.
if you can get to each cell and test voltage if you have a doggy cell it will have a lower voltage than the others after a little use. To get at the ends of each battery without ripping the nice shring wrap I use small pins to pock through the insulation tto make contact with the terminals.
Only last weekend a new member lost his trainer due to one cell failing and the anoying thing about it he was on finals and litery only needed 2/3 seconds of power and all would have been goodsad (battery was checked on first flight and this was the second short flight)
Posted by PatMc on 31/01/2020 16:46:22:
What charger are you using ? Does it have a separate setting for nicads & nimhs ?
BTW if the flight batteries are AA cells then 2500 mAH is probably a too high capacity for reliability in models using more than 2 or 3 servos.
HK Quatro Pat.
Don't follow your second part ?
Posted by john stones 1 on 31/01/2020 16:57:02:
HK Quatro Pat.
Is there a charge setting option for nicads as well as one for nimhs ?
Actually Steve's question covers the same point I was getting at.
Edited By PatMc on 31/01/2020 17:17:55
