Neddy Posted February 16 Share Posted February 16 The wings in my hawk sky are loose and will slide out of the fuselage. I was wondering whether there is a clip or something I could mount to lock them in place. Reading the assembly instructions it says use the steel bolt ? There isn't one? Quote Link to comment Share on other sites More sharing options...
Wookman Posted February 16 Share Posted February 16 Nylon bolt from modelfixings maybe? Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 17 Author Share Posted February 17 I have made up a thin plastic strap with a hole each end which I can fix to the fuselage inside the recess at the bottom where the wings slide in. I will drill one hole through each wing and have four plastic washers with spacers which I can press into the wings then bolt through using nylon bolts and wing nuts. The spacers will stop the wing getting crushed as I tighten up the bolt. So all I do is slide the wings in place line them up and bolt them in place. Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 18 Author Share Posted February 18 r Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 18 Author Share Posted February 18 All I have to do is shorten the bolts and put conventional nylon nuts on instead of the wing nuts. This should reduce any drag. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted February 18 Share Posted February 18 Any reason why you can't just run a bit of tape down the wing / fuselage gap, I used to do that on all my gliders, even my old 3.6m Multiplex DG- 600 1 Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 18 Author Share Posted February 18 The previous owner has stuck tape all over the plane. I have been gradually removing it the plane has tape glue left on it and it's messy I really don't want to stick more tape on it. Quote Link to comment Share on other sites More sharing options...
Outrunner Posted February 18 Share Posted February 18 I would have put some little magnets in the wing roots, less of an eyesore and just pull the wings off. 1 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted February 18 Share Posted February 18 1 hour ago, Outrunner said: I would have put some little magnets in the wing roots, less of an eyesore and just pull the wings off. I have a couple of my planes wings and cockpits held on with magnets from old burnt out motors. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted February 18 Share Posted February 18 Noddy, you are assembling a trainer, tool for a job. Now I appreciate pride of workmanship, but you don’t polish a hammer. Tape is quick. It’s reliable. It does not fail, think how you would feel, it’s your only plane, a magnet pulls out. Quote Link to comment Share on other sites More sharing options...
