Securing wings
Neddy
The wings in my hawk sky are loose and will slide out of the fuselage. I was wondering whether there is a clip or something I could mount to lock them in place. Reading the assembly instructions it says use the steel bolt ? There isn't one?
I have made up a thin plastic strap with a hole each end which I can fix to the fuselage inside the recess  at the bottom where the wings slide in. I will drill  one hole through each wing and have four plastic  washers with spacers which I can press into the wings then bolt through using nylon bolts and wing nuts. The spacers will stop the wing getting crushed as I tighten up the bolt. So all I do is slide the wings in place line them up and bolt them in place.
Noddy, you are assembling a trainer, tool for a job. Now I appreciate pride of workmanship, but you don’t polish a hammer. Tape is quick. It’s reliable. It does not fail, think how you would feel, it’s your only plane, a magnet pulls out.
