Erfolg Posted January 18, 2023 Share Posted January 18, 2023 I have read that late Fokker aircraft particularly EV5/D7 were painted green overall. Rather than being uniform colour, it appears to be streaky. I have read and seen on YouTube, how on small 1/32 type models some have been painted to create the effect. Some using scumble type paint systems in some cases, others standard paint However I have not found a similar methods being carried out on our sized models. Has any one any experience, method, seen videos that is appropriate to us? Quote Link to comment Share on other sites More sharing options...
J D 8 Posted January 18, 2023 Share Posted January 18, 2023 There is a large RC Triplane in Werner Voss colours on You tube, nice change from the usual red jobs. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted January 18, 2023 Share Posted January 18, 2023 Erf, there is a thread, 2013, Streaky camouflage on Fokker aircraft. It covered, how my 1/4 scale triplane got painted. A picture of the finished machine. 1 Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted January 18, 2023 Share Posted January 18, 2023 A DR1 replica. Shows quite well the streaky paint applied. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted January 18, 2023 Author Share Posted January 18, 2023 Are there any links to videos or text and photos? I assume that the reason was that the printed materials were becoming difficult to source, as the Germans ran out of most basic products (a s well as munitions and bodies)? I have read that some have used a light blue as the under painting, which struck me as strange, as I assumed that the paint was applied over white linen? Particularly as repainting had an adverse effect on the rate of climb, due to the weight increase. I have also read that the Germans permitted significant repainting, as an aid to recognition of comrades during actions, as radio communication had not arrived at that time? The trouble is you do not know what to believe is true, or even an exception, particularly with the passage of time. Quote Link to comment Share on other sites More sharing options...
David Davis Posted January 18, 2023 Share Posted January 18, 2023 (edited) I believe that the streaky finish was first applied to the triplanes, then to the fuselages of early early DVIIs before they were finished in the printed lozenge material. I believe that the wings of the DVIII/EV were painted in olive drab/dark green overall. Picture of my Hans Weiss Puppeteer below. I used decorator's scumble glaze to achieve the effect. Edited January 18, 2023 by David Davis Quote Link to comment Share on other sites More sharing options...
Erfolg Posted January 19, 2023 Author Share Posted January 19, 2023 I am coming to the end of building a model of a Fokker V29, an aircraft that was essentially a development of a D7 & D8. It competed at the 3 rd. Adlerhof competition. It appeared to be amongst the best, for most things. On that basis a overall same colour/shade green wing would suit me much better, in that I can spray the finish. My only issue is that what ew pictures of the full size are probably less than 5. What came as a surprise is that the body (annoyingly) was covered in what appears to be 5 colour, hexagon, printed cloth. I have looked at plastic kit adverts and built kit images, which I now know are not as well researched as I had hoped. The photos clearly show a white fin and rudder. Most if not all models seem to get this wrong. It is a pity that black and white photos, make what the colours were a bit (understatement )of a guess. I have photographed original aircraft at Old Warden and at Cosford (in the renovation department). The other issue is the lack pictures, especially in plan. It could be my imagination, what illustrations there are, seem to have subtle shading, to give form, life to the image. But I now pretty convinced that green, is as good a guess as most. I am probably not that concerned as to what is truly a representation of scale, as it is, will be, a every day model, not a Dany Felton, type masterpiece. Rather a 30 foot squint scale model! I do a far better understanding of many WW1 aircraft and their manufacture than when I started. For quality Fokker were near the bottom of the pile. Although I find it hard to reconcile Rudolph Platz designs with the suggestion he was denied many or all of the technical data and reports available. What I can see that his designs are pretty much by proportion and intuitive observation, a bit of an enigma to me though. Still need as much help from others as you can all provide. Quote Link to comment Share on other sites More sharing options...
David Davis 2 Posted January 19, 2023 Share Posted January 19, 2023 Unless you are going to enter your model in a competition I wouldn't worry too much Erfolg. I don't suppose that any aircraft from the Great War have survived unrestored and even if one had, the colours would have changed over the years. Quote Link to comment Share on other sites More sharing options...
david tilbury Posted January 19, 2023 Share Posted January 19, 2023 (edited) Hope these help, i used 3 different shades of green, at 1:4 scale use a 2" brush as the full size was painted/streaked with a 8".... The wing and tailplane at an angle roughly 45 degrees as with the top of the fuz, the sides of the fuz vertical......the underside of the wing and fuz was a light blue not streaked. All the best Dave Edited January 19, 2023 by david tilbury 5 Quote Link to comment Share on other sites More sharing options...
david tilbury Posted January 19, 2023 Share Posted January 19, 2023 photo by Danny Fenton.....:-) 1 1 Quote Link to comment Share on other sites More sharing options...
Steve Fox Posted June 16, 2023 Share Posted June 16, 2023 On 20/01/2023 at 08:38, david tilbury said: Hope these help, i used 3 different shades of green, at 1:4 scale use a 2" brush as the full size was painted/streaked with a 8".... The wing and tailplane at an angle roughly 45 degrees as with the top of the fuz, the sides of the fuz vertical......the underside of the wing and fuz was a light blue not streaked. All the best Dave Very nice work cheers Steve Quote Link to comment Share on other sites More sharing options...
Erfolg Posted June 16, 2023 Author Share Posted June 16, 2023 It is a pity that the V29 was not finished in the same way. Although not stated anywhere that I have seen and read. The stripy finish seem to be tolerated for a short time. I guess that both in the interest of uniformity and weight saving, many of the D7 and the whole or majority of D8 were sprayed uniform green wings and printed fabric open structures. Quote Link to comment Share on other sites More sharing options...
