Parallel charging multi Lipo packs
Tim Mackey
OK Terry here's your gizmo. Simple and idiot proof as requested, and useable for 2 X 2s  or 2 X 3s packs ( not mixed of course ).
Ensure the 2 packs you wish to parallel up are at pretty much the same state of charge /discharge as each other before plugging them in to the board.  Ignore the wiring colours as different manufacturers use different colours - stupid I know, but another example of how to confuse the beginner... just ignore the colours, and if you have different colours on your  packs, again....ignore them - the orientation of the wiring is what matters, and this is set up correctly I assure you.
Remember that for charge rates above 1A you must also join the main battery leads with a Y lead. For charge rates below 1A, then just plugging in one battery's main leads to the charger will be fine, as the other battery will be charged effectively via the parallel connections of this balance board.
I will pop it in the post tomorrow 1st class.
The two packs I used here for the photos were a fair bit out of balance cell wise ( although the pack voltages were similar...within .4V )
Each battery was then plugged in seperately after using the " Timzo " and showed each cell in each pack to be spot on 4.20V. Even woithout actually charging, plugging in two packs to the unit will automatically and quickly equalize the cells in each battery - but of course, if these cells were inbalnced to begin with they will stay that way... but at least matched pack to pack IYSWIM.
  • 6 months later...
  • 3 weeks later...
Although the internal impedance of (good quality) lipo packs is low, it's not actually a massive problem connecting different charge level packs in parallel - the math works on the voltage difference between the cells.
In crude terms, and an extreme case, two packs with an internal resistance of 25 milliohms each, and say 0.3 V difference between them would result in a 6A current (initially) between cells... that may scare you, but it'll a) tail off very very quickly, and b) it's actually not that big a deal.
If using an adaptor such as the one above (which I myself do), probably the current-limiting factor is actually the copper tracks on the circuit board, not the balance taps. The balance wires in practise are usually capable of taking several amps - their resistance probably causes significant voltage drop (but that doesn't really matter, it only reduces the efficiency of the charge), but they don't get hot, so it's all fine.
The only appreciable risk of parallel charging is what happens if for whatever accidental reason a pack becomes disconnected? In that instance, the remaining packs will experience a greater than rated charged current.
Although that situation is unlikely, I personally like to back off from the maximum current by the charge current of the single largest pack being charged, purely as a safety margin. For example, if I were charging a 2200mAh, 1200mAh and an 1800mAh pack, on paper I could charge (1C) at 5.2 Amps, i'd actually charge at only 3 A, which would result in a safe charge rate if any one pack became disconnected.
A separate note: Most of the modern far east mass produced lipo balance chargers use bleed balancers and require the main leads of the pack to be connected when charging. If you're using a parallel adaptor board as above, but your charger needs the main leads connecting too, you can actually connect the leads of just one of the packs - there's no need to connect all of the main leads in parallel (of course provided that you don't overdo the current which will be flowing down the balance leads - this trick is purely to satisify the charger's requirement to have the main leads connected, no more, no less).
I dont believe I said anything contrary to this anyway. I f yoiu read the whole thread, you will see I suggested that " packs should be roughly equal in charge state", and also mentioned twice, that if charge currents were only around 1A or so, then connecting just the one packs main leads to the charger is sufficient, as the others are then charged ia the balance plugs main "end " terminals.
  • 2 years later...
i bought a imax b6 lipo charger from ebay, or so i thought. later on cruising youtube i came across this video (see link). i contacted the guy immediately and he refunded immediately according to the paypal email i received, but it hasnt shown up at all in paypal account yet. not even appearing as a pending transaction yet, so i'll give them 24 hrs then get on to them i think.
you have been warned!
Edited By Steve Hargreaves - Moderator on 21/04/2012 21:14:06
  • 1 year later...
i know it's an old post but it's relevant to my question. this battery charging stuff has me a bit confused.
if i want to charge multiple(3 of them) 2s 300mah lipos i can use a lead like this
**LINK**
on my charger and just connect one of the batteries up via it's jst power lead to the charger as well?
what would my charge current be with setup? i normally go with the lowest setting but i doubt that it is all that quick which is what this is about is it not?
thanks in advance!
Hi Paul,
Yes I use the very same cable to charge the 2s packs from my Blade 130X. I simply plug the single end of that into my balance board, then all the packs into the sockets. And yes, as you say, one of the packs needs to be connected to the main +/- leads from the charger.
As for current, simply multiply your desired charge rate by the number of packs. So if you want to 1C charge your 300mah packs and you have three of them, set the charge current to 900mah.
I've only ever parallel charged the same brand/spec/size of pack and only if they are similar levels of discharge, which in my case means I flew until the time ran out on the TX and then landed.
  • 3 years later...
Old thread but since its been referenced recently...
Balance leads and JST-XH connectors are fragile things and at some stage we must all have had a wire detach from a balance lead. When balance-charging a single pack, the charger will spot this and stop.
When parallel charging however, you need to be confident that all the balance connections are intact and secure for each pack, as one good pack will mask any 'missing' balance connections in any or all of the other paralleled packs.
This means that whilst you think you're balance charging several packs, unbalanced cells in a pack with a dodgy balance lead or even just having a poor JST-XH connection - could feasibly go over 4.2v, the charger would be unaware. We all know where that ends!
I routinely parallel balance charge my bike battery which is two 5S 5000's in series when running, but in parallel when charging, and what I do is to plug in one pack and start the balance charge for a few seconds, long enough for the charger to spot a balance lead problem. Then I unplug that pack and plug in the other one, start the balance charge for a few seconds, again long enough for the charger to spot a balance lead problem, and if all is well plug the first battery back in so they are now paralleled, and start the full balance charge.
Its not foolproof - you could even cause the break whilst swapping packs, or you may neglect to insert the balance plug of one pack - but it is just another sanity check and a confidence thing. Simply plugging several packs in and hoping for the best, without checking each pack's balance connections, could possibly be disastrous.
Cheers
Phil
Edited By Phil Green on 02/10/2016 16:28:23
Posted by MattyB on 02/10/2016 19:56:42:
I can see the logic, but isn't the problem that it puts twice as many cycles on the balance plug connector, so it's twice as likely to fail on a given charge cycle?
I'm just pointing out the possibility of an over-voltage incident Matt, and one mitigation method which I'm content to use.
Whether maintenance checks are worth the risk of breaking something is a personal choice.
One method which should give complete protection would be to use a separate alarmed balancer on each pack, and to parallel only the main power connectors. Any cell in any of the paralleled packs would then be protected - assuming you're there to hear any alarms smiley
Cheers
Phil
Edited By Phil Green on 06/10/2016 10:38:33
