Alan Gordon 5 Posted September 16, 2021 Share Posted September 16, 2021 Hi Folks, My Aurora 9 has been in storage for approx one year, and I have used it one once before putting it into storage. However I have come to use it again and it simply wont link up the Tx seems ok and does what it is supposed to, but the Rx has no life I am using fully charged batteries and again I am following the instructions but still no go, any ideas on what might be wrong would be gratefully received. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 16, 2021 Share Posted September 16, 2021 hello Alan have the same radio......try binding the RX again and make sure you have a link,as i take it that's what you are saying that it doesn't want to link up.i've found that sometimes you have to do it a couple of times before success...dont have the TX and RX too close together...... ken anderson...ne...1....success dept. Quote Link to comment Share on other sites More sharing options...
Alan Gordon 5 Posted September 16, 2021 Author Share Posted September 16, 2021 Will do Ken thanks It used to bind no problem but will try your suggestion. Ta Quote Link to comment Share on other sites More sharing options...
Andrew Calcutt Posted September 16, 2021 Share Posted September 16, 2021 Have the same radio,the tx battery has gone so flat you have lost the memory,bind it again to rc and you should be ok,might be a good idea to get a new tx battery I use a lipo,you can get them from component shop. Quote Link to comment Share on other sites More sharing options...
Alan Gordon 5 Posted September 16, 2021 Author Share Posted September 16, 2021 Thanks for advice guys, but still no go, I accidently plugged the RX bat into the wrong socket and LED came on Red so that's working ! Looks like a new RX required. Quote Link to comment Share on other sites More sharing options...
Outrunner Posted September 16, 2021 Share Posted September 16, 2021 Alan. Are in the correct bind mode, Minima or Maxima with the corresponding receiver? Quote Link to comment Share on other sites More sharing options...
Alan Gordon 5 Posted September 16, 2021 Author Share Posted September 16, 2021 Thanks Outrunner could you advise further on your suggestion ? Not to sure on Minima / Maxima Quote Link to comment Share on other sites More sharing options...
extra slim Posted September 16, 2021 Share Posted September 16, 2021 There are a couple of binds in play here, your Rx will usually be either optima (black) or minima (usually blue, except the lite),and sometimes maxima but not as common. If it isn’t working as is, hold the bind button on the back of the tx then release, then press it again, for I think a few seconds and the lights will change pattern of flashes, I think from red to blue and red or just blue, can’t remember.Try both types, I think it will work. Tx are usually set for optima OOTB and need the above process to switch to the minima. Good luck Quote Link to comment Share on other sites More sharing options...
Outrunner Posted September 16, 2021 Share Posted September 16, 2021 Hi Alan. If you go to the Hitec Hitec RCD website you can download the receiver instruction sheet showing how to bind correctly. I do find binding Hitec receivers very fidley but work reliably once bound. I always bind mine with the instruction sheet in front of me as I can never remember how to bind them. Quote Link to comment Share on other sites More sharing options...
Alan Gordon 5 Posted September 16, 2021 Author Share Posted September 16, 2021 Again thanks chaps will try again in the morning Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 17, 2021 Share Posted September 17, 2021 Alan, here are the minima instructions,they are a bit of a fiddle.......if your RX is the black one.......... .its a maxima. ken anderson...ne..1...maxima/minima dept. Quote Link to comment Share on other sites More sharing options...
Alan Gordon 5 Posted September 17, 2021 Author Share Posted September 17, 2021 Thanks Ken, Mines is the Maxima, I will keep on trying to get the thing to bind, when I stopped using it approx a year ago it was fine but now there is no life. Quote Link to comment Share on other sites More sharing options...
Outrunner Posted September 17, 2021 Share Posted September 17, 2021 Alan, you have a red light on the receiver so binding should work, they don't usually die just sitting on the shelf. Hopefully you will get it working. Quote Link to comment Share on other sites More sharing options...
extra slim Posted September 17, 2021 Share Posted September 17, 2021 Maxima rx are black with alot of Red. OPTIMA are the "mostly black ones".. When you press the bind button in, what colour lights do you see flash on the tx module?.. If I recall, if you see blue in the flashing, then it is trying on a minima protocol. So press it again for a second, and the light sequence will change, then try again. Please confirm, exactly which rx you are trying Quote Link to comment Share on other sites More sharing options...
Alan Gordon 5 Posted September 17, 2021 Author Share Posted September 17, 2021 This is problem there are no lights what's so ever. If I plug the Bat into the other sockets then the LED lights up Red but when into the Bat socket there are no lights neither Blue or Red, what's concerning me is the fact the system was used once then I had to put back into original box for storage. the Rx is the Optima 7. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 17, 2021 Share Posted September 17, 2021 Have you got the jumper still plugged into the SPC socket Alan The next row to BATT Quote Link to comment Share on other sites More sharing options...
Alan Gordon 5 Posted September 17, 2021 Author Share Posted September 17, 2021 Hi Denis No I haven't Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 17, 2021 Share Posted September 17, 2021 (edited) Powering up options are available for the rx using BATT or SPC For most common applications using BATT as you have The Jumper is plugged into SPC Any 2 socket bind plug will do it or a lab type jumper cable To add If you previously had a BEC and Telemetry You may have removed the jumper and fitted your throttle/ ESC in SPC Edited September 17, 2021 by Denis Watkins Quote Link to comment Share on other sites More sharing options...
Alan Gordon 5 Posted September 17, 2021 Author Share Posted September 17, 2021 Thanks Denis I will keep on trying, Honestly my real problem is, if the RX turns out to be faulty then it became faulty while in storage !!!! My workshop is warm and dry and the radio set was put away in its original insulated carton. When I came to unbox the radio and test it, it did not work so I tried to rebind with no success hence the forum posts. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 17, 2021 Share Posted September 17, 2021 The Jumper is factory fitted So was in the receiver at purchase With the jumper in And batt in batt It should bind 1 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 17, 2021 Share Posted September 17, 2021 Alan, putting the RX back into its box for a while shouldn't make it go faulty etc...double check your set up as Denis has mentioned and all should work....do you have another RX you could try,or someone you know use hitec stuff......who could have a look for you or try one of their RX's. ken anderson..ne..1..... RX dept. Quote Link to comment Share on other sites More sharing options...
extra slim Posted September 17, 2021 Share Posted September 17, 2021 might be stupid, but have you got the polarity of the Battery plug correct?, have you tried it "upside" down?, pins facing upwards? Quote Link to comment Share on other sites More sharing options...
Andrew Calcutt Posted September 17, 2021 Share Posted September 17, 2021 Might as well bin it and get a fr sky receiver from T9 hobbysport. Quote Link to comment Share on other sites More sharing options...
Alan Gordon 5 Posted September 28, 2021 Author Share Posted September 28, 2021 Well gentlemen here is an update on the efforts to get my Aurora 9 to bind. I replaced the Rx and the TX battery but still no go, so I am wondering if there is a Service centre where I might send this set to be looked at professionally ? Quote Link to comment Share on other sites More sharing options...
Andrew Calcutt Posted September 28, 2021 Share Posted September 28, 2021 Perkins have a service service,I have found them very helpful. Quote Link to comment Share on other sites More sharing options...
