Tim Hooper Posted December 5, 2011 Author Share Posted December 5, 2011 The 1/2" top decking is now fitted, and hacked into some sort of shape. The cockpit opening has been hewn asunder.... ......oh, and I've daubed some filler over the more obvious gaps! tim Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 5, 2011 Share Posted December 5, 2011 GAPS!!! That's very unlike you Tim, surely a typo? irregularities in the grain perhaps? Looking very nice, and the motor is in a much better home now Oh and do you happen to have a three view of that Elf......... CheersDannyEdited By Danny Fenton on 05/12/2011 09:28:40 Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 5, 2011 Author Share Posted December 5, 2011 Posted by Danny Fenton on 05/12/2011 09:27:49: GAPS!!! That's very unlike you Tim, surely a typo? irregularities in the grain perhaps? Grain irregularities looking very much like the misplaced cut of a 10A scalpel blade! 3-view of the Elf? Now, you know that I don't even consider choosing a future build until I've finished the one I'm currently doing! Except for the scaled-up Clean Sweep.....oh, and the 1/3 scale AW Quadruplane, of course.... tim Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 5, 2011 Share Posted December 5, 2011 There was a free plan of the Elf, but it was nowhere near accurate for our particulr CDO Ah well just a thought......... Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 7, 2011 Author Share Posted December 7, 2011 It's that CDO again....I've started on the front hatch this morning. A bit of Sellotape stops it sticking to the fuselage during fabrication. It occured to me that adding the occasional 1/8" BBQ skewer to the planking would stiffen the assembly up considerably. I may skin the whole thing in 1/64 ply as well. We'll see..... After searching the net for quite a while for suitable oleo/damper/thingies, I set about making my own! A length of 3/16 brass bar, some matching tube, a couple of springs, etc. Add a couple of hours sawing, filing, soldering, drilling and tapping, and here're the finished items! Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 10, 2011 Author Share Posted December 10, 2011 It made sense to dry assemble the rest of the undercart well away from the fuselage whilst all the hammering, bending and soldering gets underway! I made 4 brackets from angle-section aluminium, drilled them, and then screwed them in place. A couple of balsa pillars followed to hold the swing arms in place. The arms are cut from hefty 8swg wire. I've cut clips from brass sheet to join the pieces together near the wheel hubs. I suspect that I'll need to use a gas torch to get everything hot enough to solder succesfully.... The inner ends of the arms are secured to the brackets by wheel collets. I may substitute these with plain brass collars later. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 10, 2011 Share Posted December 10, 2011 lovely work Tim, much easier to hold things still with a jig Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 11, 2011 Author Share Posted December 11, 2011 Absolutely Dan! it would have been all too easy to damage or burn the model if I'd done it in situ. Anyway, it was time to test fit the UC on the B2 itself. The wheels are 3 1/2" Robart items. The brass clips have been filed down to a more appropriate size. Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 17, 2011 Author Share Posted December 17, 2011 Right, now for some reason I've been mentally putting off carving the dummy air outlets on the fuselage sides, but in the end I couldn't avoid it any longer so I marked their positions out in pen. Then using a scalpel and a round Permagrit file, it only took a few minutes to hollow each one out! Next I decided to skin the cowl top and sides in 1/64" ply just to give a 'crispness' to the panels. The side strakes (from triangular 3/16 strip) followed next.... .....whilst the 1/32 balsa wing fairings weren't far behind! Whilst making the lower nose cowl, I installed a short length of convoluted plastic conduit to suggest No1 engine cylinder. Oh, and Netty's bought me a new box of pins - see the pretty red heads?tim Edited By Tim Hooper on 17/12/2011 21:48:49 Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted December 19, 2011 Share Posted December 19, 2011 Excellent work as ever Tim.....wish I could build half as well....... I do wonder how you are going to cover the model & retain these feature-ettes though....I always find that such crisp detail is easily lost under film/tex or whatever....& as to covering concave surfaces (such as your outlets!!)...well that brings me out in a cold sweat.... Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 19, 2011 Share Posted December 19, 2011 Lovely Tim, Steve we all want to se how Tim will maintain the fus shape under the covering Can I ask where the pins were from Tim, I have bought dozens of packets trying to get more of the really fine ones with small glass heads, similar to the ones I have had for years, these you have here look very closeCheersDanny Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 19, 2011 Author Share Posted December 19, 2011 Steve, There'll be no 'tex or film on this fuselage! A substrate of tissue and dope will provide a base for a layer of Flair Aluclad - a self adhesive aluminium film. Woooooo.....Danny, I'll have to ask Netty, although I suspect they've been lurking in the bacvk of a drawer for some years.tim Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted December 19, 2011 Share Posted December 19, 2011 By the hairy spools of Quill.....that will produce a nice shiny model..... Still intruiged to see how it will form around the fusealge strakes & into those air outlets though......will you be using a miniature planishing hammer to panel beat the ally tape?? Watching with interest...... Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted December 19, 2011 Share Posted December 19, 2011 Pins: Danny: those are continental glass head pins. You find them at Als Hobbies MK. They imported them. Or in every supermarket in Germany or Austria or Italy. I use only those as the head doesnt come off and they are quite hard. Cheers VA Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 19, 2011 Share Posted December 19, 2011 Hi VA, I bought some of the Al's Hobbies ones and the heads are bigger and the shaft thicker, they make a bigger hole in the wood than my skinny 30 year old glass headed ones I guess they just don't make em any more CheersDanny Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 20, 2011 Author Share Posted December 20, 2011 Danny, Just had a chat with Netty and she got them from a beadwork suppliers some time ago. tim Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 24, 2011 Author Share Posted December 24, 2011 Right - a good day yesterday! I knocked up a card template for the windscreen, and then transferred the shape to 1/64 ply. After that I made an internal frame from BBQ skewers. The 1/5 driver comes from Pete's Pilots. Yes, I know he's sporting an oxygen mask, but he's just had a sortie in his Spitfire, OK? A bit of sheeting and some Multiplex 'old timer' instruments.... Next came the task of fairing in all the struttery with balsa. Netty came up with the idea of using 1/4" LE stock. I routed a slot in the rear faces with a Dremel, then glued the pieces together, sandwiching the strut in the centre cavity. Seemed only fair to bolt the whole caboodle together to have a look at it all together for the first time. So the fuselage came first....... .......followed in short order by the wings! Then I persuaded Netty to give it some scale! So, there's lots of small details to sort out - some before and some after covering. For the moment she can stay locked in the loft (the model, not Netty....) whilst we get Xmas done and dusted. tim Edited By Tim Hooper on 24/12/2011 18:01:13 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted December 24, 2011 Share Posted December 24, 2011 W O W Tim , You don`t do things by half measures do you . That looks better than great and you haven't even covered it yet . Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 24, 2011 Share Posted December 24, 2011 looking lovely Tim, and the Blackburn looks great too. Really like the look of this one. May get added to my ever lengthening list of must builds Have a great Christmas, look forward to catching soon Cheers Danny Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 24, 2011 Share Posted December 24, 2011 Looks great as always Tim - and quite a lot bigger than I had realised. Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 24, 2011 Author Share Posted December 24, 2011 Thanks Guys!Timbo, even though it 'only' spans 65", the side-by-side fuselage and long interplane struts mean that the model stands some 20" tall, giving it quite a presence!Merry Christmas to you all!tim Edited By Tim Hooper on 24/12/2011 18:22:46 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted December 24, 2011 Share Posted December 24, 2011 merry christmas tim and netty......pleasure meeting you both at the green acre's do... ken anderson ne..1 .... TH/N fan club dept Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted December 24, 2011 Share Posted December 24, 2011 That last picture of yours just took my breath away,just stunning absolutely beautiful congratulations,Im in love,by the way the models not to bad Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 26, 2011 Author Share Posted December 26, 2011 Thank you Stephen! It's been a smelly old day here. Firstly the sanded fuselage was daubed in sanding sealer, then rubbed down again. Then it was time to crack open a new tin of dope and some fresh tissue. Several hours later sees the fuselage and struts all covered in tissue, and me in the pub ..... tim Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted December 26, 2011 Share Posted December 26, 2011 Are,you dope sniffers loses hours of your lives Quote Link to comment Share on other sites More sharing options...
