Roy Thompson Posted February 13, 2024 Share Posted February 13, 2024 Recently upgraded to a new ASUS i7 pc with Windows 11, and GeForce RTX3070 graphics card. I'm now trying to install Phoenix RC on it, but it will not launch. I've installed the latest Direct X, updated the graphics card drivers, tried with and without compatibility settings, and installed and uninstalled the Sim more times than I care to mention. Have trolled through all the forums but cannot find an answer. What am I missing? P.S. My old machine is Windows 10 and Phoenix is all good. I don't recall having any big issues when I installed it on this machine, but it was a long time ago. Don't really want to hold on to the old PC just for this one Sim, but if needs must😆. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 13, 2024 Share Posted February 13, 2024 My Phoenix does work on Windows 11, but I have to follow this sequence for it to launch. Assume the Phoenix is installed and the computer is now OFF. Get the transmitter, which is also Off, and plug in its Phono lead plug. The transmitter will then come on. Now put the other USB end into the computer. Now switch on the computer and allow loading to finish. Now try to launch Phoenix. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted February 13, 2024 Share Posted February 13, 2024 Roy - it's worth downloading V6 from rc-thoughts or rcgroups, if you get v5.5 working. Quote Link to comment Share on other sites More sharing options...
PDB Posted February 13, 2024 Share Posted February 13, 2024 33 minutes ago, GrumpyGnome said: Roy - it's worth downloading V6 from rc-thoughts or rcgroups, if you get v5.5 working. Bottom left of Roy’s screenshot 🤪 Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted February 13, 2024 Author Share Posted February 13, 2024 1 hour ago, Denis Watkins said: My Phoenix does work on Windows 11, but I have to follow this sequence for it to launch. Assume the Phoenix is installed and the computer is now OFF. Get the transmitter, which is also Off, and plug in its Phono lead plug. The transmitter will then come on. Now put the other USB end into the computer. Now switch on the computer and allow loading to finish. Now try to launch Phoenix. Just given that a try, thanks Denis, but no joy. It's going to be something stupid and so simple, I just know it! Quote Link to comment Share on other sites More sharing options...
PDB Posted February 13, 2024 Share Posted February 13, 2024 Is there anyway you can get Phoenix to use the onboard graphics card to eliminate the possibility of the GeForce being the issue? Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted February 13, 2024 Author Share Posted February 13, 2024 (edited) Interesting idea, I have a go tomorrow. Edited February 13, 2024 by Roy Thompson Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted February 13, 2024 Share Posted February 13, 2024 3 hours ago, PDB said: Bottom left of Roy’s screenshot 🤪 So it is! Good spot. Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted February 19, 2024 Author Share Posted February 19, 2024 Went back to my original Phoenix Rc PC-DVD and installed a copy from there with Direct X selected, but the Direct X part failed. So downloaded a new copy of the V5.5 DVD from RC Thoughts.com and did as you suggested. The good news is I have a working copy now, but it's V2.5 I was hoping that the other copy of V6.0i would now run, but no, that's just too easy. So I assume my next step is, uninstall the sim and start again. I'm making the assumption that as V2.5 runs that Direct X has installed satisfactorily and by uninstalling and re-installing the sim it won't affect Direct Quote Link to comment Share on other sites More sharing options...
Roy Thompson Posted February 19, 2024 Author Share Posted February 19, 2024 I'm pleased that I have my sim up and running on the new PC, one less thing I need the old one for. So to round up, and install successfully on a new Windows 11 PC; Download a copy of the installation V5.5 DVD from RCThoughts.com. Then install the directX that is on the installation DVD Map: Phoenix DVD V5.5\files\#INSTALL\utilities\DirectX\DXSETUP.exe and run it as administrator. Following that, install the sim as normal and add the updates as required. 1 Quote Link to comment Share on other sites More sharing options...
Adriano.M Posted July 13, 2024 Share Posted July 13, 2024 Hi guys, Just joined this forum today, I just reinstalled Phoenix 6.0 on my pc running win 11 everything works fine but when I try to install a new model or flying field it seemes to install it but when i go into the model select the new model is not there? any idea on what's going on, thanks in advance Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted July 14, 2024 Share Posted July 14, 2024 By 'install', do you mean add unofficial models and sites ? AFAIK, they are installed to a different directory - RCGroups has a good installation guide.... Quote Link to comment Share on other sites More sharing options...
