Andy J Posted April 28, 2023 Share Posted April 28, 2023 About to recover an open structure Playboy Senior wing using a translucent film for the TE section aft of the main spar and a solid colour for the section forward of the main spar. Will there be an issue if I take the translucent film across the wing chord ie TE to LE and then cover over the forward section with the solid colour from the LE back to the main spar? In the past I have avoided overlaying two layers of film but thinking there will be more balsa to adhere too by taking the translucent film across the full chord. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted April 28, 2023 Share Posted April 28, 2023 I think you can, air bubbles are your enemy. I reckon though, that put the translucent on first..if worried about adhesion, use a heat activated glue. Then the solid colour, 6 mm minimum overlap over the translucent film. Quote Link to comment Share on other sites More sharing options...
Murat Kece 1 Posted May 1, 2023 Share Posted May 1, 2023 I used it without any issues! Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted May 1, 2023 Share Posted May 1, 2023 Film on film, I use one of these on the film to be covered, it prevents bubbles 1 Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted May 2, 2023 Share Posted May 2, 2023 You can float film over existing film using the method normally used for putting on sticky trim. With slightly soapy water and squeeing out the water works better than trying to squeegee out air bubbles. This will work over a large area and once the film is down and all the water has a chance to dissipate, iron down the first 1/4" around the edge to secure it. It seems that any remaining moisture will migrate through film where air doesn't. This how my refurbished Sebart Angel turned out after a recovering job using the above method. 4 Quote Link to comment Share on other sites More sharing options...
