Nixer Posted September 21, 2009 Share Posted September 21, 2009 Hi folks, I have an SC52 4C in my Seagull Pilatus PC9, but it seems that 90% of my throttle control is in the 1st half of the stick movement, thereafter there's very little left in the engine. This makes it difficult when landing when subtle throttle control is required. I could sort this if i had aero throttle curve on my FF7 but alas, I do not. Any ideas as to an alternative remedy for this problem? Cheers, Nicky. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted September 21, 2009 Share Posted September 21, 2009 Its a common problem!!! All I could suggest is to use some mechanical differential so the first 30 degrees (say!) of servo movement translates to relatively less linear movement at the throttle barrel. Also limiting the ATV of the first half of the stick movement can help too. Setting up throttles can be extremely tedious & I guess most people don't bother...as long as the throttle barrel goes from idle to full without stalling the servo I guess most people are happy..... Quote Link to comment Share on other sites More sharing options...
Ernie Posted September 21, 2009 Share Posted September 21, 2009 Hi Nicky, What about using exponental on the throttle channel ernie Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted September 21, 2009 Share Posted September 21, 2009 Hi Ernie, all well and good if you have expo on the throttle channel as not all systems do. Quote Link to comment Share on other sites More sharing options...
Bert Posted September 22, 2009 Share Posted September 22, 2009 Nixer THIS or THIS may help Bert Quote Link to comment Share on other sites More sharing options...
Nixer Posted September 22, 2009 Author Share Posted September 22, 2009 Thanks guys, Some good info there. As it happens, the FF7 has got aero throttle expo, and this did the trick beautifully. Should have reserched this better! Although some of those mechanical throttle solutions are useful, sometimes it is difficult to incorporate them into a particular model. Cheers! Nicky. Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted September 24, 2009 Share Posted September 24, 2009 Try adjusting the horn positions and the locations of the clevises on the horns to resolve this issue. To my mind, far too many people jump to using an electronic solution rather than setting up the controls up properly mechanically in the 1st place. Try getting a look at the "RM Propo" book to see what I mean, it is a very old book but a real eye opener to the electronic generation. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted September 24, 2009 Share Posted September 24, 2009 It's another example of trying to change an area / volume flow using linear movement .Use all the expo you can either mechanically or 'lekkricly around the low throttle movement ie idle to half throttle 'You'll find much better control where you want it Cool G-Gumpy #1 or #2 Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted September 24, 2009 Share Posted September 24, 2009 Posted by Andy Gates on 24/09/2009 21:30:21: To my mind, far too many people jump to using an electronic solution rather than setting up the controls up properly mechanically in the 1st place. Try getting a look at the "RM Propo" book to see what I mean, it is a very old book but a real eye opener to the electronic generation. Tis true.....get it close mechanically & fine tune with the electronics.......in t'olden days we didn't have such things as ATV EXP etc....not even servo reverse (although Futaba used to supply servos with opposite rotation...(red or black labels, remember!!) which helped). Setting the throttle so you got full movement without stalling took ages....happy days!! Quote Link to comment Share on other sites More sharing options...
Aslan Posted October 2, 2009 Share Posted October 2, 2009 Hello Nixer,did you set the throttle for wide open first,with gimbal full forward? Quote Link to comment Share on other sites More sharing options...
