Engine alignment
Sam Longley
On 09/12/2023 at 12:04, kc said:
There is a school of thought that says that side and downthrust are remnants of free flight and are not needed with RC.  Much easier if the motor has no down or sidethrust - cowl fits nicely etc.
I do not like the idea of using trim on the radio as this will vary on power output & will upset  trim for rolls in IMAC etc. The Avanti should be a well balanced plane if built correctly . Then i can play with trim as i like. I am not an advanced pilot, but I will get better with the right set up & gear to start with
If you aim to fly precision aerobatics then you should understand that setting downthrust to exactly 1.5 deg is not the end of the story.  You then need to fly the aircraft to make sure that the downthrust is correct for your aircraft.  The chances are it won't be.
However, before you get there it is more important to set up the CG to its optimum position.  Any other trim adjustments then follow.  If you change the CG after you have made the other trim changes they will all then need to be re-done.  CG position is the single most powerful trimmimg tool at our disposal.
  • Like 2
  • Thanks 1
Re C of G people often forget to balance the wing tips as well. One ARF plane I bought needed a surprising amount out on the tip.
You can make some adjustments when the aircraft is static but the only definitive way to check this is during flight testing and then finalusing any further adjustments.
2 hours ago, Martin McIntosh said:
Shimming a mount is fine but adding  washers to engine lugs not only can distort the crankcase as I said above but the screws will no longer be at 90 deg and the heads will definitely shear off in time.
Not if you put counter shims above the crankshaft plates to match tapered shims below the engine bearers
Edited by Sam Longley
  • Confused 1
52 minutes ago, Nigel R said:
Must admit, 1/4 ply firewall at correct angle, plus glass nylon mount, seems like an answer without issues.
Problem is that it does not fit the design & it does not allow for changes in the downtrim of the engine without resorting to shims.
