Colin Leighfield Posted March 12, 2021 Author Share Posted March 12, 2021 The fuselage top decking is complete now, awaiting sanding and the cutting out of the cockpit aperture. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 14, 2021 Author Share Posted March 14, 2021 I’ve been able to do some work on this every day and it’s coming along nicely now. Cockpit is cut out. I’m leaving all final sanding until it’s ready for covering. I have to do some alterations on the fibre-glass cowling to reflect the differences with the Hispano engine in the Spanish planes, but first I wanted to sort out the mounting clips and ensure that it lined up with the propeller shaft. Despite trying to be careful with this during the build, it doesn’t! Next step will be to raise the motor slightly to do this, without changing the thrust-line. Not too difficult. Then I will alter the cowling with the longer cam-box bulges etc, quite easy. Following that will be the radiator, which is quite different to the Kestrel engined planes, then the undercarriage fairings. Getting excited about this now. 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted March 14, 2021 Share Posted March 14, 2021 Looking really good Colin, soon be getting to covering detail and paint, the best bit ? Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 14, 2021 Author Share Posted March 14, 2021 Thanks Danny. I’m looking forward to air-brushing this. As I’m doing a camouflage paint finish I’ve got no complicated aluminium or litho-plate work to do, also I’m using Solartex. Not too far away now. Having some decent work-space makes life so much easier as well. 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted March 14, 2021 Share Posted March 14, 2021 I am looking forward to seeing how it goes. You are right the litho/foil finish was a bit of a pain, but worth it. Yes the new workshop looks just the ticket! I have been messing with Ceconite, which is like a porous, non adhesive Solartex. Thinner and lighter, but a bit more faff, but if like me you love tissue and dope this ticks the same boxes. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 15, 2021 Author Share Posted March 15, 2021 If I remember rightly, Ceconite has been around for a while as a full-size covering material? In this case I’ve got more than enough Solartex to do the Fury and I want to get it finished now. I bought some nylon for this project, but I’ll use that for something else now. One of the problems that lead me to park the Chipmunk was warping of the ailerons using silk, tissue and dope, among other self-induced mishaps! One day I’ll take a deep breath and have another go with it. There’s a lovely un-run OS62FV in that, mustn’t waste it. 1 Quote Link to comment Share on other sites More sharing options...
David P Williams Posted March 15, 2021 Share Posted March 15, 2021 Looking good Colin. Makes a big difference having the right space to work in doesn't it? 1 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 17, 2021 Author Share Posted March 17, 2021 The longer valve gear cover blisters associated with the Hispano engine are taking shape, using blue foam. 1 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 19, 2021 Author Share Posted March 19, 2021 I’ve cut out the exhaust holes, which are different to those on the Kestrel planes. As the Hispano Suiza engine is a similar V-12 to the Rolls Royce engines, I think the most likely explanation for the odd looking exhaust arrangement must be that the manifolds on cylinders 2+3 and 4+5 in both banks are siamesed in pairs, I don’t know why. I’m quite pleased with this so far. The only remaining job on the cowl is to fit the small air intake in the chin position on the underside, which only exists on the Hispano Suiza version. Although not large, it is ideally positioned to push air in and around the motor, to vent through the exhaust holes. 2 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 20, 2021 Author Share Posted March 20, 2021 The drawings that I have show some of the Spanish Fury detail. They show a flatter line along the top of the cowling blisters than I’ve deduced from other pictures, it’s easy to sand the blue foam to a flatter profile, I’ll think about whether I want to. The under-nose air intake is also clear. One of the fibre-glass off-cuts from the blisters I’ve altered is co-incidentally spot-on for that, when that’s done (today) the cowl is finished. 1 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 20, 2021 Author Share Posted March 20, 2021 I’m pleased with this, the differences to a standard Kestrel Fury are apparent here. I’m working on the underside of the lower wing centre section and radiator now. I want to see if I can use air from that route over the ESC and let it out through the cockpit. 3 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 21, 2021 Share Posted March 21, 2021 You should be pleased Colin, It's an amazing build so far. D.D. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 21, 2021 Author Share Posted March 21, 2021 Thank you Dwain. I don’t think it matches the build standards of some of the others, but hopefully it will turn out ok and represent a version of the Fury that we don’t normally see. 1 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 24, 2021 Author Share Posted March 24, 2021 The radiator cowl is different to that on the Kestrel planes, more like that on the Hurricane. I thought about carving it in one piece from blue foam, but decided to build it up like this. 2 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 26, 2021 Author Share Posted March 26, 2021 I’ve put a couple of hours into this every day this week and it’s nearly done. I want it be accurate as I reasonably can. I’m not averse to using lightweight filler here and there, it will be ok when finished. 2 Quote Link to comment Share on other sites More sharing options...
Andy Shailer Posted March 26, 2021 Share Posted March 26, 2021 Hi Colin, amazing build, looks fantastic, looking forward to seeing it covered. Andy 1 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 26, 2021 Author Share Posted March 26, 2021 Thank you Andy. It's getting there. Quote Link to comment Share on other sites More sharing options...
Andy Shailer Posted March 26, 2021 Share Posted March 26, 2021 Only just found your thread Colin, so will be following it now, lovely work. 1 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 26, 2021 Author Share Posted March 26, 2021 Andy, this one is late in the Fury builds, there are some already finished that are more skilfully created than mine. Have a look at those as well. The differences with this one are the changes made to represent the version used in the Spanish Civil War, on both sides. These are mostly apparent in the engine cowling because of the Hispano Suiza engine used instead of the Kestrel and the undercarriage, similar to that on the Gloster Gladiator with Dowty sprung wheels. Also there are some interesting paint schemes that will give me a chance to improve my air-brushing! 1 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 27, 2021 Author Share Posted March 27, 2021 The radiator is finished now and I’m satisfied with it. Scratching my head about how to find a suitable mesh to put inside it for realism and to avoid a gaping hole, I found stainless rodent mesh on Amazon, 16 LPIx1.19mm hole x 0.4mm stainless steel wire 210x150mm for £2.99. That looks handy so I've ordered 3, enough to do the job and leave some stock. It should arrive some time next week, so while waiting for that to arrive I’ll get on with the undercarriage fairings. They’re quite tricky. Because I’ve had to create a narrow cantilever undercarriage to visually replicate the Dowty sprung wheel arrangement, all of the fore and aft movement is concentrated at the point where the leg joins the fuselage. The shock load is absorbed by the cast rubber box I’ve epoxied into the fuselage. That means that the leg fairing has to have enough space inside it to allow for the limited movement. That’s going to be interesting. 2 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted March 27, 2021 Share Posted March 27, 2021 I thought Eric had provided the STL file from my Fury? Give him a shout ? Cheers Danny Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 27, 2021 Author Share Posted March 27, 2021 Thanks Danny, Eric had very kindly got in touch via Messenger. The radiator shape is quite different, as I’ve already ordered the fine mesh I’ll use that when it comes. It should be easy to cut to shape. 1 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted March 29, 2021 Author Share Posted March 29, 2021 The trickiest part of converting to the Spanish version of the Fury is the undercarriage. Because the low drag was achieved by using a rigid cantilever leg, with all springing and damping provided by the clever Dowty sprung wheel, it’s hard to replicate. The perfect solution is a sprung wheel and that’s not an impossibility, but I don’t have the engineering skills to make that. The leg is too slim to accept an oleo and it’s not a practical solution. Therefore the compromise solution was to make a rigid leg from lengths of 8swg wire, triangulated and soldered. At the front the cross-member is hinged to the bulkhead in the same way as on the original Bryant design. The vertical shock absorption is limited, but comes from the very good low-bounce rubber DuBro tyres, which provide 1/2”. There is a little lateral spread but not much and it has to be limited because all bending forces are transmitted through the point where the leg joins the fuselage and the fairing there is a problem. The horizontal shock reaction is transmitted through the rear part of the leg assembly in to the cast rubber box that I have formed inside the fuselage. The difficult bit is getting a reasonable looking fairing at the undercarriage/fuselage join that can accommodate the lateral and rearward movement without splitting. The photos show that I’m working on that now. It won’t be perfect but I hope reasonable. 4 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted April 3, 2021 Author Share Posted April 3, 2021 The undercarriage is nearly finished. In the photo you can see the key differences between the Spanish plane and RAF versions, in the undercarriage, engine cowling detail and radiator. There is also some interesting louvre detail I will have to contrive. It’s impossible to do the sprung wheel detail without having one, but otherwise the undercarriage is reasonably accurate. The Dubro wheels are accurate in diameter and tyre section, but have light spoke outlines moulded in. I’m making conical discs from 1/64” ply to cover these. I did think about making some lighter wheels, using the tyres off the Dubros, but decided against it. The weight is in front of the c of g and they are robust. Coming along nicely. 4 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted April 3, 2021 Author Share Posted April 3, 2021 Here’s a nice photo of one of the Spanish planes, from the BAe web-site, showing clearly the louvre detail I mentioned in the previous post. Quote Link to comment Share on other sites More sharing options...
