Nigel R Posted October 26, 2021 Share Posted October 26, 2021 Won't heat shrink come off? Or is the mouth of the carb tapered a little already? Would the stack/venturi be a useful place to poke the free end of the crankcase vent, so that the odd drop of oil will get slurped up by the intake? Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted October 26, 2021 Share Posted October 26, 2021 2 hours ago, Nigel R said: Would the stack/venturi be a useful place to poke the free end of the crankcase vent, so that the odd drop of oil will get slurped up by the intake? So once the oil has done its job, contains burn combustion material and any metallic bits you then decide to send it down the throat of your pride and joy...sounds like a plan to damage the engine if you ask me! ? 1 Quote Link to comment Share on other sites More sharing options...
Don Fry Posted October 26, 2021 Share Posted October 26, 2021 Don’t some OS 4 stroke engines feed the crank case outflow back into the engine? Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 26, 2021 Share Posted October 26, 2021 That they do Don. Quite a number of them. Since around mid or late 90s I think. Chris, that exact same oil has already been in circulation in the engine for some time - does that sound like a plan to damage the engine? ? Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 26, 2021 Share Posted October 26, 2021 As did all old cars the crankcase breather in the air filter,,, Here it is with some hokey pokery for an exhaust,,, 3 Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted October 26, 2021 Share Posted October 26, 2021 A fiendishly fine fashion to fettle your ferocious four stroke. The heatshrink velocity stack is an very quick way to test out the effectiveness of the idea. Quote Link to comment Share on other sites More sharing options...
Christopher Wolfe Posted October 27, 2021 Share Posted October 27, 2021 20 hours ago, Paul De Tourtoulon said: A good idea on the Saito forum of Rcgroups, just a bit of heat sink tubing,,, Also Velocity Tube Manufacture expands on this subject with a practical example. Regarding re-circulating crankcase oil, a few people have also diverted the ejected crankcase oil into the rocker covers of four stroke engines. Chris Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 27, 2021 Share Posted October 27, 2021 All of my four strokes are inverted, so the oil finds it's way down there without any help,,, Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 27, 2021 Share Posted October 27, 2021 2 hours ago, Christopher Wolfe said: Also Velocity Tube Manufacture expands on this subject with a practical example Neat job by Gary Cee there. Would the ideal location for the open end of the tube would be in 'dead' air inside the cowl space, vs out in the airflow? Quote Link to comment Share on other sites More sharing options...
