Dad_flyer Posted May 24, 2020 Share Posted May 24, 2020 I have one of these joined 4mm bullet connectors (this one is a 4-max variety) to make a charge lead for a plane Child_flyer got at a swap meet. I can't get the connectors to push into the shroud. Has anyone got a method to get them in? Quote Link to comment Share on other sites More sharing options...
Jeffrey Cottrell 2 Posted May 24, 2020 Share Posted May 24, 2020 Hi Dad_flyer. First thing to check is the shroud is not a 3.5mm one, same as come supplied with brushless motors. 1/2mm difference is not easy to spot. Front (non-fluted) part of the plug will go in but that's all. If your shroud is definitely 4mm then try compressing the flutes very gently with a pair of pliers. Too easy to compress too much and end up with a loose fit, so gently does it. As an aside, I get my plugs from Blacksmith products, here. Note they actually do two varieties. C0403 is 20.4mm in length, but C0401 is only 14.9mm. Handy if you need a shorter connector for tight instals. Cheers Jeff Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted May 24, 2020 Author Share Posted May 24, 2020 Thank you Jeff. My question would have made more sense to everyone if I had put in the picture as I meant to. It is fitting the metal pieces to the plastic shroud that is the problem. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 24, 2020 Share Posted May 24, 2020 Shroud goes on tube before the bullets are soldered on ? Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 24, 2020 Share Posted May 24, 2020 I know this is not the solution to that connector problem, but I use XT 60's on everything. Makes life easier. They look like they pull back thru the shroud. that is to say do you slide the shroud over the wires first maybe ? D.D. Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted May 24, 2020 Author Share Posted May 24, 2020 Yes, that would work I think. Thanks DD, time to unsolder. I do use XT60s on everything else, but this model came with batteries and everything wired up, so I thought I would leave it and just make a charging cable. Edit: thanks John too, I had mis-read your post and thought it was different. Edited By Dad_flyer on 24/05/2020 21:44:21 Edited By Dad_flyer on 24/05/2020 21:45:59 Edited By Dad_flyer on 24/05/2020 22:04:30 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 24, 2020 Share Posted May 24, 2020 It's o.k, my pleasure. Quote Link to comment Share on other sites More sharing options...
Robert Welford Posted May 24, 2020 Share Posted May 24, 2020 I have had the same problem. I found heating plastic shroud with heat gun allows 4mm plug/socket to be pushed home. Don't over do it with heat gun! Quote Link to comment Share on other sites More sharing options...
PeterF Posted May 24, 2020 Share Posted May 24, 2020 I have found heating the plastic a bit to soften it helps and to push them in using a thin screwdriver onto the back of the bullet where the cable is soldered in. There is an internal lip in the plastic housing that goes into the recess in the bullet connector, when the plastic is cold it is a tight fit. But be careful not to get them too hot, use a mug of warm water, not a hot air gun, experience shows a hot air gun is too hot. I used these a lot for a number of years until I found that they are unsafe as you can connect 2 batteries together by accident as they are not gendered pairs. I now use XT90s. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 24, 2020 Share Posted May 24, 2020 LOL. Sorry John. D.D. Edited By Dwain Dibley. on 24/05/2020 21:54:12 Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted May 24, 2020 Author Share Posted May 24, 2020 Using the suggestion from John S (and DD ) they go in easily. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 24, 2020 Share Posted May 24, 2020 I felt left out. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 24, 2020 Share Posted May 24, 2020 Sort of thing I do a lot, plenty oops moments when I do stuff. Quote Link to comment Share on other sites More sharing options...
Jeffrey Cottrell 2 Posted May 24, 2020 Share Posted May 24, 2020 Hi DF Sorry, I misread what you were trying to do. Other posters are correct, wire goes through the housing first, then solder plugs on. Word of warning. The plugs are a very tight fit in the housing. Using the wire to pull them back risks damaging the solder joint. What you do is to slide the plug in as far as it will go, then find a loose plug of the opposite gender and slide it onto the plug in the housing, so that the extra plug extends beyond the plastic. Then press the plug down on a hard surface until it snaps into place. Slide off the extra plug and Bob's your proverbial. Make sure you have all your connections right before you do this. once in the plug will NOT come out. Only way to remove it will be to cut the housing apart. Good luck Jeff Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted May 24, 2020 Author Share Posted May 24, 2020 Posted by Jeffrey Cottrell 2 on 24/05/2020 22:38:00: Hi DF Sorry, I misread what you were trying to do. My fault, without the picture my question made no sense. I did exactly as you said with some spare connectors. A firm push and in they go. Quote Link to comment Share on other sites More sharing options...
Jeffrey Cottrell 2 Posted May 24, 2020 Share Posted May 24, 2020 Hi DF Picture is worth a thousand words. This explains far better than my purple prose. Jeff Quote Link to comment Share on other sites More sharing options...
