Christopher Morris 2 Posted April 19, 2020 Share Posted April 19, 2020 Hi, picked up a cheap secondhand Ranger 2000 foamy & the recommended motor is a 2215 1400KV. I have a spare 2814/ 1400kv Will this be ok & would it be more powerfully or too powerfully. Would be nice if there was a comparison chart about that was simple to see this sort of thing. Thanks Quote Link to comment Share on other sites More sharing options...
Dickw Posted April 19, 2020 Share Posted April 19, 2020 In simple terms, the power output of a motor is decided by the kv, the prop size, and the battery used, so for the same battery and prop the two motors would have similar power outputs as they are the same kv. The two motors may well be very different in weight so getting the CG right could be your biggest problem. Do you have brand names for the recommended motor and the one you have? if so it should be easy to check weights online. Dick Quote Link to comment Share on other sites More sharing options...
flight1 Posted April 19, 2020 Share Posted April 19, 2020 The first thing to check is will the motor fit as they are two different sizes/ weight , also the prop required on the 2814 might be to big to fit as your plane is a pusher type propulsion. need full spec of motor to work out # Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted April 19, 2020 Share Posted April 19, 2020 Usually 2215 is 22mm diameter by 15mm long and 2214 will be 22mm diameter and 14mm long it is showing the same 1400 KV rating as revs per volts so it may be that little bit lighter but give same power output. As mentioned above the weight will have influence on c of g and possible mounting fixtures. Maker of motors would be big help to trace down on google Quote Link to comment Share on other sites More sharing options...
Christopher Morris 2 Posted April 19, 2020 Author Share Posted April 19, 2020 Hi Dickw. Thanks for getting back. Oh! thanks everyone. The motor that would of come with it is a Volantex 2216 1400KV Brushless The motor i have is a RoHS Racestar BR2814-1400kv. using a 8x4 pusher prop I found spec on the racestar i want to use, but not the Volantex. 8" would be the largest prop i could use being a pusher type plane. & all will fit ok. Motor & prop. Model KV (rpm/V) Voltage (V) Prop Load Current (A) Pull (g) Power (W) Efficiency (g/W) BR2814 1400 11.1 9x6 47.5 1950 522 3.7 14.8 8x5 58.0 2300 858 2.7 Edited By Christopher Morris 2 on 19/04/2020 11:57:44 Edited By Christopher Morris 2 on 19/04/2020 11:58:47 Quote Link to comment Share on other sites More sharing options...
PatMc Posted April 19, 2020 Share Posted April 19, 2020 Re the power - I agree with Dick, since the motors are both the same KV using the same size prop & battery should give the same power. Albeit the heavier motor will have more potential power if a larger prop or higher voltage battery were to be used perhaps in a different model. The position of the motor on the Ranger makes it's weight less critical than it would be with most other models regarding the cg. I'm using a 1400 KV motor on 3s lipo with a Graupner 8x4.5 folder on a "warm liner" glider. Current = 20A ; power = 200W ; RPM = 12500 - that's equivalent to a decent 15 ic engine. Advantage of a folding prop on the Ranger would be reduced drag on the glide. Quote Link to comment Share on other sites More sharing options...
Dickw Posted April 19, 2020 Share Posted April 19, 2020 The 2814 does appear to be bigger and an ounce ot two heavier than the 2216, but if it fits and you can accept the weight it should be OK. Dick Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted April 19, 2020 Share Posted April 19, 2020 I personally doubt the Volantex 2216 1400kv motor is 22mm in diameter, more likely 28mm dia. (27.7mm, if one is being picky). Many 22xx motors are infact 28mm dia. sometimes the '22' can refer to the length of the magnets? So I would gues it is likely to be very similar to the motor you have Christopher although the Volantex motor may be a little longer. In any event as others have said, the kv is the same so if you fit your chosen prop (8x5in?) and connect it to a Watt meter and you get around 200W+, you are in the right ball park hopefullly. Just check the mounting holes are the correct spacing for the model mount - normally 16mm or 19mm on a 28mm dia. motor. If you don't have a Watt Meter do get one as you will find it very useful. Good luck. ps. what battery are you planning to use? Edited By Piers Bowlan on 19/04/2020 14:28:42 Quote Link to comment Share on other sites More sharing options...
Christopher Morris 2 Posted April 19, 2020 Author Share Posted April 19, 2020 Thanks everyone. Will do some do some testing on the 3 cells in the next day or so & i have a watt meter & i am hoping to get a pair of pull weighing scales in the post tomorrow to see what sort of pull it has as well. Will try not to pull the tail off, lol. Quote Link to comment Share on other sites More sharing options...
Christopher Morris 2 Posted April 19, 2020 Author Share Posted April 19, 2020 Just a PS: Piers, you was spot on with the wattage estimate. Went up to 209 watts & stabled out at 203 watts on full power & that was with a battery not fully charged. Thanks again. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 19, 2020 Share Posted April 19, 2020 This chart was on the side of my motor box This confirms that motor will push your Model along, hope it helps Quote Link to comment Share on other sites More sharing options...
Christopher Morris 2 Posted April 19, 2020 Author Share Posted April 19, 2020 Ah, thats handy. Thanks Denis. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted April 20, 2020 Share Posted April 20, 2020 For any other e-glider pilots out there here is a review of the Volantex Ranger 2000. The kit looks pretty good to me. Edited By Piers Bowlan on 20/04/2020 10:47:18 Quote Link to comment Share on other sites More sharing options...
