tiny-james Posted November 24, 2022 Share Posted November 24, 2022 So today my battery was delivered for my Transmitter so I opened my new RC sim 4 n 1 from amazon only to find out the CD has a Virus within it how can I use it. should I just return it or try and find a fix? I'm sure I'm not the only one with a CD and a virus Quote Link to comment Share on other sites More sharing options...
Jake Bullit Posted November 24, 2022 Share Posted November 24, 2022 Download PhoeniX Sim.Its great.Loads of user made models and flying sites ,and its FREE! https://www.rcgroups.com/forums/showthread.php?2382571-User-Built-Models-for-PhoenixRC Quote Link to comment Share on other sites More sharing options...
tiny-james Posted November 24, 2022 Author Share Posted November 24, 2022 I have down loaded the program but the software is not seeing my transmitter ? Quote Link to comment Share on other sites More sharing options...
tiny-james Posted November 24, 2022 Author Share Posted November 24, 2022 So, after trying to find out where I went wrong I have now uninstalled Phoenix from my computer as it would not see my controller. So I have tried Clearview and that has found my transmitter but it no free any advice welcome I'm getting quite despondent now with the hole Simulator program's I have two CD's and both are showing virus both bought from Amazon and I shall be returning them Quote Link to comment Share on other sites More sharing options...
Philip Lewis 3 Posted November 24, 2022 Share Posted November 24, 2022 It is highly unlikely that there is a virus on a comercial CD from a reputable software house and vendor, it's almost certainly a false flag positive, where you go with that though is up to you. Phoenix will only recognise the TX when the dongle has Phoenix as the selected programme to run. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted November 24, 2022 Share Posted November 24, 2022 After installation of your chosen flight sim, or your free 10 minutes per day Clearview trial, switch the computer OFF. With the computer OFF, and the transmitter OFF, always Tx Off. Attach the USB to the Transmitter and the Computer. Start up the computer. When up and running Start up the flight Sim Follow screen prompts Quote Link to comment Share on other sites More sharing options...
Caveman Posted November 24, 2022 Share Posted November 24, 2022 Hi James, have you got a dongle and adaptor set something similar to this? If so the parts you need are, the USB adaptor, the double ended mono jack cable and the rectangular adaptor which plugs into the back of your transmitter. Make sure that the switch on the USB dongle is set to Phoenix Plug them all together and put them to one side. I would ignore the CDs which came with your set. You can play with them later if you want to once you've got the system up and running. I've read previously about the CDs having viruses so I would exercise some caution! Instead go to this website: Phoenix Simulator Downloads – RC-Thoughts.com And download the Phoenix CD file highlighted below with the (rather crude) arrow. Installation instructions are given a little lower on the web page if you're not sure how to proceed. Don't bother installing updates at this stage as you merely need to get a working system - you can update later. While you're doing the above I'll go away and produce some images of the next steps.... GDB Quote Link to comment Share on other sites More sharing options...
tiny-james Posted November 24, 2022 Author Share Posted November 24, 2022 @Caveman My dongle has not got the switch on it? so do I have to buy a different dongle Quote Link to comment Share on other sites More sharing options...
tiny-james Posted November 24, 2022 Author Share Posted November 24, 2022 So this time I have ordered a dongle with a switch and a UK seller from ebay. I have just looked on my Amazon dongle order and the images shown are all with a dongle so they have sold me a different type of dongle with automatic switch over clearview is working for now so I will use this until my other dongle arrives Quote Link to comment Share on other sites More sharing options...
Caveman Posted November 24, 2022 Share Posted November 24, 2022 Good question! The answer is I don't know. However, if Clearview can see your transmitter then it's obviously working, so it's probably a good idea to carry on in the assumption that it's OK and see what happens. So, the next steps. Leave the dongle to one side for now. Assuming that you've downloaded and installed Phoenix satisfactorily, run the program and you should get an opening screen something like this Click on 'Start Phoenix R/C and the following should appear Close this screen and you should get this one, telling you that your USB interface is not detected. With the dongle NOT plugged into the back of the transmitter, plug the dongle into a USB port. If Phoenix recognises the dongle the USB message will disappear and be replaced with the following If all is OK so far, with the transmitter switched OFF, plug the dongle assembly into the back of the transmitter. I'm assuming that nothing will happen. Then switch the transmitter ON. I'm not sure what will happen next, but, I think that, as no transmitter has yet been setup, it will ask you to setup your transmitter. If this is the case, then success!! Follow the instructions to set up your TX. Incidentally, the instructions tell you to set up your transmitter for a helicopter - I would advise you ignore this and carry on in aeroplane (ACRO) mode - it's much simpler. Hopefully you've got this far and all is well. If not, let us know where things go wrong, and we'll try to help. GDB 1 Quote Link to comment Share on other sites More sharing options...
Caveman Posted November 24, 2022 Share Posted November 24, 2022 (edited) Just out of interest I've downloaded Clearview. The dongle I have has a switch for selecting : (a) XTR, G2, FMS (b) G3, G4, G5, G6 (c) Aerofly (d) Phoenix RC4 Clearview works in modes a,b &c, but not in (d)-Phoenix!! The inference is that a dongle which specifically supports Phoenix is required. I don't know whether that has any bearing on our current discussion 🤨 Also, Phoenix is vastly superior to Clearview from what I've seen. GDB Edited November 24, 2022 by Caveman Additional text Quote Link to comment Share on other sites More sharing options...
tiny-james Posted November 24, 2022 Author Share Posted November 24, 2022 I am just downloading Phoenix again Quote Link to comment Share on other sites More sharing options...
Caveman Posted November 24, 2022 Share Posted November 24, 2022 And, Phoenix doesn't recognise (a), (b) or (c) Quote Link to comment Share on other sites More sharing options...
tiny-james Posted November 24, 2022 Author Share Posted November 24, 2022 So I have started again from scratch Reinstalled Phoenix all good When I plug in my dongle USB into my computer the program still doesn’t see it. I have tried two USB ports but it’s the same with no connection. With a different dongle on it’s way I will have to wait Quote Link to comment Share on other sites More sharing options...
Caveman Posted November 24, 2022 Share Posted November 24, 2022 (edited) Just seen this on ebay 8 In 1 Software RC Drone Simulator With Disk For Phoenix Plane Accessories | eBay if all else fails!! Ah, just read your post - it suggests your current dongle doesn't support Phoenix Edited November 24, 2022 by Caveman Quote Link to comment Share on other sites More sharing options...
tiny-james Posted November 24, 2022 Author Share Posted November 24, 2022 here is my screen shot Quote Link to comment Share on other sites More sharing options...
tiny-james Posted November 24, 2022 Author Share Posted November 24, 2022 @Caveman That is the dongle I have ordered so we will have to wait untill it arrives the try again Quote Link to comment Share on other sites More sharing options...
