Thomas Furniss Posted May 7, 2007 Share Posted May 7, 2007 hi guys, i have bought a Picoo Z indoor heli from inwood models, my work mate also bought one and we are both having the same problem.the heli is always spinning to the left and requires full right stick to even keep it level. if i tap the trims when its up i can level it out but it only stays like this for about 5 seconds then reverts back to spinning to the left. is their any reason why this is happening and how to solve it ?thanks Quote Link to comment Share on other sites More sharing options...
YakMad Posted May 8, 2007 Share Posted May 8, 2007 They don't really hover without spining, I found the trick is to put some light weight on the nose to make it fly forward plus get it away from the ground, fly from a table or a box there seems to be less ground effect and it more stable. It's worth getting it flying right as there is hours of fun to be had. It also requires more trimming as the battery dies. Quote Link to comment Share on other sites More sharing options...
Alan B Posted May 8, 2007 Share Posted May 8, 2007 Hi guys, I found to get the best performance out of the Picoo Z is to stick a drawing pin in nose If you are really fussy then use a coloured one to match the colour scheme!If due to pilot error you decide to land it behind the odd potted plant or TV then check the blades especially the rear rotor, pull it off and wipe the shaft with your thumb and finger. Even a spider web or hair will make it spin violently! At all costs avoid long haired blondes with an attitude!Happy flying Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 8, 2007 Share Posted May 8, 2007 and dont puncture the tiny LiPo cell with the pin which is in the nose area ! Quote Link to comment Share on other sites More sharing options...
Thomas Furniss Posted May 8, 2007 Author Share Posted May 8, 2007 so everyones has the prolem of spinning to the left ? i have added weight to nose befoer ei posted to get it to go forwards buts its annoying it spiinnin to left all time Quote Link to comment Share on other sites More sharing options...
Alan B Posted May 8, 2007 Share Posted May 8, 2007 Yes thanksvery good comment by Timbo . Make sure it is at the very front of the nose ie not underneath,top sides etc I have done this with my own and family members without any problemsregards Quote Link to comment Share on other sites More sharing options...
Henning Strand Posted May 11, 2007 Share Posted May 11, 2007 My pico actually flies very well (as well as can be expected...). The rotation that you describe happens once in a while, but cleaning the rear prop shaft and also bending the rear prop blades to increase or decrease angle, will help. I added all the weight stickers that came with the chopper under the nose, which gives mine a steady pace forwards.Lots of fun. Brought the copter to work; one flight and 10 colleagues had ordered one each.Henning Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted August 17, 2007 Share Posted August 17, 2007 I have another problem, after a collision with a ceraeal box the tail rotor motor has stopped working. It has power to it so it is not a broken wire. Does anyone know where to get a spare or is it a throw away.Mike Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 18, 2007 Share Posted August 18, 2007 Sounds as if you have a hair round the shaft. Pull the tail rotor off carefully and remove any hairs, cobwebs etc.Note. There are non Silverlit clones out there, copies of the Picco Z. They don't fly nearly as well. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted August 19, 2007 Share Posted August 19, 2007 From my expeierence that is what they do. Every one I have seen needs immediate trimming on start up after a charge, a slight adjustments during flight. All seem to benefit from nose weight, so that you go somewhere. I used the sticky nose weight supplied, others Blue Tack.Grand daughter (2yrs) was awe struck. Just managed to save it from a King Kong moment.RegardsErfolg Quote Link to comment Share on other sites More sharing options...
Flanker . Posted August 24, 2007 Share Posted August 24, 2007 I have had a ball with mine but the left hand spin is annoying. T o make it fly well you need, as has been said to keep the tail rotor clean. Check for tiny breaks in the tail blades nr the hub. ANY brake or deformity here will lead to bad spins.Really work at the trims remembering that you have to "pulse" the control.Make a new rear fin from plastic picknick plate that has a wider flange near the body of the machine. Make sure that this fin inclines to the right as seen from the rear.This uses the down wash from the rotor to counter the spin, using the boom as a rotor blade to turn the heli the desired way. You have to experiment to find what is the ideal area/angle but is it worth It ! I can happily fly kitchen circuits and figure eights with ease (some times!) This is a very worth while tweak as it works proportionally with the rotor speed.. lol. Use the three foil weights for spot landing games and had half a pea of blue tack for good forward flight. Does anyone know where to get spare tail rotors from?Thing is I now wish for pitch, ie elevator control too, do think they will? Quote Link to comment Share on other sites More sharing options...
Sean Eltringham Posted August 25, 2007 Share Posted August 25, 2007 For spares use Steve Webb Models;http://www.servoshop.co.uk/index.php?area=PICOSPARES&type=HELIEP&title=Picoo%20Z%20and%20Micro%20Hel%20Spares Quote Link to comment Share on other sites More sharing options...
Flanker . Posted August 25, 2007 Share Posted August 25, 2007 Cool! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 25, 2007 Share Posted August 25, 2007 You should have got a spare tail rotor with your model. The clones don't come with one. Flying Toys who import the Picco Zs can supply spare tail rotors. Quote Link to comment Share on other sites More sharing options...
Flanker . Posted August 25, 2007 Share Posted August 25, 2007 Been through one already, want a spare for when I want one NOW, and Webbies have 'em.Oh, bye the way, you, er, you're not thinking of putting a pilot in your heli are you Peter? ... Quote Link to comment Share on other sites More sharing options...
Erfolg Posted August 25, 2007 Share Posted August 25, 2007 The only additional comment, that may be of any significance, is with regard to batteries.I have noted (after being told by others), when the batteries loose capacity, flight times reduce. Until a fresh set of batteries are used (NiCads have to low a voltage to fully charge.I have a broken fin on my boom, it does not seem to effect trim. Either there are subtle variations between identical models, or I am to insensitive to notice.Regards Erfolg Quote Link to comment Share on other sites More sharing options...
sean calhaghan Posted August 29, 2007 Share Posted August 29, 2007 guys my silverlitt wont fly left it will do a perfect right hand circle but it wont do a left hand circle any ideas Quote Link to comment Share on other sites More sharing options...
Erfolg Posted August 29, 2007 Share Posted August 29, 2007 They do not like doing a left hand curcuit, as much as a right hand curcuit. They tend to loose height, during the left and gain during the right.I guess it is a gyroscopic thing. I would think that some one will explain why.Get to near the ceiling, and another effect kicks in, tends to move with determination onto the ceiling. Walls have similar effect, I think that one is called the Collander (if spelt correctly) effect (normally associated with rotating cylinders or chimneys with air passing them etc).RegardsErfolg Quote Link to comment Share on other sites More sharing options...
Flanker . Posted August 29, 2007 Share Posted August 29, 2007 Check out my earlier post on the subject, but I did mean it, you have to really work those trims. Once the model is trimmed it really is well behaved (quite!) Quote Link to comment Share on other sites More sharing options...
