Former Member Posted May 25, 2009 Share Posted May 25, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 25, 2009 Share Posted May 25, 2009 Pollybrilliant Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 25, 2009 Share Posted May 25, 2009 Myronbinit Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted May 26, 2009 Author Share Posted May 26, 2009 THanks Bob Frank Stephen & of course Polysupermod Yesterday couldn't get the link from Pete Today I did !. Looks like Timbo was right when he says you get what you pay for . Never mind the hype ? Shall be getting on to GC shortly . Shame 'cos as I think I've said their service was excellent .Credit where it is due ( excuse the pun) MoT today - Fingers crossed everybody please Not been my week so far G-UMPY --I wonder why ? Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted May 26, 2009 Author Share Posted May 26, 2009 Frank Just double checked the specs having re read your entry so as I might ecentually Know just what is what & compatible with what .Then I might be able to explain the problem better . I just hate giving up on something when there might still be a solution .Did I hear a voice saying "glutton for punishment" ? I have the FSSS Tx module CT8F & all three Rx's are CR8D's .Depending on what you make of the "F" it would seem nothing should work & be unbindable OR am I out of my depth again? Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 26, 2009 Share Posted May 26, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted May 26, 2009 Share Posted May 26, 2009 Very interesting thread this one. Myron, didn't you say that the one Rx you did get to bind still had problems though? As this was a genuine mistake I should think your supplier should give you a straight swap for the correct devices. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted May 26, 2009 Share Posted May 26, 2009 Myron, the CT8F just means it's a Futaba style transmitter module. Underneath this there should be 'made in China', '2.4Ghz' and either 'DSSS' or 'FHSS'. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted May 26, 2009 Author Share Posted May 26, 2009 Polyfilla & Doug Have E-mailed GC received confirmation & now awaiting reply from their tekky dept. Should clear up the matter Doug .Glad you find it interesrting -I actually find it stimulating for my brain cell .Hate to be beat without knowing why -It's how you learn isn't it ? although I get more confused the more I read .As far as i remember & it's getting more difficult although I log most of what I have done & do .The original problems of permanent binding on the original one Rx set up I managed to sort out ( the bind )by simply switching on the Rx before the Tx and vice-versa for switching off ie Tx off first then the Rx !As I remember problems arose on the introduction of the other two Rx's (same description on the label .One thing has just this minute come into my mind !! The original pack containing the module & Rx together had the Rx without the label stuck on. It was loose in the box .I wonder if there might have been a mix up at the packing stage -However it did bind as described .I think maybe we need Inspector Morse on this one ? Slightly off thread but have just procured a charger mains/ battery plus 4 niMh 2700 mAh £6.99 .Just had to buy it at that price even though I've read that the best capacity is around 1700 mAh for models . Anyway I want to modify the charger to use on Rx packs Not seperate cells .Has anyone done this & if so did they use diagonally opposite contacts as a feed for a normal 4 pack .It has delta peak indication & fail safe going to trickle charge as well! Plus charging time approw for nicd's & nimh's Cant be bad Eh ! Maybe I should start another thread but folks must be sick and tired of my questions ?I know a lot of it has been covered before in some context or other. G-UMPY Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted May 26, 2009 Author Share Posted May 26, 2009 Phil Yes it's netto.The voltage across the "diagonal end terminals on the 4 cell position measures 16.79 V off load .Can't I just attach my lead to fit the Rx 4 pack from these terminals -Just ignore the 2 cell charge switch? I wasn't thinking of linking the remaining connectors in series if that's what you mean . I must have the back off & have a look Judging by the weight of the charger there isn't a transformer in it especially as the mains chargers output is Quote "12 V DC 500 mA 6 VA I have it all on charge now using the mains adaptor ( for about 3 Hr 20 Min it says ). Can't wait to sort it all .Good news --for a change The camper van passed the Mot --Bad news ( again) Left my 600 maH Optic 6 Tx battery pack on charge all night and after a discharge ( Left on ) now has gone from 48 minutes to a staggering1 hour13 mins . When are the peeps in white coats coming to rescue me or ensconce me in a decent pub with an ash tray that wants live music (sort of ) Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted May 26, 2009 Author Share Posted May 26, 2009 Polyhelpful There's a little red light on it that goes to green on reaching the fully charged state (it says) -Not been on long enough to find out yet . Should happen around 7.30 pm . Yep Must apologise for being off thread .Blame me if you get in trouble but you're very helpful.in my hours of need. Should I start a new thread ? By the way the destruction leaflet is written in no less than ten languages so I suspect the manufactureres are not some "fly by night" organisation .It's made by ENCORE & I'm sure I've seen the name during my research this last few days I do know what you mean by RMS values (0.7071 of peak if I remember correctly) 'It explains why the charger gets warm when you say there is a resistor in there ( isn't it a rectumfrying circuit with 4 diodes and a rew capacitirs thrown in to give a "so-called "regulated output ".I'm just thinking that a little knowledge is a dangerous thing before you say it ' Thanks again -Better shut up now or join the unruly band of contributors in the "Cafe" GUESS WHAT ? the light has just turned green -One & a half hours -Maybe the batteries weren't flat to start with -They were 1.24 V all of them out of the bubble pack which incidently will make two lovely canopies for a war bird . They measure 1.42 V now after 5 mins rest & warm to the touch Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted May 26, 2009 Author Share Posted May 26, 2009 PS Not 1/1/2 hrs but 2 1/2 hrs Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted May 26, 2009 Author Share Posted May 26, 2009 Say no more -Can you transfer what has been discussed so far onto another thread or no ? .Now you have a challenge Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted May 26, 2009 Author Share Posted May 26, 2009 Polymusiclover&family Back on thread ! Received a reply from the "experts" Telling me to switch the Rx on first We'd never have thought of that would we AARRGGHH 'Sorry to keep RAPPING on about this .WWHHOOhhps Wrong thread (won't mention the "cafe") Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted May 26, 2009 Author Share Posted May 26, 2009 PS Only read about 400 threads on this subject Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted June 1, 2009 Author Share Posted June 1, 2009 Phil-- Reply from other thread as requested . Can't get Rx No 2 to bind at all now -Surprise ,surprise .But have done nothing else yet.( Like the obvious of trying No1 & /or re-binding it ) Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 1, 2009 Share Posted June 1, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted June 1, 2009 Author Share Posted June 1, 2009 Phil Am going to "Return to sender" Rx's 2 & 3 ' I've been assured they won't charge me to return them if they find them faulty .The thing is of course is- What use could they be if they do ? Thanks again to everyone with their help,advice & time Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted June 1, 2009 Author Share Posted June 1, 2009 Polyproperly Sure will ! Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted June 1, 2009 Share Posted June 1, 2009 And you have the might of this Forum behind you all willing the things to bind and bring a smile to the Mrron we all loveIts been like following a decent soap,my evenings wiill be hollow without this drama going on MyronEdited By Phil Wood - Moderator on 01/06/2009 22:30:14 Quote Link to comment Share on other sites More sharing options...
Garry Pollard Posted June 1, 2009 Share Posted June 1, 2009 Dont say the drama is going to be wound up, if so can we expect a sequel , couldnt sleep nights without my Myron fix Garry Quote Link to comment Share on other sites More sharing options...
