Rich Griff Posted June 24, 2021 Author Share Posted June 24, 2021 Oh brill, now goto figure out how to open the files on my internet phone, the lad would help, eventually. Any chance if I pm my email address you could email them ? Over Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted June 24, 2021 Share Posted June 24, 2021 No problem. Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted June 24, 2021 Share Posted June 24, 2021 2 hours ago, Rich Griff said: Would much prefer a " simple" radio set like a new challenger which would do very well for my needs. Hi Rich, Simple non-computer 2.4GHz sets do exist. The Spektrum DX4e and DX5e use dip switches both for servo reversing and to select elevon mixing. The only criticism, in comparison to the Futaba Challenger, is that the dual rate switch doesn't have a potentiometer for adjusting the throw on the reduced setting. No doubt someone will have worked out a way to add this though. Keep an eye on Ebay, you should find a DX4e or DX5e for less that £20 if you are patient. Quote Link to comment Share on other sites More sharing options...
Björn_S Posted January 21 Share Posted January 21 Greetings Futaba challenger fpt6-nl. I'm hoping to resurect one of these units. Feeding 9.6v I noticed one of the RC filter components (sumida m44) gets really hot after 40s, 80° on the 3 unsoldered pins! The tx was drawing 0.2a Is this component replaceable? (Cant Find on Google) Can it even be tuned without scopes & Sig gens? (Or best to buy up a couple of other units and swap out the whole board? Noticed the black wire issue PDQ. Be great to get this running, be so straight forward to run it on 18650 lithium batteries. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted January 21 Share Posted January 21 Hi Bjorn - I’m no radio electronics expert but do you have the aerial (I’m assuming this is a 35MHz set?) connected and extended? Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted January 22 Share Posted January 22 Its worth noting that the early Futaba Challenger was the FPT-6NL and didn't have a buddy box socket, whilst the later one was the FPT-6NFK (or FPT-6NPK) I believe the early ones (6NL) had electronic components with legs through the boards, whilst the later ones 6NFK & 8NPK) were surface mounted. Quote Link to comment Share on other sites More sharing options...
