Simon Chaddock Posted November 5, 2023 Share Posted November 5, 2023 I did add a 😉 concerning the gyro. On the other hand I am not keen on white knuckle rides so when I maiden an own design with un proven aerodynamics I do fit a gyro but in rate mode so no positive stabilisation. Hopefully this slows down the plane reactions enough for my 'old age' eye/hand coordination to keep up. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted November 5, 2023 Share Posted November 5, 2023 1 minute ago, Simon Chaddock said: I did add a 😉 concerning the gyro. On the other hand I am not keen on white knuckle rides so when I maiden an own design with un proven aerodynamics I do fit a gyro but in rate mode so no positive stabilisation. Hopefully this slows down the plane reactions enough for my 'old age' eye/hand coordination to keep up. First time I enabled a gyro in flight, the model went crazy. Memo to self, ensure gyro moves control surfaces in the right direction before flight! Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted November 5, 2023 Author Share Posted November 5, 2023 (edited) Hopefully this next week I can get the remaining work done and then get a final weight and assess the power setup properly, i am hoping to run on 3 cell lipo but there is space for 4 cell if required but the model has not been on the scales yet and the CG may need a little assistance in the nose as I want to be slightly forward of the mathematical position at least for the first flights. Hopefully we can be in excess of 125 watts per pound with a 11-12 inch prop. I have a 710watt 900kv sat on the shelf ready pending final weight checks, i am hoping just over half that would be enough. Linds Edited November 5, 2023 by Lindsay Todd 1 Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted November 25, 2023 Author Share Posted November 25, 2023 Ideal day for a test flight all complete checked and ready, final motor configuration updated to an Overlander thumper 900kv throwing a 14x6 prop at just under 400 watts and an all up weight of just on 4lb. An hours trip down to my test flight site, and a further check over and all the static shots done. with no more excuses left i lined up for the first flight, good acceleration, V tail rudder working fine, up to flying speed and eased back on the elevator As the model rotated it was clear something was wrong with the ailerons so with an inch or two off the ground i chopped the power. On inspection the left hand aileron servo had stripped its gears and explained the sudden loss of feel, any further and it could have been far more serious but so frustrating as from the photo above it was so nearly there but we can't yet claim a successful first flight. On the plus side, I was able to satisfy myself re power, rudder and elevator authority. it will be a couple of weeks now before i get another chance but this is what test flights are all about and just grateful the brain was able to react so fast to something having happened so suddenly. The servos were a couple of mini Hitec mini nylon gear items, I will upgrade both i think even though the load has not been the route cause, might have got knocked in transit and the cold will not have helped I guess. Linds 2 Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted November 27, 2023 Share Posted November 27, 2023 Well done Linds,shame about the servo. You can almost taste it! Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted June 2 Author Share Posted June 2 Not the best image as it had some rubbish behind which had to be edited out but finally got airborne having waited since last November, a couple of trims and a bit more exponential on aileron but not to bad a test flight. Need a better day, brighter sky and can get some proper pics done. Linds 2 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted June 2 Share Posted June 2 Well done, video would be nice Linds. 😉 Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted June 2 Share Posted June 2 Impressive A very good example of "with enough power fancy aerodynamics are not required" Quote Link to comment Share on other sites More sharing options...
