Piers Bowlan Posted November 22, 2020 Share Posted November 22, 2020 Chaps, I bought this engine second hand some years ago and it was stored well oiled in a dry environment, However the throttle barrel has seized (caster oil lacquer I think) so I thought I better seek advice before messing with it. The throttle arm is plastic and easily removed. What is the next step? Sorry to ask a silly question but apart soaking the carb in glow fuel (or meths?), what should I do next as I don't want to damage it? Any advice is much appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted November 22, 2020 Share Posted November 22, 2020 Gentle heat normally does the trick. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted November 22, 2020 Author Share Posted November 22, 2020 Thanks Martin, would you heat it in situ or remove the carb from the engine or is that a bad idea as it might damage the seal beneath the carb. There a couple of screws holding it in place. Also would it help to remove the spray bar or would that make no difference? Edited By Piers Bowlan on 22/11/2020 17:31:07 Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted November 22, 2020 Share Posted November 22, 2020 Simply put it in a pan of water with some Flash or Tesco hard surface cleaner and simmer for a while. The crankcase may discolour a little. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted November 22, 2020 Author Share Posted November 22, 2020 OK, thanks Martin, I'll try that. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted November 22, 2020 Share Posted November 22, 2020 You could pop the whole thing in the oven at 100 degrees while the missus is snoozing after Sunday dinner - not hot enough to damage anything but should soften the castor. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted November 22, 2020 Author Share Posted November 22, 2020 Thanks Martin, I will let you know how that works out. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted November 23, 2020 Share Posted November 23, 2020 hello piers,have a go with your heat gun or her indoors hair dryer, after a coupe of mins it will free it....do be gentle with the arm until its happy.....I had an OS 46 in the box,exactly the same... ken anderson...ne..1....arm dept. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted November 23, 2020 Author Share Posted November 23, 2020 Much appreciated Ken. I have removed the carb and currently soaking in glow fuel for several hours before trying gentle persuasion . I have removed the plastic throttle arm and fitted a strip of aluminium instead to try and work the throttle barrel lose - more leverage. I will try a heat gun (when it has dried out ) plus a few choice words, not repeatable on this forum! Quote Link to comment Share on other sites More sharing options...
Richard Acland Posted November 23, 2020 Share Posted November 23, 2020 I had the same problem with an OS 40 FSR bought on e bay. I didn't want to use heat as the idle control has a rubber "o" ring. I soaked it in a container of glow fuel for 48 hours and it did the trick. Quote Link to comment Share on other sites More sharing options...
Robert Welford Posted November 23, 2020 Share Posted November 23, 2020 I have found carb barrels on other OS engines seize after quite a short period of none use. Soaking in fuel and lubricating before layup is the answer. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted November 23, 2020 Author Share Posted November 23, 2020 Thanks Richard and Robert. I have been marinating my carb in fuel all day, so I will take another look at it tomorrow. This is where an ultrasonic cleaning bath would come in handy. I don't think Santa will bring me one this Christmas. Quote Link to comment Share on other sites More sharing options...
Petrol Pete Posted November 23, 2020 Share Posted November 23, 2020 hi i did one yesterday on a os 26 four stroke, i replaced the plastic throttle arm, with a nut and bolt and soaked it in wd40 gentle pressure after a bit of soaking and it started to move, cleaned it up and then lubed it with after run oil all good Pete Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted November 24, 2020 Author Share Posted November 24, 2020 Success! Thank you all for your suggestions. I must admit that like Richard I was a little wary about applying heat for fear of damaging the rubber (or whatever) seals, although I know many of you heat the engines to good effect. Thanks too to Jon (of Laser Engines fame) whom I contacted and he also suggested I remove the throttle stop screw. After a good soaking in fuel I was then able to turn the barrel clockwise, past fully closed. Turning it anti-clockwise just undid the temporary ali throttle arm that I had fitted. Now back together and oiled the engine is waiting a test run after umpteen years. Quote Link to comment Share on other sites More sharing options...
