Re-covering after Solafilm
Tony H
I have same comments  and experience from trying to clean off the pigment as Andy Stephenson. The staining is not much of an issue if the pigment is light such as white or yellow but if red, dark blue or black can be visible certainly if the new covering is light in colour. Sometimes after using thinners I have found a light sanding of the airframe helps.
Try using parcel tape, well burnished onto the remaining shards of de-laminate Solarfilm adhesive -experiment with heat and the angle of pull. Then it's a case of shaving or picking off any recalcitrant bits with a scalpel followed by sanding. I don;t like to use cellulose thinners because it just drives the colour into the wood.
  • 1 month later...
